Question about ATS RA2180BB Cordless Expansion Handset
American Telecom cordless answering machine w/3 ext. #RA2184BB
I just opened the box to my cordless telephone and answering machine with 3 extensions. I followed the directions to charge the batteries for 24 hours. The red light was still on, and the bateries did not charge.
Would you please replace the 8 AAA rechargable batteries so that I may use my new phone?
Thank you for your help.
Chris Lyons
4713 Calle Reina
Santa Barbara, CA 93110
(805) 683-2366
  • 1 more comment
  • danettebdunn Mar 09, 2009
    The red light stays on. In the manual it says it should say "Ready" but I charged it in its entirety and it still stays on. What should I do?
  • witch87711 Mar 12, 2009
    Get a better phone! Try a Uniden!
  • danettebdunn Mar 13, 2009
    I have the RA2180BB Cordless Expansion Handset and the red light stays on and it acts like it is dead completely. The only light on is red on the charging station. I can't get ahold of the company because they are obviously not concerned wtih the quality of the products they sell. Please help. They make a pretty expensive paper weight.
You more than likely have one or both batteries DOA. Switch them out with OTC rechargeables.
Posted on May 30, 2010
Intercome doesn't connect
sounds like one of the devices is broken. I would try to find another phone to add to your setup. You will need to test them bnoth to find out which is broken.
Dec 24, 2013 | Quad American Telecom RA2184BB 1.9 GHz ...
Does the USB cable go into the LINE or the EXT connector for the X125
There is only one connector to hook the USB cable to on the back of the printer. You are probably confused with the telephone line connections. The telephone line from your telephone wall connector normally connects to the LINE in connector. A telephone line out to an extension or answering machine would be connected to the EXT connector.
See the quick set-up guide for how to set up your printer and make the telephone and USB connections.
Jan 30, 2011 | Lexmark X125 All-In-One InkJet Printer
I have an america telecom model-RA2184BB that is saying BS Search how do i fix it.
keep pressing the intercom putton on the base, this will register the phone with the base unit.
Nov 11, 2010 | Quad American Telecom RA2184BB 1.9 GHz ...
American telecom digital cordless phone
The razon that you can't make a call may be because your phone been disactivated.
Let em help you to activeat it.
1.- Take your phone off the base,
2.- In your phone ,hold and press the # sign
3.- you will heat a bip that means is activated it.
4.- put your phone in base for 3 mts and is ready.
Your rating is important for me.
Was this helpful?
Jun 26, 2009 | Lands Phones
My American Telecom Digital Cordless Phone doesn't work
their customer service is not answering they have several number I guess they are almost out of the business. If you have the box please bring it back to reseller and get your money back. I had the same problem than you! Cecile
Apr 21, 2009 | Lands Phones
I can hear, but not talk, on my ATS RA2184BB cordless phone.
Have you tried unplugging your base station and all the handsets?
Sometimes the base station, where the power and the telephone line plugs into needs a reset. Just like a computer sometimes it needs a reboot.
If problem presists, take a regular analog phone and plug it in to the same jack as the cordless phone bas station, and see if it is a cable issue/ telephone company issue.
Mar 19, 2009 | Lands Phones
Answering machine not working
Open your TalkSwitch Management Software.
Go to Local Extensions/Fax
Select the extension you are using for the fax.
Click on additional settings under the activate extensions section
On the direct Line Access Tab put a check mark in the check box for "Use Direct Line Access on:" Select your Hunt Group or the number you have to dial to get an outside line.
This will force this extension to not have to dial 9 or whatever number to get an outside line for dialing out.
Jan 25, 2009 | TalkSwitch CT.TS001.124001.US...
Do not know which port to connect telephone line
there is only one line to connect to telephone. it same to the telephone connection line.
Nov 13, 2008 | Brother MFC 210C All-In-One InkJet Printer
Can I use this fax on a telephone line together with a GE 2.4 GHz Cordless Telephone (Model 27992B)? Will it be possible to recive messages and faxes when no one is at home? Remark: The answering machine...
sure u can: Installation with an answering machine and/or extension telephone: 1. Remove the seal covering the TEL. SET jack on the rear of the fax. Connect an extension telephone or answering machine to the TEL. SET jack. 2. If desired, connect an extension phone to the answering machine. from the user Fax guide: If desired,you can also connect an answering machine or an extension telephone to your fax. ¨ Connecting an answering machine to the fax will allow you to receive both voice and fax messages on the same line while you are out. For details on using this feature, see Chapter 7. (Note: Do not connect an answering machine to your fax if you will be using the distinctive ring feature described in Chapter 2.) ¨ You can connect an extension phone to the fax to make and receive calls like any other extension phone on your line.
Oct 09, 2005 | Sharp UX 510 Plain Paper Thermal transfer...
ATS RA2180BB Cordless Expansion Handset Logo
376 people viewed this question
Top ATS Lands Phones Experts
Computer Repairing
Computer Repairing
Are you an ATS Lands Phone Expert? Answer questions, earn points and help others
