Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Access Service menu
I have a RCA D52120 Chassis# CTC211A.
How to bring up the service menu?
    Sergeant:
  • 233 Answers
Hey there!
Its really easy to do, but write down any settings before you go changing them..
1. Turn off tv.
(use buttons on tv for this)
2. Push volume down and channel down both at the same time, and hold them for about 10 seconds, or until the tv turns on.
Posted on Jan 23, 2009
I think my convergence is off. Just the green and red seem to look off. I do not know how to adjust each color. When you go into the convergence setting under the menu and it just does like an automatic...
You will need to know How to Enter the Service Menu to bring up the Convergence Pattern in order to adjust the Convergence,another thing is it depends on which chassis you have RCA had bought the right to use the name Zenith, when in fact these TVs had RCA Chassis and not Zenith Chassis
Remove the back to Tv, Make sure TV is unpluged and look to see if you have on a board Located on the right hand side
2 Big Black ICs they will have Part number on them example STK392-570 these are your convergence ICs that need to be replaced.You can exchange this board for new board at Zenith exchange moduels 1-800-632-6637
But if you have the RCA Chassis then you will have 2 bottom boards one on the Left hand side will be the Deflection board it will have the FBT flyback transfomer on it and their is 2 Ribbons that connect to the board on the right handside which is the ssb board that has your cable/AV input jacks on it.and their will be 2 boards above the 2 bottom boards if these are the boards you have then you can with Tv Off Press and Hold vol- and ch- wait untill TV comes on,release buttons and then you should be in the service menu to adjust convergence manually. R/G/B
For these chassis PTS rebuilts boards 1-800-844-7871
Jun 26, 2011 | Zenith R57W46 57" Rear Projection...
Rca d52120 need more green and red color
sounds like the Blue CRT drive has an issue which causes the blue to become dominate thereby limiting the red and Green CRTs from projecting normally. Is your screen full of blue?
May 23, 2011 | RCA D52120 52" Rear Projection Television
RCA 52" model D52120 i have the following codes
Sorry we are not able to help you with your problem
Dec 05, 2010 | RCA D52120 52" Rear Projection Television
How do I access RCA HDTV D52W23 Service Menu?
Shut unit off. Wait 10 to 15 seconds then press and hold volume down and channel down together for 10 to 15 seconds. This will get you into the service menu.
Apr 07, 2010 | RCA D52W23 52" HDTV CRT TV
RCA P60920BL wont power up makes clicking sound
This is a chassis PTK195 and acommon fault with these sets, that causes the symptom you describe, is the flyback transformer goes bad.
If you're at all familiar with electronic repair you could start checking there (and horizontal output transistor shorts). If not have an RCA approved warrany repairer give you an estimate/service call.
Note: the good thing about these sets is the chassis is very common and easily removed for service (without bringing in the whole set.) .
Usual cost to repair flyback/ dead set symptoms $200-$350.
Nov 24, 2009 | RCA P60920BL 60" Rear Projection...
RCA d52w26 Field service menu
RCA > HD52W66
itc222a chassis
Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec.
http://home.austin.rr.com/doctorjoe/ITC222align.pdf
Oct 03, 2008 | RCA HD52W59 HDTV Projection Television
Is Repair worth trying?
its smart to try to DIY if its only the sound that was lost.
but be very careful as such appliance have very intricate design. always be careful.
you can start by troiubleshooting the speaker itself then work down going to the wires of the speakers then the audio chip.
if you still have some questions, just post them here.
Mar 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52130 CHASSIS CTC211A PROBLEM
Do you hear a click when you try to power it up? If no you may have a blown fuse. But if the fuse is blown chances are a short has caused that condition. Check the fuse to see if its blown and let me know and I will try to help you out with it.
Mar 27, 2008 | RCA D52130 52" Rear Projection Television
Service Menu RCA HD56W58 56" TV
http://www.hdtvoice.com/voice/showthread.php?t=24248
go to http://www.thomsonnetwork.com
Click on "publications ordering" (in the list on the lefthand side of the homepage)
Click the box for service information. Enter the model number (or click the chassis button and enter the chassis number).
In the list of documents you can purchase for $40 ESIATC32X -- the service manual on CD for your set.
This disk will have the info you need.
If you do decide to purchase it (and I highly reccommend you do so), send me the alignment chapter and I would be happy to post it for others who have the same set on my homepage.
Jan 28, 2008 | RCA HD56W58 56" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
216 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
