Question about Tools & Hardware - Others
Will my furnace operate with out freon - Tools & Hardware - Others
    Problem Solver:
  • 8 Answers
Your furnace doesnt run on freon, your ac does
Posted on Jan 13, 2013
Atwood 1522 LP furnace fan operates at one speed only
Furnace only works at one speed, high and low fan is usually used for AC. It never has had 2 speeds on furnace correct? Furnaces usually only have 1 speed, except for some home models.
Mar 14, 2014 | Atwood 38591 Excalibur XT Furnace 1522 15K...
Furnace blowing cold air
Check for stopped up filter and press reset on outside unit.will. located near Freon lines at bottom of unit
Jan 07, 2014 | Ruud Heating & Cooling
Rv heat pump problems
Open circuit or out of range Freeze Sensor. Air conditioner mode of operation will be locked out. Furnace, heat strip, heat pump and fan mode of operation can continue to operate but displays the last temperature set-point. There is a sensor that detects evaporator freezing, it may be bad or your freezing because of low freon levels
Sep 30, 2013 | Dometic Rooftop RV Air Conditioner
What is a-coil
It is the coil that is on top of or below your furnace that the freon flows through to cool your house when your ac is on. To locate it you need to follow the two copper lines that are going into the furnace, they are connected to the a-coil.
Feb 06, 2012 | Fujitsu Heating & Cooling
I have a goodman furnace GMVC950704CX and GSC130301DA condensor, my problem is the coil is freezing up and I know the freon level is ok
Hello, if the freon level is ok then there is a airflow problem, such as dirty air filter, dirty evaporator coil, or the blower motor is not pushing enough air across the evap coil.
May 31, 2011 | Heating & Cooling
I have a Coleman model # FC32A3XN1A. The code is flashing 10 = Gas flow with no call for heat. There is also water in the bottom of the furnace below the circuit board. I also hear what sounds like water...
Turn everything off your coil is frozen over and destroying the furnace. The furnace has water on the flame sensor and it thinks the gas is on but it isnt. The water is grounding out the flame sensor. If there is no water damage to the circuit board all you have to do is dry your flame sensor off and you should be fine. Now for the frozen coil you have a freon leak most likely or an air flow issue but you have to thaw the coil out completely before you can find out the problem. Check your air filter is it clean make sure your blower inside the furnace is rotating. If all these things check out ok you have to get the A/C charged with freon you have a leak. If this help please rate me and do a testimonial.
May 23, 2011 | Heating & Cooling
Rheem criterion gas furnace
Check freon, you will need guages on the condensor, also make sure the cond, outside unit is operating
Jun 14, 2009 | Amana Comfort Zone 12M32PBEH Air...
My central air unit keeps freezing up on the inside
1) locate the A-Coil (A-frame) inside the furnace. It is usually located in the furnace supply plenum located on the "down" side of the furnace plenum. If it is very dirty, there will be poor air flow generally in the house. This can cause the A/C to "freeze up" as the refrigerant is not getting enough heat to convert the refrigerant to a gaseous state.
2) The unit may be low on freon (or whatever refrigerant you are using). Contact a serviceman to check the unit.
Jul 07, 2008 | Coleman Heating & Cooling
Tools & Hardware - Others Logo
15 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
