Question about Canon PowerShot S30 Digital Camera
Nikon s30 black screen - Canon PowerShot S30 Digital Camera
How do I open the battery door?
With the display screen facing you, look on the bottom right for the door for the batteries. There's a tiny grey slide switch on the right side of that door with polk-a-dots that you have to slide toward the screen side of the camera. Hold the camera upside down and while sliding this switch away from you, you can slide the door to the right, which opens the battery compartment.
Jan 19, 2013 | Nikon Coolpix S30 Digital Camera White
How to install a Nikon Coolpix s30 Camera to a computer
You don't need to install anything.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Nikon Transfer or Picasa.
Dec 29, 2012 | Nikon Coolpix S30 10.1-Megapixel Digital...
How do i reset a navman s30
Insert a Needle or straightened out Paper Clip in the Side of your Navman S30..It,s on the left Hand Side ( while looking at the Screen) 7 it is covered with a Rubber Plug..There are 2 Holes under this Plug--1 is for an External Aerial & the other is the Reset Hole...
Hope that Advice helps
Oct 01, 2010 | Navman S30 Car GPS Receiver
Hi I am using Navman S30 car navigator. It has been giving me problems now. Every time I connect its charger, it turns on and gets stuck on the usb connection screen. I have changed its charger but I am...
Open your usb cable with a sharp knife; you'll find four different coloured cables inside: leave the red and black cable intact; cut the other two. Close your cable with some tape.
Your navman won't go into usb mode again, but it will charge your device
Dec 23, 2009 | Navman S30 Car GPS Receiver
Camera Screen black
Time for a new camera, the cost to have it exchanged by Nikon is near the cost to replace.
Jul 11, 2017 | Nikon COOLPIX S5 Digital Camera
Frozen screen on Gigabeat S30
I left the Gigabeat on until the battery ran out. It then turned itself off automatically and allowed me to re-charge the battery. When I turned the Gigabeat on, it again worked perfectly,
Jun 23, 2008 | Toshiba Gigabeat S30 MP3 Player
Black Screen
sir,u replace ur camera CCD
Apr 06, 2008 | Nikon COOLPIX S5 Digital Camera
Black screen
Did you accidentally hit the "DISPLAY" button (lower right corner) ?
Feb 15, 2008 | Canon PowerShot S30 Digital Camera
Canon PowerShot S30 Digital Camera Logo
46 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
