Question about LG LDF6920ST Stainless Steel 24 in. Built-in Dishwasher
LG LDF6920 Dishwasher. Drain pump turns on while filling...constantly!
My dishwasher has been doing this for some time. When you start the normal wash cycle the first cycle in the program is that the drain pump kicks on to remove any access water. Next the dishwasher begins to fill with water. About half way through the filling cycle the drain pump kicks on for no reason (while filling!). Doesn't make any sense. If I open the door during the fill/drain cycle...everything stops (of course). When I close the door and allow the dishwasher to continue it's cycle...it will fill properly then go through the rise cycle as it should. Recently this problem has been surfacing during program drain/fill operations throughout the wash cycle...which then kicks an E1 code (water leakage). Water isn't leaking, it's being pumped out while filling. Any help would be apprecaited!!
LG dishwasher LD1419W2 which would not fill -error code IE. I replaced the inlet hose complete. Now it has the error code FE and the water overflows onto the floor when in wash cycle. Peter
Try resetting by:
turn off dishwasher
trip circuit breaker to remove all power to unit
wait 30 seconds
restore power
start dishwasher
the drain pump should start and drain all water then start a cycle. Good luck
Nov 14, 2017 | LG Dishwashers
Dishwasher wont fill up with water
When you start the dishwasher you have probably noticed that it first drains water and is very important to hear that drain pump running all the time or stops after a while? Why?
If the drain pump runs constantly then the fault is in the phase of "drain water" or is activated anti-flood system. Reset point of pressostat is not reached after max. 120secs. Programme stop and can be continued after error remedy by pressing the programme key.
If the pump is running for a while and then stops, then the fault is in phase "fill up water". Switchpoint of pressostat is not reached
after max. 60 secs.
Usually built-in dishwashers has anti-flood system that responds in the event of water in the bottom of the dishwasher. Such a case, find and repair water leaks.
Dado
Aug 06, 2014 | Electrolux 23 in. ESI6104 Built-in...
LG drains and fills at same time.
This is caused by the " the flood" circuit at the bottom of the dishwasher that detects some water leak. Once this circuit detects any water on the bottom of the washer, it immediately switches the pump out circuit on. It consists of a polystyrene float coupled to a micro switch. You need to dry the bottom and then check for leaks (hose or hose clamp).
Jul 03, 2013 | LG LDS4821ST Stainless Steel 24 in....
Lg dishwasher ldf7932st motor starts but doesn't work
Is the water turned off? Dishwashers normally start a wash by emptying any waste water tipped into them during loading. Problem could therefore be a blockage somewhere, most likely in pump inflow under the filters in bottom of machine. Lift these out to check. Also check your sink drain isn't blocked and preventing the water from being pumped out.
Jan 19, 2013 | LG LDF7932ST Builtin Dishwasher
We have water leaking out on the floor when it is filling
this one of those things you need to inspect..look at all connections and hoses..we know it should not do this..its going to be something like motor seals leaking or the pump or seals on pump leaking? you might luck out and it will be a loose hose...good luck and let me know if you need help
Nov 18, 2010 | LG LDF6920 24 in. Built-in Dishwasher
LDF6920 soap will not come out of dispenser
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 18, 2010 | LG LDF6920 24 in. Built-in Dishwasher
It's not draining properly. The error message is OE. Model number is LDF6920WW
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 08, 2010 | LG LDF6920 24 in. Built-in Dishwasher
Maytag DWU6602AAE. My Maytag dishwasher (14 years
SOUNDS LIKE A TIMER PROBLEM. YOU MAY WANT TO PRICE A REPLACEMENT TIMER. AND PRICE OUT NEW DISHWASHERS. GOOD LUCK!
Feb 25, 2010 | Dishwashers
Not really a problem, Ijust want to know how long a normal cycle should last.
wash cycle is between 10-14 munites. rinse cycle is about 10 munites. pluse time to fill and discharge water from the tub. total time should be about 40-45 munites
Apr 22, 2009 | LG LDF6920 24 in. Built-in Dishwasher
Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Dec 29, 2007 | Dishwashers
LG LDF6920ST Stainless Steel 24 in. Built-in Dishwasher Logo
140 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
