Question about LG WM-2277HW Front Load Washer
When to know if the motor is going out ?
On one or more spin cycles the dreaded LE code appears (Motor Overload) Checked all connections and reset andunplug etc. After a few minutes (empty) it codes again "LE" power down 24 hrs and replug, checked for restrictions, bearing seems good drains some agitation but no spin. Sounds like motor arching from rear of drum before several attempts to spin then codes. Motor spins free bearing feels good? On a normal wash cycle it fills does some agitation but a few minutes into the wash codes again LE. Can't find service manual or diagram never the less parts hard to come by also. Washer is two years old. Could of bought a car for the money spent on it, now trouble. Please help email me f1360@comcast.net Thanks
  • 5 more comments
  • Anonymous Nov 12, 2007
    LG wm2277 spins slower than normal and than stops and reverses direction.will not reach speed to drain properly.
  • eric bosman
    eric bosman Apr 15, 2008
    It is an easy fix. 99% of the time it is indeed the hall sensor.
    Go to sears on line and they have the parts on line. Type in the washer type and look for the hall sensor lokated in the tub section. attached to the stator ( ring with coils) sometimes called sensor assy.
    Order and replase. Very easy. 99% fix of your problem
  • ntms Jul 30, 2008
    LE error message. Drum is free and rotates easily by hand. Machine produces two distinct sounds - hissing "sssss" (the drum does nothing) and a muted "angry bear" sound, about 20Hz "ghrrrrrrr" (the drum revolves).... then the LE error message appears.
  • ntms Jul 30, 2008
    The Sears on line does not provide ANY sensor for this machine
  • Anonymous Sep 07, 2008
    LE code on and off for a year now and so we ordered a sensor but before we received it the power went out on it. No lights, noise or movement! Model WM2032HW Anyone with similar problem?
  • Anonymous Oct 19, 2008
    I have same problem. Our washer is just over a one year old....
  • cot10 Nov 01, 2008
    I had the same problem with my WM2032HW. This answer was the solution. Further details. Use 17mm wrench to remove the bolt for the rotor (hubcap like object). This was hard to do since the bolt was very tight and the drum turned with it. The rotor was hard to pull off. The manual makes it look like you turn counterclockwise, but this does not seem to be the case. Pull HARD. It has a ring of magnets that hold it on. For the six bolts inside use a 10 mm wrench. This circular ring will still be attatched by some wires and so swings down horizontal. It was helpful to have something supporting it while I unsnapped the hall sensor.
This fix below completely fixed my LG front loader issue of the drum "freezing" and "studdering" on fill and a lot of times giving a LE (motor overload) error. Bought position sensor as described and doing a load right now!
Wolfster you are awesome...you saved me probably $200.
Definitely sounds like the position sensor is faulty. I had this happen to my WM2277HB recently. Motor would start to turn, then jerk, hum, and not move, eventually gives LE code. Powering down, all the other tips had no effect. Very unlikely that the motor itself is bad if it still turns freely. You could confirm the stator wiring is OK by unplugging it and taking resistance readings across the stator terminals of the 3-pin connector (any combo of two should be 7-15 ohms). I was able to order the part from an online electronics supplier (www.mcminone.com, P/N 6501KW2002A, description is "sensor assembly") and several other places may have it as well. You can download a basic but somewhat helpful service manual here http://136.166.4.200/contents/Laundry/WM2277.htm that has some disassembly instructions and exploded view diagrams, explains the troubleshooting mode. Don't even bother calling LG or a service tech unless it's under warranty. If you're here you probably have some basic repair skills and toolsWhen to know if the motor is going out ? - 4.gif and can easily replace it yourself for about $20. My washer was about a year and a half old when the sensor went out, now it runs great again.
Posted on Dec 18, 2007
  • 4 Answers
Definitely sounds like the position sensor is faulty. I had this happen to my WM2277HB recently. Motor would start to turn, then jerk, hum, and not move, eventually gives LE code. Powering down, all the other tips had no effect. Very unlikely that the motor itself is bad if it still turns freely. You could confirm the stator wiring is OK by unplugging it and taking resistance readings across the stator terminals of the 3-pin connector (any combo of two should be 7-15 ohms). I was able to order the part from an online electronics supplier (www.mcminone.com, P/N 6501KW2002A, description is "sensor assembly") and several other places may have it as well. You can download a basic but somewhat helpful service manual here http://136.166.4.200/contents/Laundry/WM2277.htm that has some disassembly instructions and exploded view diagrams, explains the troubleshooting mode. Don't even bother calling LG or a service tech unless it's under warranty. If you're here you probably have some basic repair skills and tools and can easily replace it yourself for about $20. My washer was about a year and a half old when the sensor went out, now it runs great again.
Posted on Dec 04, 2007
Thanks to all of you for saving me money! The directions were complete from part number (6501KW2002A) to locating the part www.mcminone.com to the detailed directions as to how to replace the Sensor Assembly. My LG washer is a WM2032HW. It is 3 years old and up and running again! THANKS SO MUCH!!! I appreciate that you have taken the time to help someone like me who wouldn't otherwise have a clue!
Posted on Jul 12, 2008
    Problem Solver:
  • 5 Answers
I had the same error code along with the drum "freezing" up. The first unit that was delivered 2 years ago leaked water from the detergent compartment and they sent a second unit. I have only had this unit for 2 years and I am very disappointed in the LG product. LG was no help on the phone and I the only people that could service it were 45min away from were I live. I took the advice of a posting on this website that it could be a part called the sensor assembly (#6501KW2002A) and ordered it from an online electronics store (www.mcminone.com). To get to the sensor assembly, you first unplug and take off the back plate that has 4 small screws. Next, unscrew the big bolt in the middle and take off the hubcap looking part the bolt was securing. Next unclip the two sets of wires on the bottom of the circle you are looking at (the set of wires to the right are connected to the sensor assembly you want to replace). Next you will unscrew the 6 or so smaller bolts to take off the circular piece that the sensor assembly is snapped to. Take it off, unclip the old sensor assembly and clip on the new one – and reassemble. This worked perfectly for me and the part only cost $18 bucks plus shipping. When working, this product works well but I will not be purchasing any LG products in the future.
Posted on Dec 08, 2007
I have a WM2277HB that is giving me the LE code, everything that i have read says that it this the stator senor. is there anyway to make sure that is the problem? i put in a load last night and when the washer filled with water and i guess it was suppose to to start rotating it would give me the LE code about two mintues in it. the drum would not even rotate.
Posted on Jun 23, 2010
  • 298 Answers
Here's a link to order the original sensor assembly for this model (WM2277HS) from a major parts distributor:
LG WM2277HS Replacement Part Sensor Assembly
Posted on Mar 31, 2009
I will start by say thanks to Wolfster and diyrocks!
I have an LG WM2277HB. Bought it from Best Buy on 9/2005, and the 3 yr extended warranty. Called for service once last year, a hose was leaking through a hole that was rubbed into it. The service technician did not have a replacement hose, had to order one and then set up another service call. In the mean time I went to OSH, bought a high pressure hose and fixed it myself. I kept the other replacement hose from the service tech as a backup. At this time I had one daughter, so having the washing machine out for a week was a nuisance.
Last sunday, 12/14/2008, the washing machine LE error comes on, the day before by youngest son (I have two kids now) starts vomiting after every meal, and 3 months earlier the extended warranty on the washing machine expired (naturally). I feel very lucky to have found Wolfster and diyrocks on fixya.com. I ordered the sensor assembly (part #6501KW2002A) from lge.andrewselectronics.com, they are the Western USA authorized LG parts distributor. The part was $19.39, and 2 day shipping was $17.95 (priceless when one kid is vomiting all over the house). Following the directions I found here, it took me about 20 minutes to replace the part, and so far, after two critical loads, everything is running smoothly. I can only imagine what a service technician would want to replace, how long it would take, and how much I would be billed. I am very happy to have found all the information here. Thanks again!!!
Posted on Dec 18, 2008
LG front load starts fine but the motor makes grinding noises and turns only one way with resistance the other a couple minutes later stops with an LE message. is the moter gone? spins fine manually with no noise or resistance.
Posted on Oct 09, 2008
    Problem Solver:
Wm2032 left off for two days will complete wash on speed wash. Go to speed wash again, cycle only continues for 20 min, then LE error code. Any ideas?
Posted on Sep 29, 2008
Well here is how i fixed my lg LE error.
i just replaced the main pcu and all better now. it was not the hall sensor nore the rotor on the motor or the bearing or even the power soap
it was the main computer. for about 170 bucks and took about 5 min to change out it was all done and wroking fine
Posted on Sep 04, 2008
I had the same problem with the drum "freezing" up. I ordered the hall sensor from MCM on line like above and washer is working great now. The only issue I had was I ordered on Sunday and MCM didn't ship until Tuesday. I didn't get it til Friday. I should have just bought it in the town I live in and could have had it up and running sooner. My fault. This is a great web site and the first time used it. Thanks so much to the other posters and their detailed description of the problem they were having. That is what really helped me to fix the machine and save the money I did. Keep up the good work.
Posted on May 25, 2008
This solution worked for me and was a relatively easy repair. many thanks to this forum for sharing their experiences
Posted on May 19, 2008
How do you manage to unscrew the big bolt the middle of the motor assembly while the motor assembly is spinning?
Thanks
Posted on Mar 13, 2008
  • tom19020 Apr 02, 2008
    I just installed the "sensor assembly" as suggested by others here and my WM2032hw washer is working again.
    Thanks.
Diyrocks, dondon, Happynow had it right on.
I had the same problem with my 3 yr old WM2032HW.
I got my new sensor from repairclinic.com, their part # 126283. $22.90+8.47 for FedEX 2 day shipping.
6501KW2002A is also correct to search for.
In less then an hour I was up and running again!
Thanks for the great Help Guys!
P.S. It is a "Hall Field" sensor. It has to do with sensing magnetism and current flow.
Posted on Jan 18, 2008
Wolfster hit the nail on the head with this one!
I'd only add this:
That "Hubcap" looking thing is actually the outer part of the motor, the part that contains the magnets. so YES you are disassembling the motor! It's either the Stator or Rotor part you are first removing. I'm thinking Rotor, as it rotates. Secondly, that next part you are taking off is the copper (Stator?) part and the sensor clips inside of that. Yes, you have to take that part off too.
Other comment is you are trying to unscrew a bolt on a rotating assembling. The only way I could do it was to wack the wrench with a rubber mallet. Keep in mind this thing is torqued for a reason, that washer spins at high RPMs. You'll also notice the bolt has a thread lock compount on it. It would be probably wise to put fresh blue locktite on that bolt before you put it back in.
The other confusing this is this - if you look at the exploded view model of the washer, there's another part called "Sensor Assembly PN 6501FA2462C" that's something different. I kept second guessing thinking they sent me the wrong part. I further couldn't believe the Wolfster had me tearing the motor apart. I really didn't bargain for that.
Including swearing, fighting with my wife and moving the washer in and out, I'd say the whole thing takes 2 hours. Most could do it in 45 minutes.
Thanks Wolfster! No more laundry mat for me!
Posted on Jan 16, 2008
If the motor attempts to spin, but seems to seize up trying, it is likely the motor position sensor. I paid $75 to have it fixed, (the part was still under warranty). If LG would have shipped me the part I easily could have replaced this myself! Good luck.
Posted on Jul 27, 2007
    Problem Solver:
  • 18 Answers
Unfortunately LG washers have a direct drive motor fitted round the back of the drum, I think that is your problem
Posted on Jul 11, 2007
My front loader washing machine suddenly stop working at there is an LE sign
LG, the electronics and appliances conglomerate, manufactures a variety of high-efficiency washing machines. Whether you have a front- or top-loading model, your LG washer is equipped with an error-monitoring system. When the LE code appears in your display, it indicates a problem with the motor. The problem can be related to several different issues. In order to clear the error, determine which issue is at hand.
New Installation The LE error code may appear in an LG washer's display if installation issues exist. It indicates a miscommunication between the wash motor and the control panel. In most cases, you can simply reset the washer to solve the problem. Unplug your washer before pressing and holding the Start/Pause button for approximately five seconds. Plug it back in and set the washer to a rinse-spin cycle to see if the code has cleared. If the code reappears in the display, contact LG at the phone number in your owner's manual for assistance.
Thermal Overload Protection Your washer may display the LE code if the thermal overload protection circuit in the motor has been tripped. The feature is designed to prevent the motor from overheating and causing permanent damage to the washer. To clear the error code, the motor must cool down. Allow the washer to sit for approximately half an hour before restarting the cycle. If the code reappears, the motor may have an issue that requires a service call. Unplug your washer and contact LG.
Excessive Suds If your washer detects excessive soap suds in the drum, the LE error code can appear. Typically, excessive sudsing occurs when you use too much high-efficiency detergent or a detergent that's not specifically high-efficiency detergent. Always follow the guidelines in your owner's manual and on the detergent label to determine what type of detergent, and how much, to use. To get rid of soap suds in the drum and clear the code, unplug your washer and let it sit for a half hour so the suds can dissolve. Plug the washing machine back in and turn it on, hitting the Spin Speed button and selecting "No Spin." Press the Start/Pause button to turn on a drain only cycle. When the cycle is completed, remove the load from the tub. Start a rinse-spin cycle to clear away any residue. You may need to repeat the cycle to remove all of the suds.
Load Issues The LE error code can appear in an LG washer's display due to certain load conditions. If you are washing a large load, don't choose a gentle cycle like Delicates, Hand Wash, Perm Press or Wool/Silk. Reserve them for smaller loads. To reset the washer, unplug it and press the Start/Pause button for five seconds before plugging it back in. The LE code can indicate that the washer has been overloaded; large loads and bulky items can strain the motor. Remove a few items from the washer to reduce the load size and restart the cycle. If the code appears again, let the washer sit for a half-hour so the motor has time to cool down before you restart the cycle.
Feb 28, 2015 | Washing Machines
LE error (checked stator and replaced HAll sensor already)
If the control board does not receive the input it will not operate does the door lock? However:
The attachment shows how to diagnose and repair a failed hall sensor, the usual cause of
an LE error code.
DO NOT replace the stator until the hall sensor has been tested. 98% of LE error codes are
caused by failed hall sensors.
[DD motor SVC check process ]
Pre Check
1) Gentle wash cycles, such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for
smaller loads. Because these cycles are more gentle in tumbling and spinning, putting too much in the
drum can register an issue with the motor. Remove items, reset unit and test with a Rinse/Spin cycle.
2) Don't replace the PCB when the hall sensor is replaced.
Check the hall sensor as shown in the new process.
O have a file I can send but can not upload here if you want it, contact me melissamaemartin@yahoo.com please put hall sensor in subject line. Thanks
Mar 28, 2014 | LG WM-2277HW Front Load Washer
LG wm6042h washing machine. LE code for motor overload.
This is normally a common problem on LG tromms. The cause of this error code is as stated "motor overload" . The most common fix to this problem is replacing the hall effect sensor. But.... If you weren't getting this code before replacing the bearing I would recommend checking the sensor to make sure it's plugged in correctly.
I’m happy to help further over the phone at https://www.6ya.com/expert/george_083af2f0afc0328b
Dec 31, 2013 | Washing Machines
Have LG WM2277 with constant LE code. Already tried resetting by unplugging. Already replaced hall sensor. Still LE code. Only use HE detergent. Machine is level. Have checked all internal...
If your husband has already replaced the Hall sensor, it's most likely going to be a Stator problem. You can Ohm the stator out, it should read between 5 and 15 ohm's. If not, then you need a new Stator assembly, which also comes with a new hall sensor, typically. These Stators fall under the 7 or 10 year direct drive warranty, if you have proper date of purchase paperwork and model+serial number.
Mar 06, 2011 | LG WM-2277HW Front Load Washer
What does code LE mean? The washer stops and LE appears
Code LE signals an overload to the motor. Wait 30 minutes and restart the cycle. If the code is not released, you need to call a service technician.
Jan 07, 2011 | LG WM2487H Front Load Washer
Trying to do a standard wash -- washer does not enter spin cycle -- the display reads "LE" -- door remains locked
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Aug 18, 2010 | LG WM-2432H Front Load Washer
Washer
Greetings jannd,
The message "LE" can indicate that the thermal overload protection circuit in the motor has been tripped. The remedy for this can be to allow the washer to stand for 30 minutes to allow the motor to cool, then restart the cycle. If the LE error code still appears, unplug the washer and call for service. Keep in mind that this unit carries a 7 year warranty on the motor also.
I hope this helps!
Best regards,
Dorothy
Go Ahead. Use Us.
May 11, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Samsung p1253
LE means locked rotor or overload in motor. Check for binding or mechanical resistance. check motor winding resistance. Also check 3 pin connector in motor harness, harness between stator and main board or Hall Sensor on motor could be defective
Dec 28, 2007 | LG WM-2277HW Front Load Washer
LE Problem
An LE Error Code is indicative of a ?Locked Motor? or ?Overload in the Motor?. This is rarely caused by a problem with the machine and in most instances resolvable over the phone. Q1:Are there suds in the drum? -->Oversudsing is the main cause of LE error codes. Using non-HE detergents or too much detergent will cause stress on the motor. Oversudsing can also cause leaking and odor. Follow the steps below to resolve an LE error code caused by oversudsing. --> Step 1: Unplug the unit and let machine sit for 30 minutes to allow suds to dissolve. Step 2: Press the POWER button to turn on the washer. Step 3: Press the SPIN SPEED button to select ?No Spin?. Step 4: Press the START/PAUSE button to begin drain only. Step 5: After cycle is complete, remove the items from the machine. Press POWER to turn on, RINSE&SPIN button, then START/PAUSE. Repeat, if necessary. This will remove excess suds and light residue from drum. Do this until no suds are seen in drum. Q2: Is this a new installation? -->In new installations, the code can appear simply due to a miscommunication between the control board and the motor. In this instance, the unit will simply need to be reset, much like rebooting a computer. Unplug unit, press and hold start/pause button for 5 seconds, plug unit in and test with a Rinse/Spin cycle. Q3:Is a large load size in a gentle wash cycle? -->Gentle wash cycles, such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because these cycles are more gentle in tumbling and spinning, putting too much in the drum can register an issue with the motor. Remove items, reset unit and test with a Rinse/Spin cycle. Q4:Is the washer overloaded? -->Single bulky items (comforters) or extremely large loads can add extra weight to the drum which stresses the motor. Remove some clothing and restart. If it doesn?t work, unplug unit and let it sit for 30 minutes to allow motor to cool. Then restart the cycle.
Jun 09, 2007 | LG WM1814CW Front Load Washer
LG 1285
Lg washers used to carry a 3 year warranty.check warranty as requires a new stator.
Jan 05, 2007 | LG WD-1280FHD Front Load Washer
LG WM-2277HW Front Load Washer Logo
2,969 people viewed this question
Top LG Washing Machines Experts
Marvin
Marvin
jimorris77
Paul
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
