Question about HP Color Laserjet CP3525 Printer Series, Color Laserjet cm3530
Cp3525 makes noise when printing and at start up
4 Suggested Answers
broyyce
  • 30 Answers
SOURCE: HP CP3525 loud grinding noise
Sounds like you have a stripped gear somewhere. Probably somewhere in the paper drive assembly. Take it to your nearest printer repair shop, because tech support may not be much help with that.
Posted on May 20, 2011
BaronVonNuke
  • 1915 Answers
SOURCE: HP CP3525 loud grinding noise when it starts a print job. I removed each toner,1 at a time. When the magenta toner is out the noise goes away. I replaced it and still same noise. Any ideas?
Possible that the drum drive for the magenta is not engaging properly. On the control panel go to troubleshooting and then diagnostic test and then component test and test all the cartridge/drum drives.
Posted on Nov 18, 2016
Inkworks
  • 87 Answers
Fuser drive assembly would be my educated guess based on problem description. Good Luck~
Posted on Sep 22, 2017
Nov 18, 2016 | HP Office Equipment & Supplies
Hp CP3525 only prints black and whitte
You need to determine if this is a driver issue or a fault with the printer. The easiest way to do that is to go to the diagnostics menu on the printer and run the PQ troubleshooting pages. If they come out in color then the problem is that your driver is set for monochrome print and you need to turn the color back on.
Sep 02, 2014 | HP Office Equipment & Supplies
Why does hp laserjet CP3525 says A4 in tray 2?
Based on my experience, it is likley that the document you are trying to print was originally formatted for A4 and hence when you go to print it asks for that paper. I have also run into a few fresh driver installs that default to A4(european) paper sizes.
May 23, 2014 | HP Color LaserJet CP3525x CC471AABA...
Hp color laserjet cp3525
CP3525-59.FO ERROR. 1. TRANSFER BELT FLAG/ACTUATOR, WORKING? 2. SENSOR CHECK BEHIND CYAN TONER CARTRIDGE, WORKING? THESE 2 ARE IN THE BOOK AND EASY TOO CHECK. 3. MY ISSUES WAS THAT I REPLACED THE FUSER PRESSURE RELEASE MOTOR ASSY, BUT DIDN'T REALIZE GEARS WERE MISSING FROM SECOND HAND UNIT COMPANY ORDERED.:(. GOT MACHINE WORKING, BUT CYAN CAM IS OUT OF ALIGNMENT AND HAVE TO REINSTALL MAIN DRIVE AND CALIBRATE.. THIS ALL STARTING BY NOT USING HP SUPPLIES. BAD TONER CARTRIDGES HAVE TURN THIS JOB REAL UGLEY!!
Apr 17, 2013 | HP LaserJet Office Equipment & Supplies
HP 8600 makes clicking noise takes long time to start printing
Solved!
Found a misfed page jammed inside the printer on far
right side ( by the ink service station) - after removing the
"hidden" wad, the printer no longer makes "clicking" sounds
and prints right away!
Officejet Pro 8600
Feb 18, 2013 | HP Officejet Pro 8600 Premium e-All-in-One...
Hp cp3525 printer makes clicking noise when printing and start up
  • Make sure the paper type levers are set right in the tray. When loading paper this can get moved and the printer will think it is picking up bigger paper than is actually loaded and it will click.
  • Locate the fuser, usually just before the paper exits and it should be easily accessable from the back panel. Remove the fuser and inspect the gears, they will get chewed up and may need to be replaced. A good sign will be a lot of white dust which is bits of the gear itself.
Jan 13, 2013 | Vizio Xwr100 Dual-band Hd Wireless...
HP CP3525 loud grinding noise when calibrating after printing
May 20, 2011 | HP CP3525N Color LaserJet Printer
Problems printing 4x6 with MP600
You're most welcome. Remember to check all of your paper, I had it curl a bit from sitting too long and I had a very bad paper jam from that. Good luck!
Feb 25, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Makes noise
Click HERE for HP troubleshooting for your printer.
Jun 06, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Color Laserjet CP3525 Printer Series, Color Laserjet cm3530 Logo
82 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
