Question about Maytag Washing Machines
My maytag washing machine model number mvwc300vw0 filled with water but now it will not spin it just makes a humming noise
natengel
  • 19 Answers
SOURCE: washing machine will not spin makes loud humming noise
motor coupling needs to be replaced
Posted on Nov 05, 2007
dauphine
  • 207 Answers
SOURCE: Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Posted on Apr 11, 2008
  • 100 Answers
SOURCE: Washer does not spin when filled with water. Makes loud noise
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Dec 17, 2008
SOURCE: washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Posted on Feb 21, 2009
lojacksdad
  • 121 Answers
SOURCE: Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
Posted on May 02, 2009
Maytag lse7804ade
Buy the right size fuse. Too big of a fuse can cause a fire.
Aug 23, 2014 | Maytag Washing Machines
Mvwc300vw0
The howling (squealing) noise is likely the belt, if I had to make an educated guess. Of all the fixes you could be stuck with, that's one of the easier ones.
The reason I suggest that is because even though it probably isn't washing to its fullest potential either, you wouldn't really notice it, if it's still able to do a little agitation. Once the spin cycle kicks on, the motor applies a lot of power, and if the belt is loose, it'll spin that belt around the wheel, creating a really soothing and serene squealing noise, causing average humans to start seeking sharp objects with which to slice their wrists.
Sep 02, 2012 | Maytag Washing Machines
I started a load of wash and the water stopped flowing into the machine. It will spin, so it isn't anything electrical. The water will not fill it up?
If there's no water at all, make these checks: If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown? Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Jan 06, 2011 | Maytag Washing Machines
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
My Maytag Performa washing machine filled up with water, and now just makes a humming and clicking noise. It will not agitate, spin, or drain.
sounds like your drive belt is lose.
Open the machine and check it
here is the link for your PARTS
includes also drawing
Jun 19, 2008 | Maytag Washing Machines
Maytag MAV6257AWW Washer
Could you describe the noise you are hearing. This will help to determine what to look for.
Jan 13, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
103 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
