Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Ice Cream Melting...
Please Help, Our "new" Kenmore (purchased October, 2004) Trio Bottom Freezer Refrigerator, Model 596.75509400, Serial 10890213ET, started making a different noise about two weeks ago. In the freezer, the ice cream got all runny, and the frozen French fries were soft (both items located in top shelf). The items in the bottom shelf seemed to still be frozen (fish fillets and steaks for example). The temperature in the refrigerator seemed to be about right. The intermittent noise, when it occurs, takes place every 2 to 5 minutes, for 3 or more times, started with a click, continues as a buzz for about 5 seconds, and concludes with a click. It sounds like something trying to start and then giving up. We pulled out the fridge, unplugged unit (condenser fan running), and made sure the lower area was free of dust. Although minimal, we blew out and cleaned everything, taking about 20 minutes. Upon plugging the unit back in, everything seemed fine for a couple of days (freezer at 0 degrees). Upon next occurrence (freezer at 30 degrees), we turned up the controls for both freezer and fridge (5 to 7), which seemed to work again (freezer at -15 degrees). After a couple of days, I turned the controls back to 5, their normal settings. After a couple of hours, it was off to the races again! The repair man arrived the next day, open the freezer, which was working fine at that moment, mentioned he had a lot of problems with the evaporator fan going bad, and walked out with a check. The next day he installed the new fan (by the way, I noticed ice on the evaporator when he removed the rear panel in the freezer), and walked out with a second check. The fix lasted about 2 hours. Upon calling the repair man again, explaining that his fix did not work, and going over our problem again in detail. He mentioned a relay, said he would be out tomorrow, and was never heard from again. Is there something I can do to fix this problem (9 days before someone from Sears can get out here)? Is the frost on the evaporator a clue to the problem, or a sign of impending failure? Any comments or advice would be greatly appreciated... Balto Marty
    President:
  • 1,462 Answers
The ice on the evap may be the clue. there should not be excessive ice build up and if this has occurred, the ice can jam the fan. try removing the freezer back panel, defrost with a hair dryer, reassemble and see if it works. if it does, the fault lies with the defrost system
Posted on Jul 09, 2007
How do I take KENMORE ELITE TRIO 596.75533400 out of demo mode?
Try pressing ultra ice and home while the refrigerator door is opened,or ultra ice and the refrigerator pad with the freezer opened. Hold for five seconds. Hope that works.
Jun 12, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
Our Kenmore Elite french door bottom freezer, automatic icemaker, no water/ice dispenser on the door - is leaking quite a bit - had to mop up the floor three times today. first time it's happened since...
Check for cracks in the water supply tube from the house plumbing valve to the ice maker. Could also be the valve itself.
Turn off valve for a day to diagnose which.
Oct 21, 2017 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Ice Cream In Freezer Is Soft
DON'T BY ICE CREAM! LOL Try putting ur ice cream somewere else
Oct 26, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Just bought a kenmore elite bottom freezer trio model and display panel shows o ff. Expect this means whole unit is off but manual does not say how to turn ON in the setting the controls section of manual....
I just purchased a similar model and had the same frustration. Finally called the store and it was in DEMO mode. Open the freezer draw and hold down the Ultra Ice & Refrigerator Temp buttons simultaneously for 5 seconds. That worked for me and hope it will do the trick for you.
Jul 12, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Refrigerator Trio display panel read ER IF and everything seems to be melting or thawing. Not making ice and water is running from door where the ice seems to be melting? HELP! My freezer...
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 08, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Elite trio
Hello bigmikeegator
Welcome!
You said, you have the Kenmore Elite Trio Bottom Freezer. You moved your refrigerator to a new home and removed the bottom freezer door, but can not seem to figure out exactly how to put it back on correctly.
It's too much for me to tell you myself.
This is easier!
Page 9 shows you how to remove and reinstall doors.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523115.pdf
Thank you,
Huuum,
Please remember to leave a rating!
Oct 06, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Kenmore 596.755 23400 problem with freezer
You can try to replace the relay and overload but on this model usually the compressors go bad. Call sears to check the warranty. The compressor should have a five year warranty.
May 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite Trio 795.7756 /7757 problem
I had the same problem, freezer full of groceries defrosting or crisper drawer freezing produce. Sears Appliance Repair sent servicemen out twice and both times I was assured the problem was fixed. After freezing produce the third time I insisted they come and get the faulty appliance. The replacement has worked perfectly since day 1. INSIST ON A REPLACEMENT
Sep 03, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
133 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
