Question about Compaq Presario 5000 PC Desktop
PRINTER NO POWER
I press the power on button of my printer is no power. I check the cable but it connect properly. What is the problem of my printer?
  • 3,940 Answers
Depending on the model and design of your printer, it could be several things. If the printer has an external power supply, it may have failed.
Try plugging the printer into a different outlet (Bypass any surge protectors etc) with all cables disconnected from the printer. If it powers on, then try connecting the data cable and see if it still works.
If the printer doesn't power on with all other connections removed and in a different outlet, then if under warranty, contact the manufacturer for repairs/exchange.
If the printer is out of warranty, they are generally cheaper to replace than to repair
Posted on Jan 25, 2009
Power but not printing
Hi Linda,
Did you check if the printer is able to scan or does it makes photocopy? if the printer doesn't respond to any input follow below steps.
  • Power Drain:
  1. Turn the printer OFF using the power button.
  2. Disconnect the power and USB cable from the back side of the printer.
  3. Press and hold the Power button for 30 seconds and release the button.
  4. Connect the power cable and try printing.
  5. If the above steps didn't work try below.
  • Partial Reset: Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button. If you still see the issue try next level of reset.
  • Semi Full Reset:- Remove the ink cartridges; Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button.
Feb 07, 2012 | HP PSC Photosmart 2355 All-in-One Printer
Tip
HP Office Jet All in One : Resetting Steps
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
NVM Reset
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards,
Rizwan
on Jan 19, 2010 | Office Equipment & Supplies
Error 5200 of canon pixma mx328. i already tried turning it on and off several times and even got the cartridges and returned them back but still when i tried to print a page error 5200 still...
Error no 5200 is caused by its temperature high.. to solve your problem follow the instruction given below::
1. Turn Off printer, cable power still plug in.
2. Press Stop/Reset button, don't release the button.
3. Press Power button by holding without release and than release Stop/Reset Button.
4. Press Stop/Reset button two times (2x) now release the Power Button.
5. Wait until service mode to zero (0).
6. Turn off the Printer, cable power still plug in.
7. Press Stop/Reset button, don't release it.
8. Press Power button don't release & than release Stop/Release button.
9. Press Stop/Reset button four times (4x), wait until service mode to "1"
10. Turn off printer, and loose cable power, wait for one (1) minute.
11. Connect cable power, turn on printer again, now this printer ready to use.
Aug 23, 2011 | Canon MX300 Office All-In-One Printer
MY HP OFFICEJET 6 310 ALL IN ONE INKJET PRINTER IS FLASHING RESET POWER
Please follow below resets.
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards,
Riztech
Oct 24, 2010 | HP Officejet 6310 All-In-One InkJet...
Hi. I have a HP all in one printer (C6100). It keeps turning off then immediately back on. Can the printer be reset?
The below are the resetting steps for this printer model. Try next reset if the first one did not help. Do not try all resets together
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards
Riztech.
Aug 18, 2010 | HP Photosmart C6100 All-In-One Printer
Officejet 5610 All-In-One InkJet Printer: error 0xd0620130 reset power...
Please try the below resetting steps
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards,
Rizwan
May 07, 2010 | HP Officejet 5610 All-In-One InkJet...
Worked yesterday, now will not turn on!
  • Try connecting the printer directly to wall outlet without surge protector.
  • If the problem exists reset the print, see below steps to reset it.
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards,
Riztech
May 02, 2010 | HP Photosmart 3210 Printer
My officejet7210 all-in-one, not working . i shut it off to checjk all connections, i had to to move the printer, now it wont turn on. I've pushed the on button quickly, held it. no go. any ideas?
hi, lets try some reset on the printer but before that make sure that the printer is directly connected to the wall socket and there is no power surge protector connected now place your hand on the the power adaptor of the printer and check if the adaptor is heating or not if its heating then proceed further if not then there is some problem with the adaptor
now connect the power adaptor to the printer and then try turn on the printer if its not turning on then press and hold the power button for 10 sec and then remove the power cable from the printer now keep pressing teh power button and after 10 sec reinsert the power cable and then release the power button
still if the printer is not powering on then press the # and 3 button on the printer and then while pressing them remove the power button wait for 5 sec and then replug the cable while pressing the buttons
now try to power on the printer if not powering on still then try the above step using the # and 6 buttons if till face the problem then the device needs service
Aug 29, 2009 | HP Officejet 7210 All-In-One InkJet...
HP Officejet G85xi with no power
Hi..
You can try to reset the Printer to factory settings.Just follow the below steps, dont worry my steps will not mess your printer , as i was HP tech support for All in One printer for 20 months.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait for 40 second then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait for 40 second then release the buttons. Push the ON button and check.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold ENTER/OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons for 40 seconds ,then release the button and Push the ON button.
Please try the steps and let me know the result.Waiting for good reply from u.
Cheers
RIZ.
Feb 11, 2008 | HP G85xi All-Color InkJet Printer
Alignment failed
Just try to reset the Printer.the pro L series printer can be reseted as follows.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button.
SEMI_FULL RESET:-Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button.
FULL NVM RESET:-Turn the printer OFF, Disconnect the power cable from printer and from the wall outlet.Wait for 1 minute.Connect one end of the power cable to wall outlet.Press and hold # and 9 button and connect the Power cord while holding.After connecting , release the button.Then Turn ON the Printer.
(Notes - resets will take a while)
Feb 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
Compaq Presario 5000 PC Desktop Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
