Question about ConnectLand USB 20 External Enclosure for 35Inch SATAIDE Hard Drive CLENC35008 Serial ATA USB 20 External Drive Case
Window 7 Drivers for Connectland 1908054 - ConnectLand USB 20 External Enclosure for 35Inch SATAIDE Hard Drive CLENC35008 Serial ATA USB 20 External Drive Case
ConnectLand cl-me 606 goose neckdesktop microphone to desktop
Look for a 3.5 mm microphone port on the computer. Usually the port on the back of the desktop will have a pink surround. (There will be other ports there; the usual minimum are the green port for speakers and blue one for line-in.) Put the 3.5 mm jack on the end of the cord on the microphone into the port. If you have an add-in sound card, use the microphone port on the sound card.
Some machines will also have a front panel microphone port. This will have a small mike icon next to the port.
Next you need to ensure that the audio device is set to Microphone. For Windows systems (Vista/7/8), enter the Control Panel and go to the Hardware and Sound panel. Click on Manage Audio Devices under Sound. Then click on the Recording tab. Check if the microphone listed as plugged in. Make this the default recording device. (XP has a slightly different name for the panel.) For XP through Windows 7, click on the start button and then find the Control Panel listed on the right. For Windows 8, from the desktop, press the Ctrl and X keys at the same time. Then find the Control Panel in the list. (Alternatively, activate the Charms menu, Ctrl+C or hover on the upper right of the screen. Move down and click on the gear (Settings). Then select the Control Panel.)
If the computer doesn't indicate that the microphone is plugged in, make sure that the 3.5 mm plug is in the correct port. Next try the microphone on another computer. The audio card port could be damaged or the microphone cable could be faulty. If the microphone works on another computer, you can try a USB audio adapter (StarTech ICUSBAUDIO or similar) or a new sound card. (Note: some older sound cards do not work properly on newer versions of Windows. If you have a sound card installed and the motherboard has an on-board audio device, remove the sound card. Enable the on-board audio in the computer's BIOS. Install the appropriate audio drivers. Try that audio device. Accessing the BIOS will depend on computer. Often you can press Esc, F1, F2, F10 or Delete repeatedly after you turn on the computer. If Windows starts to boot, turn off the system and try again.) If another computer doesn't recognize the microphone, I'd recommend a new microphone. Fixing the cable isn't worth the effort.
I hope this helps.
Sep 20, 2013 | Computers & Internet
Connectland usb u2mnhub not connecting any devices
Go on line search manufacture if your hub and check for laters drivers and then delete and reinstall software or just new drivers, also check by going to start menu look for control panel look for device manager select it , then scroll down list till you see USB devices , look at usb icon host controllers and see if there's is a failed icon symbol beside your USB icon like a red or yellow exclamation mark or an x
Dec 15, 2012 | ConnectLand CLU2FPHUB4W USB 20 4 Ports Hub...
My printer( HP Deskjet 1050 all-in-one J410 Series) isnt compatable to my toshiba windows 7 and i lost the cd
I checked it and found that it is compatible with Window 7.
Here is the drivers link for window 7 32bit or window 64 bit.
http://www8.hp.com/us/en/support-drivers.html
click on your printer and then select the operating system and then download HP Deskjet Full Feature Software and Drivers not the Basic Drives.
Note:-To check whether is Win 7 32bit or window 7 64bit
start>>right click on computer>>left click on properties>>now you see whether is 32bit or 64 bit operating system.
Let me know whether this was helpful or not.
Apr 08, 2011 | HP DeskJet F380 All-In-One Printer
My laptop mark is hp G60, i installed in WINDOW 7 and up to now the web camera failed doesn't work at all.I thought about web camera driver for WINDOW 7.How may i get it or how may i solve the problem?...
There are usual isolated cases that the drivers for the webcam on your netbook might not have a compatible driver for windows 7.
you can tryo downloading the Vista Version of the webcam. Because windows vista ans windows 7 has the same architecture.
Here is a link for the download of the drivers:
http://tinyurl.com/29qecrk
Cheers!!
Sep 10, 2010 | HP Pavilion dv9000z Notebook
Audio drivers
try window vista driver for window 7OS vista driver work many time in window 7 download window vista driver from here
http://www-307.ibm.com/pc/support/site.wss/MIGR-67616.html
i hope this will fix computer sound problem
Regards
manish
Mar 22, 2010 | Computers & Internet
We have installed window 7 but there is no driver for window 7
The drivers on your old OS can run on windows 7. Or you may download video, sound and other drivers compatible with windows 7.
Feb 04, 2010 | Panasonic KX-P1695 Matrix Printer
I just upgrade to Window 7, to my ACER AspireOne Netbook. Successful install with no problems. I have Acer X163W Monitor to use with my Acer Netbook, before install Win 7, I was able to setup the monitor...
As of now, there are no Windows 7 drivers for that monitor.
Here is the Vista driver:
Acer X163W Vista 32-bit Driver
You can try installing this in Windows 7 using compatibility mode and see if it works. Otherwise, just try to contact them directly or try and submit a query about it.
Oct 31, 2009 | Samsung 941BW LCD Monitor
I have recently installed a window 7, but software cd which i have of hp f4288, that is the old version, that is not installing on this window what should i do now/
Its possible that your f4288 software CD only has drivers for Windows XP or older operating systems. Unfortunately they are not compatible with Windows 7. Try going to the HP website and look at the support area for the F4288, see if they have updated Windows 7 drivers or look for Vista drivers if Windows 7 are not available (as Vista drivers are supposed to be compatible with Windows 7). If Windows 7 (or Vista) drivers are not available on the HP website you are out of luck for now until HP releases new drivers.
Oct 27, 2009 | HP DeskJet F4280 All In One Printer InkJet
NEED MANUAL FOR CONNECTLAND WEBCAM
what is the no. of ur camera (the version)
Jun 06, 2009 | Cameras
ConnectLand USB 20 External Enclosure for 35Inch SATAIDE Hard Drive CLENC35008 Serial ATA USB 20 External Drive Case Logo
286 people viewed this question
Top ConnectLand Computers & Internet Experts
David Payne
David Payne
Are you a ConnectLand Computer and Internet Expert? Answer questions, earn points and help others
