Question about Vtech V2656 Cordless Phone
Change frequency on vtech cs 6419
Needs to be 2.4ghz
Can I change the frequency of my LS6225
Before I answer, why would you wish to alter the frequency?
Aug 25, 2014 | Vtech Lands Phones
How do I change frequency on my vtech dect 6.0?
You cannot. The phones use broad spectrum transmission with auto select and a key signal that is sent when you pair the two.
Aug 10, 2014 | Vtech DECT 6.0 Cordless Phone with Digital...
Unable to Call, Try Again
The phone line is supplying a certain amount of power. If you open many parallel channels the power is distributed among active phones. The more sets there are the less power each one gets.These are the physical principles behind the limitations on the number of ringers a single line can activate (Ringer Equivalence Number)
As to the need to be using 3 or more sets on the same line and at the same time, I have a hard time understanding that.
For a landline, your phone company can activate 2 numbers, as it can enable A/DSL on your phone line.
Dec 18, 2013 | VTech Communications CS6409 - cordless...
How to set voicemail into vtech CS 6419 model phone, nothing mentioned in the manual. thanks
There's nothing in the manual for the very simple reason that the CS6419 isn't a voicemail system. To setup your voicemail system, please refer to the documentation for that system.
Mar 20, 2013 | Vtech Lands Phones
How to set the voice mail in a vtech CS6419 model phone? thanks
The CS6419 isn't a voicemail system. To setup your voicemail system, please refer to the documentation for that system.
How do i change the frequency on a Vtech t 2340?
While on a call, press the CHAN button near the lower left corner of the T2340 keypad to change channels. See page 9 of this manual for details.
Jan 13, 2013 | Vtech VT-T2340 Phone
Change frequency
Since you declined to specify the model of your VTech system, enter it into the search box here to download a copy of the manual.
Dec 13, 2011 | Vtech Lands Phones
When I turn on my Philips lx8500w dvd player my wireless internet stops working, what may be the problem?
the lx8500w uses the same frequency as the wireless (2,4Ghz). I bought the same system, it's ********. Just problems and after 2 years it doesn't work anymore (goes to standby after 1 hour or so). Try to change the wireless channel. Or buy another home cinema...
Mar 19, 2010 | Philips Home Cinema system DivX LX8500...
Panasonic KXTG2344 Phone 2,4ghz malfunction with microwave
You can change the channel used by the phone in the settings, but the better option is to make sure the charger base is nowhere near the microware.
Also, make sure that the microwave and the charger base are NOT plugged into the same outlet. I would even try a different outlet than you are using now as interference would definitely pass through the line.
Dec 02, 2009 | Panasonic KXTG2344 Cordless Phone
Vtech V2656 Cordless Phone Logo
23 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
