Question about NorStar Computers & Internet
How to recover programming password of norstar syatem when this password is changed by any one.
Dr5 8*24 ds
I'm trying to change the display names for each extension but when i try the **266344 a user id option pops up....not for a password. What do i do?
Try pressing the FEATURE button then, **266344. On some Norstar phone systems there is also an Admin level of programming that is useful if you only need to change the names or the time. To access Admin programming, press Feature**23646(spells admin on the dial pad). Then 23646 for password.
Feb 24, 2011 | NorStar T7316E Corded Phone
I have mistakenly changed the password to the CCR log in for my Nortel Norstar phone system.. Is there a work around or reset option available so that I can access the system? I need to change the greeting...
to reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000.
Apr 13, 2010 | NorStar Startalk Flash 2 Phone
Norstar 7324 time change
Programming should be done from the M7310, M7324 or the T7316E set. Administration access code: Feature * * 266344 which also is Feature * * config.
If asked for a password enter 23646.
When in programming2.gif just press the next button(lower right arrow) until you see what you want to change. Then press show ( top right arrow) ,then change if you want to change it. If you pass it, just press back (lower left)
Example: To change the Time & Date Press next until you see Time & Date. Then show Then change Then change again, change it if you need to, Then next again until you see what you need to change. For example; only the hour needs to be changed for day light savings time. Just press next until you come to the Hour. Then Change it. Then press release RLs when your done.
Sep 21, 2009 | NorStar Meridian M7310 Phone
Can you change the password on NORSTAR M7310? I have the restricted line (long distance phone call) and I would like to remove that restriction. Can you help me? thanks Brandon
Yes u can change the password.
Go to system programming by Fetature **266344 password will be 266344.
Keep pressing next until display shows restrictions.
press show there it will ask for COS password press show there u press 00
u will get a pasword press change as per ur requirement.
Jun 26, 2009 | NorStar M7310 Corded Phone
I cant seem to programme the meridian m7324 when i put in the password **23646 it does nothing it wont even go to the password bit just freezes and does feature time out , i cant change the names or the...
I think you need to enter the password **266344 (CONFIG) first, then **23646 (ADMIN). The first is the password that gets you into programming mode and the second is the password for the programming level you want.
Apr 23, 2009 | NorStar M7324 Telephone
Norstar CallPilot 100: need to change the time within the system to reflect daylight savings time
the time change goes off the system time to change system time press feature **7463 enter the admin password then press change and enter new time
Mar 09, 2009 | NorStar CallPilot 100
Password
The Default ADMIN password is 23646 and to get into programming you press " Feature * * 23646 " then the password. Good Luck, let me know if you have any problems .....Mitelmike
Nov 03, 2008 | NorStar M7310 Corded Phone
Norstar M7324 programming password
The password should be 266344 after entering * * 266344. Let me know how it goes ....Mike
Aug 08, 2008 | NorStar M7324 Telephone
Computers & Internet Logo
22 people viewed this question
Top NorStar Computers & Internet Experts
Computer Links
Alun Cox
Are you a NorStar Computer and Internet Expert? Answer questions, earn points and help others
