Question about Toshiba Satellite L25-S119 Notebook
Will not connect to the internet wired or wireless
My toshiba will not connect to the internet at all wired or wireless please help...
  • preteewoman Jan 23, 2009
    Thank you Eddie..That was so technical and went way over my head could you make it a little simplier (if that's a word)
    Novelist:
  • 176 Answers
Unplug your power from the modem first and after that unplug your power to your router, disconnect all your cat5 cables and wait for at least 20 secs. After 20 secs or so go ahead and plug your power back to your modem and wait until all the flashing green lights are solid and that the link light starts blinking. After that plug in your Routers power (You can also reboot your PC while this is going on) . Wait until all blinking lights becomes steady then re-connect your cat5 from the modem to your routers uplink and last the cat5 cable from the router to your PC. If you'd rather not test the direct connection then go ahead and switch your wireless on.
Your wireless connection properties on your PC under "Internet Protocol TCP/IP" should be set to "Obtain IP address automatically" and that "Obtain DNS server address automatically" should also be set. Your routers should, if not already, be set to automatic DHCP. Make sure that on your Device Manager > Network Adapters that your wireless network adapter is not disabled and that it has the correct driver (yellow exclamation on it indicates it needs correct driver). You should disable your integrated ethernet LAN card if you have enabled your wireless Network Adapter to avoid conflict.
On your Wireless Network Connection properties under "Wireless Network" tab go to "Preferred networks" and highlight your wireless network name (SSID) . After highlighting click on the "Advanced" button and select "Access Point (infrastructure only) networks only"
Posted on Jan 23, 2009
  • Ed Deguzman
    Ed Deguzman Jan 25, 2009
    Router;
    Check that your Internet Connection Type is "Automatic Configuration - DHCP" and that DHCP server should be enabled under Network Address Server settings. Under Wireless Network Mode select "Mixed". Create and type your wireless network name (SSID) . Wireless channels can be what ever range you would prefer. Wireless SSID broadcast should be "Enabled" so that once you turn on your PC wireless it would become visible and available.
    PC;
    Check the properties of your wired and wireless connection and make sure they are not disabled, if so enable them.
    Click on Start > Connect to > Show all connection
    Right click the wireless connection and select properties
    Under the "This connection uses the following items" look for and highlight "Internet Protocol TCP/IP" then click the "Properties" button.
    Make sure that "Obtain IP address automatically" and "Obtain DNS server address automatically" are the only ones selected then click "OK".
    Click on the "Wireless Network" tab. Make sure your wireless network is listed (Under Preferred networks) and is at the top of the list, if not move it up, if not there Add. Click "OK"
    Right click the Local Area Connection wireless connection and select properties
    Under the "This connection uses the following items" look for and highlight "Internet Protocol (TCP/IP)" then click the "Properties" button.
I have a toshiba dvd blue ray player up to 3 days ago was quite happily watching Netflix now it won’t load. I can get everything else but Netflix. Please help
Sounds as if your player has lost its internet connection. Check the cable if it's wired, and the WiFi setup if it's wireless.
Feb 02, 2018 | Toshiba Televison & Video
Limited or no connectivity wireless
Can you tell me where does is reflects that the driver is outdated?
Also what is the NIC you are using for connecting to internet? Is it Wireless or Wired Network? Please provide the full name as under Device Manager.
And lastly, what is the laptop model you are running?
Let me know and I should be able to help you in fixing the issue.
Oct 15, 2013 | Toshiba Satellite Computers & Internet
My toshiba laptop does not work on a lan. The icon
When you look at the Manage Network Connections link on the Network and Sharing Center you do not see
Local Area Connection?
Do you see Wireless Network connection?
You need to check the device manager to see if the card has been disabled.
It should show two entries with no red or yellow marks. One for wireless (WLAN) and one for wired (Ethernet)
Apr 11, 2010 | Computers & Internet
Toshiba Satellite L355D wont connect to the wireless internet
i am having the same problem and its not software related as i have my laptop dual booting with sabayon 5.0 and im getting the same result in that OS so this tells me that the hardware is failing
if your problem is the same as mine have you exposed your computer to cold or humid atmosphere?
mine sat in my trunk for a week this newyears
Apr 21, 2009 | Toshiba Satellite L355D-S7809 Notebook
Toshiba Laptop Wifi not working
Please make sure you have turn on the wifi and your computer is updated. if you are not sure then you go to http://www.techssupport247.com/wifi-is-not-working-on-toshiba-laptop.html
Here you will get more help about wifi problem on your toshiba laptop and you will able to fix your problem easily.
Dec 18, 2008 | Computers & Internet
Don't have wireless connection on my Toshiba notebook.
Make sure the drivers are installed for your wireless adapter. XP sometimes overlooks adapters during installation. Check the Device Manager for any yellow exclamation points. If you find one, uninstall it and click on the top item (your computer). Right-click the same device and then click Scan for Hardware Changes. You should have your drivers disk ready. The device will likely install, but be unable to find drivers. Point XP to your drivers disk and it should install the drivers for you.
BTW, if you don't have a drivers disk, check your system BIOS for the chipset and google for "<chipset number/name> Windows XP drivers". You should be able to find the drivers and download them from the wired connection before trying the above instructions for reinstalling the wifi drivers.
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Nov 17, 2008 | Toshiba Satellite A135-S4527 Notebook
Wireless Connection
delete all aspects of this wireless installation.make sure wireless button is turned OFF, connect via wired. make sure you can get into internet function. ensure toolbar has an icon that shows ' wireless', disconnet wired cable and turn on the wireless button. do a ''connectivity doctor scan' and see if any wireless devices in your area for secured/non-secured status. turn off wireless for now and reinstall device software driver.
Jun 29, 2008 | Toshiba Satellite M35X-S311 Notebook
Syntax error in wireless connection
does this only happen on wireless connection?
How about wired?
Nov 29, 2007 | Toshiba Tecra M2 Notebook
Toshiba Satellite L25-S119 Notebook Logo
226 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
