Question about Visonic Home Security
My secom (TS500) alarm says tamper and wont let me reset any ideas of what to do?
2 Suggested Answers
SOURCE: hi the house alarm is showing tamper,zone 6 got 2
Make sure you have power to both sensors and if you have any fuses , make sure they are good and try re-setting
Posted on Mar 12, 2010
Hi, my house alarm ready light is not on since I opened the anti tamper box, when the box opened the alarm went off, I put in the entrance code number, the alarm went quiet, since then the ready light
Hi Terry,
Most alarm systems require you to reset the tamper alarm.
Most systems will reset the tamper simply by arming the system and then immediately disarming the system. However, you MUST make sure that the Tamper circuit you tripped is closed. If you removed the cover on the panel, make sure the tamper switch for the cover is in the correct position and that the cover is pressing the switch and closing its contacts. If you are trying to arm the panel with a cover off, the tamper circuit will not reset unless you defeat the tamper switch. Just make sure you remove the defeat when you replace the cover. You may also wish to try a google search on the type and model of panel you have so you can download a copy of the manual to check on the reset procedure. We also need to know what brand and model the panel is so we can help you further..
Nov 26, 2014 | Cars & Trucks
Turn off tamper on gardtec 350 so I can fix socket
If you are disarmed, you should only get a trouble signal when you remove AC power, This should clear when power is re-established. The tamper is a switch inside the panel that trips when the door is opened. This too should be only a trouble if the panel is not armed. (Unless the tamper is programmed for instant alarm like a panic or fire alarm input.) Check your manual for the programming instructions for bypassing or disabling the tamper. Another thing you can do is disconnect the backup battery before removing the AC power, this will stop any alarms, but you should notify your monitoring company first.
http://www.innovatealarms.co.uk/pdfs/GARDTEC350+ENGINEER.pdf
Nov 08, 2014 | Home Security
Gardtec 370 repetitive bb tamper alarm
Yes any bell box will do. Just note your terminals.
you can link out the bellbox tamper from the control panel as a temporary measure until you replace the bellbox, assuming its faulty
Apr 12, 2014 | Home Security
Security Alarm Tamper Detected
The internal battery is depleted an must be replaced TAMPER
Apr 03, 2014 | VeriFone VX510
RESETTING A VISONIC ALARM
Line failure is related to power not phone line. What is the exact model number?
Nov 24, 2013 | Visonic INC Smarthome SecureLinc Wireless...
Hi the house alarm is showing tamper,zone 6 got 2 sensors 1 in kitchen, 1 in living room can u help it wont reset cheers
Mar 12, 2010 | Kitchen Appliances - Others
How can i get the tamper light to go out, so i can reset my alarm on the cooper menvier 9448+ alarm control panel
Find out where the tamper fault is. This panel has tamper monitoring for external bell remote keypad zones and cover. Check all devices for loose covers ,wiring for breaks (especially if new carpets fitted) and bell box.You can check for continuety with a multimeter inside the panel you should have a short between A/T terminals and between 0v and TR if not check the wiring.
HTH
Oct 06, 2009 | Kitchen Appliances - Others
Aopen ax34 tamper alarm--how to reset????
I don't think that board actually has a tamper alarm in the bios, password security yes but I saw no mention of a tamper alarm. Besides, a tamper alarm won't stop the pc from booting, it just lets you know that the case has been opened....sorry. I think you likely have a mainboard/ram issue.
First thing is to clear the bios. Here's how. Right beside the floppy connector, there is a jumper labeled 'JP14'. Please do the following
  1. Turn off the pc and remove the ac power cord.
  2. Remove the atx power connector from the mainboard (from power supply).
  3. Locate jp14 and move the jumper from pins 1 and 2 to pins 2 and 3. Wait 10 seconds.
  4. Put jp14 back to pins 1 and 2
  5. Reconnect the atx power connector.
Or you can just unplug it from the waal and remove the bios battery for an hour.
sa code
Try to fire it up again. If it still won't boot, then let me know the number of beeps it makes and the pattern to the beeps ie: one long beep then another long beep or 1 long beep then 2 short ones. These beep are actually telling you what the problem is.
Hope this helps! Post a comment and let me know how you make out.
Aug 24, 2008 | AOpen AX34-U Motherboard
Home Security Logo
203 people viewed this question
Top Visonic Home Security Experts
Gil Shultz
Jerry Kramer
Jerry Kramer
Are you a Visonic Home Security Expert? Answer questions, earn points and help others
