Question about ECS 945G-M3 (V3.0) Motherboard
Wont power on
Where do i put the power sw and power led plugs
    President:
  • 2,976 Answers
Look at the schematic that should have come with it. The pins will have markings on them. They may be letters, numbers or a combination.
Posted on Jan 23, 2009
Where do I plug in the power sw and power led wire on the eMachines T5274 computer? Thanks
When looking at the motherboard with the back of the computer to your left, there should be a row of pins on the lower right corner of the motheboard (or close to the corner). These pins are normally marked as something like PLED (for the power LED), PWR SW for power switch, RST for reset, IDE LED for the hard drive light, etc.
The power switch is normally along the bottom row and the power LED is on the top. But--to find where the power switch goes, take a small screwdriver and short two of the pins to see if the computer turns on. If it does, you've found the power switch. When the computer is running, put the power LED plug across two pins to see if the power light lights. If it doesn't, try two more until you find it.
var fctb_tool=null; function FCTB_Init_88a0199091e74aa0ab8dd27b901b03c6(t) { fctb_tool=t; start(fctb_tool); }
Nov 13, 2010 | eMachines T5274 Desktop PC
I have a intel media series dp35dp motherboard. I have a power led cord, reset sw cord, power led cord, m/b sw cord and a speaker cord for the speaker on the chasis. When I plug them up I don't see a spot...
in newer generation motherboard the buzzer is built in in there is no need to connect an chasis speaker if built in buzzer is not there uwill find a four pin conecter near the power pannel you nedd to conect the pwer switch and reset switch in proper conector or the system wont powerup properly
Sep 25, 2010 | Intel Computers & Internet
IVE TOOK MY COMPUTER APART AND PUT IT BACK TO GETHER BUT I DONT NO WHERE TO PUT MY HD LED ,POWER LED, POWER SW, RESET SW SOME 1 HELP ME BECAUSE I NEED MY PC WORKIN LOL I PUT DEM IN A PLACE BUT WHEN I PUT...
on board it sould say hd power reset on the front panel on board use manual that it came with or you go to libary go to web site of board type s740mp will tell you the maker of board go there type in board number go to manual then print it out ok jim
Feb 19, 2010 | AMD S740MP (S740MP-1800) Motherboard
Power Button wire to mother board power led power sw HDD Led . what pin connects to the three wires from power button. Led Power wire to what pins, HDD Led to what pins and power SW to what pins on the...
There are may motherboards, but most have writing on them as to what is suppose to plug where. For example, for the power switch, the lettering might be "Pwr" or "Power" or "Pwr sw". The pins are usually together and should fit the plug on the end of the wire.
Nov 25, 2009 | E-Machines eMachines Desktop PC
I put a motherboard in my pc and i dont know where 2 put POWER SW,RESET SW,HDD LED,POWER LED....please help
http://eu.shuttle.com/archive/en/prod/mb/big/av49vn.jpg
ok man on this picture in the bottom of the pic there will be a sort of black rectangle with nine pins, 5 on bottom, four on top. This is where all your POWER SW,RESET SW,HDD LED,POWER LED will be plugged in. I could not find instructions for your board but for mine it is
Looking at the pins from the side where there are 5 pins on the bottom and 4 on top. The top two sould be the power led the two next to that should be the power switch, the bottom two to the left should be the hard drive led and the two next to that should be reset.
This is not the guaranteed position seeing as we have two completely different models.
Hope this helps.
Jun 17, 2009 | Ultra Computers & Internet
HI! I was cleaning the inside of my e-machine W3502 and I putted off the 3 cords labeled Power LED green in color,HDD.LED red in color, and the POWER SW. Now i don't know how to put them back on in order....
look on the motherboard where all the cables are plugged in, It should list on the board in small letters what plugs in there. whats written on top goes on the top pins & bottom list should be the bottom pins.
Jan 14, 2009 | E-Machines eMachines Desktop PC
I have a Northdate computer and every time I push the front button to turn it on it would shut right back down. I opened the side panel and took out the power supply box and replaced it. Still doing it...
ok find the pin on the mother board of your pc you will see a 9 pin like this ( ::::. ) or in reverse order just put the pw sw. in pw mark you can see that just read it
Jul 21, 2008 | Northgate Computers & Internet
Gateway wont turn on
Usually in the motherboard it tells you where those plug correspond to the board. to you see and pins on your board that are labeled?
Jul 05, 2008 | Gateway 507GR PC Desktop
Icute to motherboard wiring
Hi, on the edge of your mother board closest to the front of the computer, you will find a double row of pins. Use a torch and if needed a magnifying glass and study these, you will find they are labeled the same as your cables from the case.
In some cases the plugs are set as a 3 space plug, if you find one of these that wont fit. just split it. If you plug the LED wire back to front, don't panic it won't hurt they just wont work. The power and reset are not pole sensetive.
Goodluck mistyman
Dec 23, 2007 | Computers & Internet
Front Panel Switch wires
If you can see, this is the setup
Jan 25, 2007 | Gigabyte GA-7ZXE Motherboard
ECS 945G-M3 (V3.0) Motherboard Logo
143 people viewed this question
Top ECS Computers & Internet Experts
David
David
mitch_3020
mitch_3020
Greg Cann
Greg Cann
Are you an ECS Computer and Internet Expert? Answer questions, earn points and help others
