Question about Kodak EasyShare Z612 Digital Camera
Kodak z612 camera now underexposes all flash photos, and overexposes all outdoor photos.
    Genius:
  • Kodak Master
  • 1,099 Answers
Pls. reset. the cam: Take the batteries out for longer than 30 sec and insert them again. This will reset any previous settings that might be on the cam.
If this doesn't work I'm afraid it might be a repair.
Kodak Digital Imaging Support Centre can be contacted on any of the numbers below:
UK 0870 243 0270
International Toll line +44 (0) 131 458 6714
Posted on Oct 12, 2009
    President:
  • 2,976 Answers
Check your settings. You probably have something set on manual control. Just set the camera's settings for automatic and you should be good to go.
Posted on Jan 23, 2009
Overexposed outdoor pictures
I'm not familiar with this particular camera as I'm a keen photographer only, but usually you have chosen either to fast an ISO (i.e. 800 or 1600) or you have too much light entering the lens (sensor) in other words the automatic exposure is turned off manually or there is a fault, check first the menu options. as a rough guide you should have the ISO set around 200 - 400 the aperture set around F6.3 to 8 with a shutter speed at 200 ish, all this depends on the brightness of the day but if you have auto exposure on which every new camera would have these days then that is all taken care of. GOOD LUCK
Nov 24, 2009 | Kodak EasyShare Z612 Digital Camera
Horizontal banding on kodak z612 photos
if theres always a lines on the your photos it means that the camera is already defective, I strongly suggest Do not Dismantle the Lens, what you can do is to call kodak toll free 1 800 235 6325 and ask them to send your camera on their Repair center., Gudluck!
Oct 11, 2009 | Kodak EasyShare Z612 Digital Camera
MY camera seems to be overexposing all pictures taken , so that I can not take outdoor photos at all and can only take photos inside if I close the drapes and block all natural daylight. It seems as if...
Hello, the problem that you explain could easily be caused by an improper "ISO" setting. When you go to your camera's menu, look for the ISO setting and put it back on "auto". It's probably on 800 or higher now, which will cause everything to be overexposed.
Oct 03, 2009 | Kodak EasyShare Z612 Digital Camera
Outdoor images overexposed
hi, its a problem of lence flap,it is in the lence berral , just change the lence flap and your camera is ok,remember if you are a tecnition then try your owen
Aug 27, 2009 | Sony Cybershot DSC-T200 Digital Camera
Kodak Z612 won't turn on
while you turn try and turn it on slow twist and pull lens outwards(gently while power on /off) and it will retract back in and power on.Work perfectly after.
Enzomatrixx Da Gr8 One
Apr 23, 2009 | Kodak EasyShare Z612 Digital Camera
I have a Z612 which will seems to overexpose outdoor sunlight pictures. Video is ok, indoor flach pics ok. I think the problem was caused checked luggage being slammed around. Any ideas?
Many cameras have an exposure adjustment of increasing/decreasing amount of exposure (usually marked as -/+) Yours is probable set with to much overexposure. This is a setting you can change.
Apr 12, 2009 | Kodak EasyShare Z612 Digital Camera
Time for new flash??
the camera's light sensor or metering system, for correct flash exposure is no longer working, that's why your shots is either black or white (overexposed or underexposed) the flash firing has loose its control because of the defective sensor, it now only depends on the charge current of the flash capacitor. If you'll wait longer time the charge is maximum picture result will be overexposed(white), and vice versa, less charge, dark result, have the flash assy replaced. Daylight no problem, it doesnt use the flash circuitry, thanks
Jul 28, 2007 | Sony Cyber-Shot DSC-S60 Digital Camera
Pictures are underexposed
When you are photographing scenes with mostly light objects (for example, snow, water, and sand), the picture is usually underexposed (darker than it really is). The camera meter registers the brightness of the scene and tries to set the camera lens and aperture for an exposure based on average brightness levels (18% reflectance) causing it to underexpose, as in the following picture. When you are photographing scenes with mostly dark objects (for example, shade, shadow, and overcast skies), and very few light objects, the camera may overexpose the image, causing it to be too light. If you have a flash on your camera, you can compensate by adding "fill flash" for some extra light. If your camera has an exposure compensation adjustment, you can increase or decrease the exposure to correct for these exposure problems. Increase the number to make the image lighter, and decrease the number to make the image darker. You may want to try a series of shots with different exposure compensation adjustments to get a feel for how much difference these adjustments make.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Kodak EasyShare Z612 Digital Camera Logo
102 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
