Question about Vizio Xwr100 Dual-band Hd Wireless Internet Router
Hp cp3525 printer makes clicking noise when printing and start up
  • Vizio Master
  • 2,072 Answers
  • Make sure the paper type levers are set right in the tray. When loading paper this can get moved and the printer will think it is picking up bigger paper than is actually loaded and it will click.
  • Locate the fuser, usually just before the paper exits and it should be easily accessable from the back panel. Remove the fuser and inspect the gears, they will get chewed up and may need to be replaced. A good sign will be a lot of white dust which is bits of the gear itself.
Posted on Jan 14, 2013
HP CP3525 loud grinding noise when it starts a print job. I removed each toner,1 at a time. When the magenta toner is out the noise goes away. I replaced it and still same noise. Any ideas?
Possible that the drum drive for the magenta is not engaging properly. On the control panel go to troubleshooting and then diagnostic test and then component test and test all the cartridge/drum drives.
Nov 18, 2016 | HP Office Equipment & Supplies
Hp CP3525 only prints black and whitte
You need to determine if this is a driver issue or a fault with the printer. The easiest way to do that is to go to the diagnostics menu on the printer and run the PQ troubleshooting pages. If they come out in color then the problem is that your driver is set for monochrome print and you need to turn the color back on.
Sep 02, 2014 | HP Office Equipment & Supplies
Why does hp laserjet CP3525 says A4 in tray 2?
Based on my experience, it is likley that the document you are trying to print was originally formatted for A4 and hence when you go to print it asks for that paper. I have also run into a few fresh driver installs that default to A4(european) paper sizes.
May 23, 2014 | HP Color LaserJet CP3525x CC471AABA...
Hp color laserjet cp3525
CP3525-59.FO ERROR. 1. TRANSFER BELT FLAG/ACTUATOR, WORKING? 2. SENSOR CHECK BEHIND CYAN TONER CARTRIDGE, WORKING? THESE 2 ARE IN THE BOOK AND EASY TOO CHECK. 3. MY ISSUES WAS THAT I REPLACED THE FUSER PRESSURE RELEASE MOTOR ASSY, BUT DIDN'T REALIZE GEARS WERE MISSING FROM SECOND HAND UNIT COMPANY ORDERED.:(. GOT MACHINE WORKING, BUT CYAN CAM IS OUT OF ALIGNMENT AND HAVE TO REINSTALL MAIN DRIVE AND CALIBRATE.. THIS ALL STARTING BY NOT USING HP SUPPLIES. BAD TONER CARTRIDGES HAVE TURN THIS JOB REAL UGLEY!!
Apr 17, 2013 | HP LaserJet Office Equipment & Supplies
HP 8600 makes clicking noise takes long time to start printing
Solved!
Found a misfed page jammed inside the printer on far
right side ( by the ink service station) - after removing the
"hidden" wad, the printer no longer makes "clicking" sounds
and prints right away!
Officejet Pro 8600
Feb 18, 2013 | HP Officejet Pro 8600 Premium e-All-in-One...
I have a HP Photosmart C4780 all in one printer and when I turn it on, as well as before I go to print something, the printer makes a horrible, loud clicking sound. I have cleaned out the inside and...
There may be nothing you can do about it. A lot of the HP printers make a lot of noise as they start up or prepare to print. Has your printer always made this noise or did it just start?
Jul 26, 2011 | HP Photosmart C7280 Laser Printer
HP CP3525 loud grinding noise when calibrating after printing
Sounds like you have a stripped gear somewhere. Probably somewhere in the paper drive assembly. Take it to your nearest printer repair shop, because tech support may not be much help with that.
May 20, 2011 | HP CP3525N Color LaserJet Printer
I have HP laserjet 1018 printer and it makes noisy sound when it prints. But it prints fine though. What causes making this noise?
The noise is probably due to the print heads aligning and clicking. To try to make this noise a little quieter, clean and align the print heads.
Mar 23, 2011 | HP LaserJet 1018 Printer
Hp 2115 - clicking noise from carriage, can`t print test page
I have an HP 6110 is always has a grinding noise.No functions work. HP just want me to buy a new machine. They are bad quality 3 in one's. That is for sure.
Jun 28, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Makes noise
Click HERE for HP troubleshooting for your printer.
Jun 06, 2008 | HP Officejet 5610 All-In-One InkJet...
Vizio Xwr100 Dual-band Hd Wireless Internet Router Logo
75 people viewed this question
Top Vizio Computers & Internet Experts
Jessi Singh
Level 1 Expert
ray gallant
Are you a Vizio Computer and Internet Expert? Answer questions, earn points and help others
