Question about Bissell Vacuums
Dont no were my water and sop lines go. - Bissell Vacuums
  • Official Brand Answer
  • 315 Answers
You may want to contact a BISSELL Authorized Service Center to have a qualified technician inspect your machine.
Here's a quick link to locating one. http://www.bissell.com/service-centers/?cid=ccsocial
Posted on Jan 14, 2013
I need a manual for a Sop-vac 1.5 gallon.
Have a look at this page and if it matches your product, you can click "user manual" on the right hand side to download a PDF version of the manual.
Shop Vac 1 5 Gallon 2 0 Peak HP All Around EZ Wet Dry Vac
Sep 19, 2017 | Vacuums
Electrolux Vacuum Rug & Hard Floor Brush Flip Tool. Defective O-ring in elbow part. Where can I get a replacement?
go to a vacuum sop/ repairer and make inquiries
probably find that you have to buy the head new
Feb 21, 2016 | Electrolux Vacuums
Hoover floormate will not dispense solution
this is the original Hoover Floormate, and may have a few different things that may be wrong. First check the fresh water tank is seated or installed properly. Second, it may be the pin on the actual unit itself that is not pushing in the plunger (located on the water tank) all the way to release the solution. Check for clogs above the brush block assembly the small holes may be plugged with dried sop solution.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Sep 29, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
It fills up with water in the reserve to the top and flows onto the floor
There is a float switch that should stop the water from picking up when the regular reservior fills. I dont know what machine you have, but assume it is a Rainbo or a Black and Decker. You will need to replace the float switch to repair the problem Go on line and google your machine do it yourself repair manual. You can down load it free of charge. If the machine is under warranty, call the store or where ever you purchased it.
Feb 03, 2011 | Vacuums
We are VERY disappointed in our Steam mop. After only using twice in one year and following all the instructions, went to use it yesterday, Oct. 7th and could not get any steam out? It started up and it...
Unfortunately they do not work well at all but if it means anything to you your not alone. Many people have complained about the same issue. To be quite honest there really is nothing better than very hot water in a bucket with a bit of cleaning solution and just be sure to squeeze out the mop well before you put it on the floor. It does not need to be sopping wet. Steam, is just water anyways and you can get steaming hot water from your tap in the house bso really its no different.I hope you kept the receipt so you can return it. I hope I didn't ruin your day and if this did help be sure to remember to click on the yes bow on your way out . Thanks again and good luck.
Oct 08, 2010 | Vacuums
Detergent dispenser does not open in wash cycle
mght have a lot of dried up sop in it preventing it from opening.clean the dispenser out real good.please leave feedback
Apr 29, 2009 | Eureka Whirlwind 4388 Bagless Upright...
I THINK THE SMART MIX PISTON IS INSTALLEDS WRONG
it has the rubber seal and the container releases fluid when it depressed.... bipolar lol..
fill it with hot water and prime the machine.. don't use soap just try lear the lines.. always run hot water through your machine to clear the lines before storage.. and to maintain prime
Oct 16, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 7901-1
If the mix valve knob is turning smoothly, then most likely the cap and valve for the sop bottle is bad. Also make sure that the seal is on the cap at the bottom of the bottle and not sitting in the hole.
Feb 18, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
16 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
