Question about Mackie SRM-450 System
Makie SRM-450 active loudspeaker stop working after short-circuit
I had unmounted bass speaker and its cables touch each other wile powered on. Fuse went of. First I tried bridging fuse poles with screwdriver but no lights turned on, then I replaced fuse but keep burning it, seems there is a short circuit somewhere. I visual checked motherboard and found no sights of burning elements. Any idea what can go off after such things I did?, I would appreciate any inputs other than the obvious "send it to technical service" Regards
    Champion:
  • 243 Answers
Your Power Output Devices got fried, if you look the pcb there's an array of devices attached to the main heatsink with screws, Q34/Q35, MJE2955/MJE3055, check them as a starting point, hope this helps.
Posted on Nov 08, 2013
SOURCE: Signal light stays on, no sound output
T14 is part of the +15v power supply that feeds the input board.
It is actually a transistor.
If this is the only problem on the board, then this transistor could be resoldered back on but you will have to make sure it tests OK and it attaches to the heatsink the same way it came off. ie make sure it is electrically isolated from the heatsink
It seems if there is no fuses blown on the power amp board you might be one of the lucky ones.
In my opinion this amp is a clever design but is under-engineered for robustness
Posted on Sep 16, 2008
mrwtech
  • 59 Answers
SOURCE: I have a pair of
you have one of two problems.1) the woofer is blown(most likely) or 2) the crossover is fried(rare). Take the woofer out and press on the speaker cone(softly). If there is a scratchy feeling when you move it or if it doesn't move at all, you'll either need a new woofer, or get that one reconed.
good luck.
Posted on Dec 04, 2008
  • 4 Answers
SOURCE: drivers burn
We sell a replacement diaphragm for your speaker. Simply replace the bad diaphragm with a new one.
http://www.soundspeakerrepair.com/speaker-parts-cp/SRM450-DIA/DIA-Mackie/Mackie/
We ship worldwide every day.
Posted on Jul 21, 2009
  • 133 Answers
SOURCE: I have Mackie srm 450 original the speaker
When it goes off, try pressing gently on the speaker membrane (you'll probably need to remove the protective mesh to do that).
If the speaker comes on for an instant or so when you press the membrane, then the cause is a broken braid wire at the back of the speaker (it goes from the connection terminal on the speaker itself to the speaker cone where it is connected to the speaker coil wire and glued to the cone to keep it firmly in place).
If this turns out to be the case, the braid can be resoldered at the point where it is damaged / broken (you need good soldering skills to do it, also the braid needs to be cleaned well which is a bit tricky because of its structure, and solder won't stick to it well if it's not clean).
The solder point should be firm, but as small and short as possible because the braid needs to remain flexible at all times since it moves when the speaker is operating.
An alternative to braid resoldering is to replace the speaker, but there may be speaker repair shops around where you can get it fixed.
The problem may as well be something else, the above is just one of the things that you can check and possibly fix by yourself.
Regards
3rq8 (Triarcuate)
Posted on Sep 11, 2009
Testimonial: "sounds feasible will look into that soon altho away for some weeks yet so cant try immediatly TS"
  • 4234 Answers
SOURCE: hello there i have a
The most common cause of this is a blown horn. A replacement can be ordered from Mackie directly. Remove the screws that hold the plastic horn in place. At the rear of this part will be the tweeter assembly that unscrews from the horn. This needs to be replaced.
Another possibility is that the tweeter driver has broken from the horn itself and is inside the cabinet. Remove the horn and you may find that the aluminum part has broken. Replace the horn which comes with that part and you should be fine.
Dan
Posted on Jan 12, 2011
My srm - 450 the light is busted where can i get one ?
Any electronics components store.
I replace mine using a blue led from my kids broken toys. Remember leds have polarity, check it before. And always power off the speaker, I did blow some motherboard circuits while testing led and an unplugged horn cable did breakdown voltage. Shame on me
Oct 06, 2014 | Mackie SRM-450 System
Power supply circuit diagram
There is almost certainly a reason the PSU has blown, these are not very reliable units and the amp has probably gone and taken the PSU with it. You are better off taking it to a dealer and getting it fixed. If there is no power on the seecondary and there is no short the transformer must have blown (assuming you're not trying to check with a DC meter)
Jan 19, 2014 | Mackie Srm450v2 Srm450 Srm 450 V2 Active...
My Mackie SRM-450's both make excessive white noise, one of them crackles quite loudly.
This type of active speaker by Mackie has a issue with operational amplifier ic's inside, they are just those little black things with 8-pin soldered to the pcb, you may have some of them damaged, because of the erratic operation of the units, let me know if i can help more.
Jul 04, 2013 | Mackie SRM-450 System
Main Speaker Not Working
IS there a circuit board inside that speaker? You are correct about the general loss of sound quality that usually occurs with speaker failure. Best way to check is with a meter or a scope
May 04, 2013 | Mackie SRM-450 System
Need spec on Mckenzie loud speakers 12'' dual cone 85 watts rms
What\'s the question, are you asking about eyebolts, SRM 450 or McKenzie speakers?
Let\'s assume speakers. These are quite nice vintage speakers and were fitted in a number of units back in the day. Depending on the use they are going to be put to you\'ll need to find the dimensions of similar boxes for the same use and speaker size from (ideally) makers who used these speakers or something similar. It\'s going to be a bit suck it and see and will also depend on if you are looking to use an infinate baffle, sealed or vented enclosure.
Try Speakerplans com
Sep 23, 2012 | Mackie Pa-a1 Eyebolt Kit for Mackie Active...
Active Speaker won't power up
If the speaker is OK, check the audio output components like ICs and transistors.
Jun 05, 2012 | Mackie SRM-450 System
Problem with the Mackie SRM 450 v2
It would be very unusual if the blue LED is burned out. They should last a million years. I suspect the power supply has a problem.
Apr 03, 2017 | Mackie Srm450v2 Srm450 Srm 450 V2 Active...
Mackie SRM 450, the main speaker has stopped working but the tweeter is OK, there is nothing coming from the speaker at all, no hiss, or clicks.
It could be 2 things:
*Blown Speaker or,
*Fried power amp output stage of woofer, since this speaker operates as a bi-amplified system it has separate amps for woofer/tweeter...
Aug 17, 2011 | Mackie SRM-450 System
Srm 450 stop working suddenly
Fuse OK? Is there secundary voltage present?
Nov 07, 2009 | Mackie SRM-450 System
Mackie SRM-450 System Logo
91 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
