Question about Miele S514 Solaris Turbo Plus Vacuum
Miele vacuum cord reel question
Dear reddevil6,
My Miele S514 Solaris Turbo Plus seems to have a defective cord reel. It won't start up until I wiggle the cord. I have opened it up to figure ou the part number and found the following: 5240301/03. It seems that online parts stores have a similar, but slightly different part#, e.g. 5240304. Would you happen to know if this will work on my model or if there is a cheaper fix like just replacing the cable? Thanks a lot!
Matt matt.jost@gmail.com
I had to take off the cord reel and clean the contacts inside it. I also bent the contacts out since they tend to wear down after time.
Posted on Jun 07, 2009
Miele S514 Turbo red light on. Dismantled and cleaned. Motor checked and no resistance. Circuit board? Can it be be replaced or by passed?
If there is a circuit board between the cord and the motor it is certainly replaceable. Unfortunately my suppliers don't have schematics for the Miele models. You might try the Miele website, if there is one, or call your local repair shop to see if they service them. Sorry I can't be more help.
Jun 14, 2014 | Miele S514 Solaris Turbo Plus Vacuum
How to reset the Miele Type HS 05 Model S514?
Hi bud
sounds like ps3 has shut down as the gpu/cpu has popped of the board due to over heating and the use of lead free solder.there are places you can send it for repairs or you could have a crack at if with heat gun and liquid flux if your brave. Google it for a tutorial
hope this help you out
Jun 10, 2014 | Miele S514 Solaris Turbo Plus Vacuum
Miele turbo s514 power
If it has no suction take bottom peice off take out brush roll then run clothes hanger through dust channel to clear any blockage if none there its in your hose
Mar 27, 2013 | Miele S514 Solaris Turbo Plus Vacuum
My turbo plus does not turn on when plugged in. This is the first time this has happened. Any suggestions?
Check the power switch, plug cord and vacuum wiring. A open circuit will cause that and you need a continuity tester to test it. Once you find the trouble part, replace it with the same size and rating. A dent or vent wire will cause not to flow the current and voltage so check it.
Thanks for asking.
Jul 13, 2011 | Miele S514 Solaris Turbo Plus Vacuum
Miele Solaris won't turn on after falling down 1 stair.
there is no reset on this model. look @ your miele info & it shows you where it would be. I just had to look for mine when it would'nt start. mine ended up being cord winder kink affecting motor.
good luck
linda
Mar 15, 2009 | Miele S514 Solaris Bagged Canister Vacuum
Miele solaris turbo plus S514 will not start in live outlet
The reason why the vacuum will not start is because of the cord winder. They are pretty tricky to repair yourself. A service center could probably fix it for about $50.00. It has been a while since I have worked on one of these but I think the screws are under the switch and maybe the filter.
Jan 19, 2009 | Miele Vacuums
Miele S514 Solaris Electro - won't turn on
I don't have the exact same model as you guys, but maybe my situation is similar to yours. My Miele Silver moon model won't turn on one day. I took it to a Miele authorized repair shop ( they all offer free estimate on finding the problem first, then they will tell you what the repair cost will be). They said my vacuum cord reel shim was damaged. The damage was caused by over stretching the cord while I vacuumed. According to them the shim is kind of like a clip that holds the cord inside the vacuum. When the shim is damaged, the cords are pulled apart and electricity can no longer pass through. That would expalin why it won't turn on. The repair cost was not too bad, it costed forty-six dollars. I hope this helps.
Jun 06, 2008 | Miele S514 Solaris Electro Plus Vacuum
Miele Solaris Electro Plus will not turn on
I was using my Miele Solaris Turbo plus to **** the air off the Space Bag. Now I have the red indicator on and the vacuum cleaner won't turn on. Please help. This is my favorite vacuum cleaner!
May 17, 2008 | Miele S514 Solaris Electro Plus Vacuum
Miele Solaris height adjuster arm won't snap back in
Maybe this picture will help, put the pieces together, then it sits directly under where #230 in the pic.
Mar 25, 2008 | Miele S514 Solaris Turbo Plus Vacuum
Miele S514 Solaris Turbo Plus Vacuum Logo
955 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
