Question about Plumbing
I just installed a Kohler R10433-CP faucet and no cold water comes out even when I move the handle to the cold water "position". Water comes out but it's hot, but not as hot as the hot position.
  • 2,322 Answers
Cartridge may be 180 degrees off
Posted on Jun 18, 2017
  • 68 Answers
SOURCE: Pressure problem with Kohler shower faucet??
Hi pglaw,
My best guess is the supply valve for the hot side isn't open all the way. This valve is right on the valve and is accessed by taking off the front cover plate. This would still allow the pressure balancing valve to let water through but then you would have a small flow on the hot side.
If this isn't it then then cartridge is bad.
Please rate this response and good Luck,, phil
Posted on Dec 31, 2008
  • 148 Answers
SOURCE: Kohler Forte Single Handle Faucet Leaks
you will have to replace the ball assembly with a repair kit
1 turn the water off under the sink (hot and cold)
remove the handle ( you may need an allen head wrench to remove a hex screw or you may have to take a channel lock pliar and unscrew achrome
nut over the ball mechanism
after the handle comes off there is usually some type of lock nut that you must remove to remove the ball mechanism
remove the ball (usually chrome or brass(ther are usually little springs and rubber washers under ball
take ball and washer to ACe or lowes and match the pieces (usually sold as a kit
follow directions and installl
turn water on and pat yo!ur self on the back !
Posted on Jan 05, 2009
  • 10 Answers
SOURCE: No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
Posted on Oct 24, 2009
  • 4348 Answers
SOURCE: Just lost pressure. Only a very small stream of
First try the tip ariator. it can plug up. then you have to check the inlet system, which includes shut off valves, hoses to the faucet and the cartridge. It is the cartridge that has the small openings, but shut off valve seat material falls back into the feed channel. I usually remove cartridge, cover with a towel and turn on feed water briefly. Often I get little pieces.
Posted on Oct 27, 2010
heatman101
  • 43501 Answers
SOURCE: I have lost virtually all
I assume that you have removed the aerator on the end of the spout and cleaned that out first thing...
If that is not the problem then the possibilities get tougher...
The passageways in many of the newer faucets are very tiny and clog easily...
The best way I have found to clean them out is to remove the aerator...
The disconnect the supply tubes underneath...
Then with the faucet open to the hot or the cold side one at a time blow compressed air backwards through the faucet to blow the dirt back out the way it got in there...
Most of the time, that will work, but sometimes it does not and then the whole faucet is junk...
Hopefully this will work for you..
heatman101
Posted on Jan 15, 2011
Just lost pressure. Only a very small stream of water comes out, hot or cold. All other faucet in the house work fine. It is about 1 1/2 years old. R10433-CP
Oct 27, 2010 | Kohler Model 10433: Fort® Single-control...
Kohler K-16109-4 Revival Kitchen faucets (two handle): When I turn on the HOT water handle and let it run, I get a small leak out of the COLD water handle. When I run cold, no leak. Does this just...
There is definitely a problem with the cold valve if it is leaking, but it seems odd that it doesn't leak when it is on. If I was doing this, I would replace both valves.
Nov 14, 2017 | Kohler K-16109-4-CP Revival Kitchen Sink...
Disassembled handle and initial pieces under handle to find leak source. Single handle shower assembly. reassembled. Cold water only, no hot water. What did I not assemble correctly?
Take handle back off and see if it has a dial that can be removed and repostioned. take off and move it about 1/4 turn counter clockwise and reinstalled and try to see if mixture is correct.
May 18, 2010 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Oct 07, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Kholer faucet won't move from sise to side
under the neck there is a o-ring it is starting to go bad.call a plumber to fix if you can't do it yourself.
Jun 28, 2009 | Kohler Model 10433: Fort® Single-control...
Faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
May 06, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Kohler shower facuet pressure balancing problem?
ever since the pressure balancing regulations came out for shower valves, they have went from simple to very complicated devices. sounds as if some foreign material caused the valve to stop working. that valve is quit difficult to reassemble correctly because there is only one way it works and can be assemmbled many ways that do not work concerning alignment of the ports. if you dissassemble it and check that all the moving parts are functioning in the balancing cartridge you can then look closely at the alignment of the ports on the cartridge that the handle is connected to. understanding how the port align as the handle is turned should assist you in assembling it correctly......hope this helps.
Jan 20, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Hi pglaw,
Dec 30, 2008 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Nov 12, 2008 | Kohler Forte entertainment remote valve...
Plumbing Logo
402 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
