Question about EliteGroup 661FX-M Motherboard
HDD light & floppy disk light stays on
When i switch on my computer the HDD light & the floppy disk light stays on and i don't get any information sent to my monitor ...therefore cannot even access the BIOS.
What could be the problem ?
  • Misterixas May 11, 2010
    If you are trained enough in computer hardware, try to disconnect the power (molex) to one of these devices and see if it helps
  • 478 Answers
If you where tinkering inside and unpluged the floppy drive the wrong way this problem will happen
Posted on Dec 10, 2009
Operating system not found
Don't take this the wrong way, but start by making sure there is no floppy disk in the drive, CD ROM, or sometimes even a USB flash drive can cause booting to fail. If the boot order is such that those devices are checked before the HDD then you could see this message.
Also, if you have installed another Hard Drive recently then the BIOS can sometimes choose to boot from the wrong drive and you can get this error as well.
See this link for more information:http://h10010.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c00364979&lc=en&product=403835
Mar 14, 2012 | HP Compaq ProLiant ML110 G4 Server
Bootable device has not been dectected
When the PC cannot see a boot file/disk on either thehard disk or floppy drive it gives an error message "No bootable device. Insert boot disk and press anykey" First thing, check to see if the is a floppy disk inthe floppy drive, if so removes this disk. If there was no disk in the floppy drive then it maybe a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case andre-seat the data cable on the hard drive and also where it connects to themotherboard disk controller.
If it still gives this error message and the BIOS does not detect this harddrive, then the hard drive is probably faulty.
A further check on the hard drive, remove the hard drive and connect it to anUSB hard drive adapter and connect it to a working computer's USB port, if thiscomputer does not detect it as an external storage device then the hard driveis faulty.
To get the computer operating again, install a new hard drive in your computerand then install Windows on this hard drive plus the computer's devicedrivers and your programs.
Aug 24, 2011 | Intel D946GZIS Motherboard
Disk drive not reading disks. Light stays on all the time.
Turn the computer off.
Disconnect the ribbon-cable from the motherboard.
Flip it end-for-end.
Reconnect it.
Turn the computer on.
The light should normally be OFF, until you access the media.
Jan 18, 2011 | Panasonic JU 257 (JU257A827P) Internal...
How can I fix the "disk read error occurred" problem.
Hello omarnavarro4,
We need some more info on this.
What are the steps you taken beofore this error occured? Make sure you should not have any floppy/CD in your Floppy Drive/CD Drive.
You can go to BIOS and run the HDD Self test to check your HDD status.
Please inform us the model of Laptop/Desktop you using.
With regards
Pankaj
Sep 22, 2010 | HP Mini 1000 Netbook
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER
your system either does not detect a bootable disk, or the HDD has failed. Disconnect any floppy disk, USB storage devices connected to the computer and make sure the HDD with an OS installed is the primary boot device. If you get the same error, remove and reconnect the hard drive. If all else fails, try repairing or reinstalling Windows. If nothing works, you may need to get a new HDD.
Aug 25, 2010 | Compaq Presario SR1030NX (DW256A#ABA) PC...
Trying to boot from windows CD and not working
If its the full windows xp cd by booting it from the cd drive it will erase everything and ask if you want to upgrade or advanced install I think. Your correct in choosing the atapi cd-rom as 1st boot device. The cd should be in the drive on startup. IDE is the type of hard disk drive. I'm guessing the FDD stands for floppy disk drive which you might not have that many but you have that many bay windows available.
Put disk in, shut down computer, Start computer and it should give you the xp disk contents. Be aware of data loss though.
Nov 14, 2009 | Microsoft Windows XP Home Edition
Floppy drive light stays on all the time
please remove the floppy disk if inserted floppy drive...........or unplug the floppy drive .........or check the motherboard setting....some times light on due to reading floppy disk........please try it and rate it
Apr 11, 2009 | NEC (FD1231T) Floppy Drive
Please help me with my COMPAQ ARMADA 1700
plz check the hard disk cable if its ok then your hard disk may be bad.
Jun 11, 2008 | Compaq Armada 1700 Notebook
Sata hdd cant install
hi
go to your bios setup
go to advanced option your sata hdd is disable enable it.
if it is enable then boot your sys with bootable disk
go to dos mode.
type FDISK
Y
4 TO DISPLAY INFO OYUR PARTITION.
IF YOUR PARTITION ARE NON DOSE DELETE IT
THEN RESTART YOUR SYS.
U CAN INSTALL XP NOW.
Mar 25, 2008 | Mercury KVM800M Motherboard
Computer
Please provide more information about the error. Once we know what the error is all about, then we can surely work on it.
Oct 16, 2007 | Computers & Internet
EliteGroup 661FX-M Motherboard Logo
114 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
