Question about Kenmore 65924 Electric Dryer
My electric dryer kenmore 70 series it works but runs for about 15 min. then shuts off it won't run full cycle. What's the problem?
Is your dryer plugged directly to a power source or are you using a surge protector?
Posted on Jan 17, 2013
SOURCE: kenmore 70 series clothes dryer
My dryer is making a loud sound while drying the clothes. The heater still works, but is just very loud while drying. What is the problem with my dryer?
Posted on Jan 05, 2009
SOURCE: Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Posted on Jan 26, 2009
  • 65 Answers
SOURCE: Kenmore 70 series dryer shuts off and won't restart
IT SOUNDS AS THOUGH THE MOTOR IS OVERHEATING AND SHUTTING ITSELF OFF. THAT IS ABOUT THE ONLY THING ON THE DRYER THAT WOULD SHUT IT OFF AND NOT ALLOW IT TO START AGAIN RIGHT AWAY, BUT LET IT START AFTER A WHILE. MAKE SURE THE MOTOR TURNS FREELY. IT SHOULD NOT DRAG OR HUMM WHEN TRYING TO START.
Posted on Jan 28, 2009
  • 686 Answers
SOURCE: Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Posted on Apr 06, 2009
Maytag317
  • 1136 Answers
SOURCE: My Kenmore electric dryer runs but no heat ....
Hi, You will need to remove the front lower panel and this will get you to the element and thermostats.
With the dryer running. check voltage to the element and you should get 240V. If there is voltage, you will need to change the element.
If there is no voltage to the element, UNPLUG the dryer and check the thermostats and fuse for continuity. These parts are located on the element housing and the blower housing under the drum.
If any of the thermostats or the fuse are open, they will need replaced.
I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
Posted on May 29, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
Kenmore dryer 70 series flame ignites, but goes out after 5 mins
If it's gas, the coil valves get weak and are unable to hold themselves open when hot. First, check the exhaust vent. If it's clogged, it can't remove heat and it will shut off prematurely. Most likely the coil valves though.
Mar 03, 2009 | Kenmore 63942 Dryer
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Kenmore 400 series electrical dryer
I have a 400 series kenmore dryer that just quit running after 10 min. into cycle. breaker in house checked and is ok but no power to dryer. what could the problem be
Oct 18, 2008 | Kenmore 73952 Gas Dryer
Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Feb 28, 2008 | Kenmore 64952 Electric Dryer
Signal
Kenmore 70 series. Model/Stock 66702692 Serial MG2402832
Cycle Signal works but then won't shut off until I open up the dryer door - it just keeps buzzing for hours. Also the dryer will turn on if I close the door ( and arrow is within a number and not on off) without pressing the start button. So if door is closed - the dryer will run or buzz (depending on arrow). How do I fix this?
Thank you
Jan 04, 2008 | Kenmore 64892 Electric Dryer
Kenmore 70 series clothes dryer
Feb 15, 2007 | Kenmore 60172 Electric Commercial Dryer
Kenmore 65924 Electric Dryer Logo
259 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
