Question about Gateway HD1900 19" Monitor
Monitor flickers then shuts off - Gateway HD1900 19" Monitor
P2770h monitor flickers. progressed into the monitor shutting down after a few minutes. the monitor power on light flashes in a slow dim.
Is this happening while your are playing games or you are doing a specific task? If not try to change your connectivity cable (HDMI or DVI)
Aug 28, 2013 | Samsung P2770H SyncMaster Widescreen LCD...
Veiwsonic VP2365wb backlight flickering
If it's not under warranty, buy a new one from newegg dot com.
Mar 27, 2013 | ViewSonic VP2365WB 23 inch LCD Monitor
Monitor flickers on start up after shut down
The symptoms you have are very common on this model. The capacitors in the power supply are beginning to fail and as this happens they can not filter the power correctly and you get the flickering until the unit stabilizes. As time go by the issue will get worse until the unit fully dies. The repair is very easy, you will just need to replace 6 capacitors on the power supply board. Here is a link to additional information on repairing this model.
http://www.ccl-la.com/catalog/product_info.php?products_id=229
I hope this helps,
BuddyMc
Sep 06, 2012 | Samsung SyncMaster 203B LCD Monitor
Monitor color
replace signal cable your problem will be solved if persist then open the monitor and find out the dry solder and clear it
Apr 12, 2010 | Dell E173FP 17" LCD Monitor
Reddish picture when power on, screen flickers and then shuts off after 1 or 2 minutes
The red or pink color indicates one of the backlight tubes is failing. Only solution is to replace the bulb or replace the unit.
Monitor Mike
Jan 17, 2010 | HP L1706 17" LCD Monitor
Samsung SyncMaster 920nw suddenly went black now squeaks/flickers
The 920nw did have a 3 year warranty on the unit but they will be out of warranty now. The flickering power light is an indication of a failure in the power supply board. When the board fails it can't start up correctly and the power shuts down over and over so you get the blinking light and no display. This is a very common failure point on all LCD monitors after a few years of use. There are parts called capacitors on the power supply board and they filter the output power. When they fail the power is not properly regulated and the power supply shuts down and tried to restart so you get the flashing. Here is a link to a repair guide that will show you how to dis-assemble the unit and then what to look for and replace to get it back up and running again.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
The repair guide has pictures and videos to guide you through the repair.
I hope this helps, if so please rate my solution.
BuddyMc
Nov 14, 2009 | Samsung SyncMaster 920NW Monitor
Gateway HD1900 19" Monitor Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
