Question about Bosch Dryers
Bosch wta 3100 changed element still not heating
Purchased new Bosch heater unit ( which includes thermostats) and after fitting, dryer spins but does not heat. Is there another sensor or thermostat that may be at fault?
watugot
  • 290 Answers
SOURCE: Kenmore Electric Dryer Model # 110.62622101
I think on your machine the lower thermostat connected to one terminal of the element, you have a wire coming from the thermal cut off down to the top terminal of the lower thermostat, a wire from the lower thermostat to the timer, and a wire going to the other terminal of the element.
You probably have the wire from the cut-off correct as it won't reach the other terminals. You have crossed the other 2 wires. This caused 240V to short across the lower thermostat and burned it out.
You will need a new Hi-limit thermostat, which will include the upper cut-off as well. They come as a set part# 279816. This will be a little different because the new hi-limit will not connect directly to the element. There will be all the wire ends and instructions with it that you need to get it hooked up correctly.
There should be a wiring diagram inside the console of the dryer that shows which wires go where, but I am sure you have crossed the 2 wires below the hi-limit switch.
Post back if you need any help.
Thanks/Mike
Posted on Dec 02, 2007
  • 1028 Answers
SOURCE: Kenmore Dryer Model 110 Heating Element & Thermostat
believe that model has a relay under console..pull console end caps off remove screw on each end roll console back..if your model has an electronic bd it also has a heat relay it will be the one with 2 large red wires.. a quick ck would be to unplug power remove the red wires and tape bear ends together pug back up turn on dryer if it heats unplug and exchange the 2 relays the one with the blue wires is the motor relay and is same as heat relay try again if motor fails to start bad relay if motor starts bad control bd
Posted on Aug 10, 2008
SOURCE: how to access heating element and thermostat on Admiral ade7000ayw dryer
The top has a hinge bracket in the back. pop the front up with a flat screw driver. you should see the heating element there and be able to access it from that point.
Posted on Aug 21, 2008
canbruce75
  • 1776 Answers
SOURCE: bosch tumble dryer, model wta 4100 , no heat,
If the dryer isn't heating, check for a blown thermal fuse or a faulty heating element. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. Both components are located in the rear of the dryer. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Hope this helped and best wishes.
Posted on Sep 12, 2009
SOURCE: Where do I find the reset button on the Bosch WTA
my dryer is blowing cold air it is a bosch 2000wta
Posted on Apr 07, 2010
Dryer runs but does not produce any heat. Got a memo on the panel saying clean lint filter, which I have done.
The element may have failed if no heat at any setting. It could also be the thermostat but the element is more likely if no heat at any setting
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 28, 2011 | Bosch Axxis WTA 3500 Dryer
My Bosch electric dryer wta3510uc heats but doesnt get hot like other dryers. why is that? it takes over an hour to dry or even more and it use to seem much hotter. clothes are still cool and damp after 40...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Bosch wta 3100 no heat
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 03, 2010 | Bosch Axxis WTA 3003 Electric Dryer
The dryer runs but does not heat up
Depending on your heat source (gas or electric), your problem could be one of the following:
* if electric: heat element, thermostat or timer
* if gas: gas coils, radiant sensor, thermostat or timer
Note: In either case, check to ensure that the dryer is receiving the proper amount of electricity (110 volts for gas & 208-220 volts for electricity).
Feb 19, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Bosch WTA4108 Dryer Not Heating
check and make sure you have 220 volts leving panel and @ the dryer motor runs on 110 volts takes 220 to heat
Oct 19, 2008 | Bosch Axxis WTA 3510 Electric Dryer
GE GAS DRYER DCLR333ETOWW
Check the vent sometimes if the vent is blocked the thermostat gets false reading.There are some other problems such as thermostat,Igniter,heating element.
Apr 21, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Only a little heat is going to the cylinder
Zuraxus what you are seeing is normal for a time. Here is how this dryer works. With a wet towel in the dryer, the first 5 minutes is testing to see if the load is wet. If so then between 5 & 10 minutes the dryer will turn on the 800 watt heater section (only in clockwise rotation). If still wet enough from 10 minutes to 15 minutes it will turn on the 1900 watt heater (heating only in clockwise). If still wet enough 15 to dry will turn on the full 2700 watts in clockwise and 800 watts in counter clock wise. That is how the cycle works. However it is hard to tell with the rear cover removed as the blower pushes the air thru the heater. Careful that by running with the back panel off you don't trip the high temp manual reset protector. So yes this sounds normal. What is the issue that is causing you to think the dryer isn't working proper?
Apr 20, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis Dryer won'r heat
hi there what u need to check is the thermostats and the heater element which are at the back take the back panel of should be the small 1 and not the complete back panel right once uve got it of there u should see the stats and element now 1 easy way to check the element is with a cord with a plug on 1 end now with the wire at the other end place the live wire and the neutral wire on each of the prongs make sure they dont touch now hold the wire by the insulated part and turn on the power if it starts to glow then your heater element is ok and u should change the stats if it doesnt then your element is faulty m8
Dec 12, 2007 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Dryer misfunction
Check the fuse. This is a German unit, so every part including the light bulb is 208/240 volts. If the fuse for the dryer on the back is open the unit will not start.
Nov 18, 2007 | Bosch Axxis WTA 3510 Electric Dryer
Dryers Logo
53 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
