Question about Home
Disk type Pfister valve leaking
The two discs doing the job don't seem damaged. Why does the valve still leak?
    Problem Solver:
  • 19 Answers
I think you should immediately contact to a professional who can definitely help you to get rid of this leakage.
Posted on May 22, 2013
Petcock where connecting to tank seems to be leaking, someone said to tap with mallet on dial and see if it seats or what can I do
Hi, If it won't seat properly anymore, Go and get a new one at your nearest bike shop. Don't hit it with a malot you can crack or damage the threads. Drain tank and remove valve/petcock carefully. Good luck.
Nov 14, 2012 | Motorcycles
Error code p0442
Evaporative Emission System Leak Detected (small leak), check for leaks.
Jul 17, 2017 | 1999 Pontiac Grand Am GT
Vacuum leak in the EGR valve in my 2006 Jetta TDI 180000miles runs great can I just plug the leak with epoxy or what
Would you want a doctor to just plug a leak in your heart
Unless your butcher,just replace the egr valve
The car is only 6 years old & you don't seem to care much
about it's maintance
Sep 21, 2011 | 2006 Volkswagen Jetta
How to fix a leaky Moen faucet that leaks at the spout ,which is separate from the handle?
These faucets can leak in three different places:
  1. Internally at the valve seat
    You'll see water dripping from the spout. This means the rubber washer is worn or damaged. To replace the washer, remove the decorative cap from the handle. Remove the retaining screw and pull off the handle. Remove the decorative cover, called an escutcheon, if there is one. Unscrew the packing nut counterclockwise. Unscrew the valve stem and remove it. Remove the screw that holds the rubber washer in place. Because these washers come in many shapes and sizes, you'll want to take the old one to the hardware store and buy an exact replacement. Be sure to buy two washers so you'll have one for the other valve. Replace the washer and reassemble the faucet.
  2. Around the handle
    If you see water coming from below the handle, the packing nut is leaking. Older faucets have a string-like graphite packing material wrapped around the stem. Newer faucets use an O-ring. First try tightening the packing nut clockwise... about one-half turn. If this doesn't stop the leak, remove the packing nut and replace the packing or O-ring; then reassemble the faucet. If the valve is using the graphite packing material, it might be a clue that you should shop for a new faucet.
  3. Between a pivoting spout and the body
    The spout might be held in place with a packing nut, similar to the faucet stem, or it might have a nut at the top of the spout. In either case, remove the spout and replace the packing material or the O-ring seal. Then reassemble the faucet.
Single lever faucets also are known as "washerless" faucets. They are easier to repair than compression faucets after you determine what type of faucet you have. There are three types of washerless faucets: ball, ceramic disk and cartridge.
Leaks are evident in two places... dripping from the spout and seeping from around the spout where it joins the body of the faucet.
Leaks from the spout indicate that the ball, disk or cartridge is leaking. To repair, turn off the water to the faucet, then remove the handle. The handles on ball-type faucets are held in place with a setscrew that requires an Allen wrench to loosen. Ceramic disk and cartridge-type handles usually are held in place by a screw hidden beneath a cap.
On ball and ceramic disk-type faucets, remove the ball or disk and replace the seals. You can buy replacement kits for these faucets at the hardware store or home center.
On cartridge-type faucets, remove the spout and pull out the retainer clip that holds the cartridge in place. To remove the cartridge, pull on the cartridge stem with a twisting motion. If it resists, install the handle so you can a better grip on the cartridge to pull it out. Take the cartridge to the hardware store or home center and purchase an exact replacement kit.
Reassemble the faucet according to directions.
Leaks at the spout-to-body joint indicate an O-ring failure. Disassemble the faucet as described above. Remove the spout sleeve and replace the O-rings. It's a good idea to replace these seals if you have the faucet disassembled for repair of the ball, disk or cartridge.
Sep 10, 2011 | Moen Plumbing
Vacuum valve leaking water
Question is unclear.
What is a vacuum valve?
You posted under electric water heater.
Water heaters are associated with TP or 'safety overflow' valve, water shut-off valve, tank drain valve, pressure-regulating valve, mixing valve and possibly a few other plumbing valves.
Vacuum valve implies that a compressor is creating pressure on one line while creating vacuum on another line. I don't know of a water heater that uses air compressor.
Open following link to help troubleshoot leaking water heater:
http://waterheatertimer.org/Leaking-water-heater.html
Jul 23, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Price pfister pull out kitchen faucet starting leaking suddenly and profusely at base, from joint segments along handle base, directly under handle and possibly at base of faucet. Understand I need to...
Most likely it is under the label , it is normally put on with light adhesive. That is where the set screw is most cases. As far as leak goes, your on right track with 0 rings/gaskets. Be careful however, some time you can just get one at hardware store ( whole unit) already together almost as cheek as repairing this unless it is just a couple 0 rings.
May 27, 2011 | Price Pfister Plumbing
HELLO THE FAUCET DRIPS AT THE HANDLE AND THE HOT AND COLD SEEM REVERSED
On this valve the hot/cold in reverse is easy enough to fix, but the faucet dripping at the handle is another issue. To reverse the hot and cold, turn off the house water, relieve the pressure by opening a nearby faucet. Once the water stops, remove the handle and faucet cover so you can see the valve. then the four screws that are visible need to be removed. Mark one of the screw holes with a crayon or pencil and then remove by pulling straight out. Once out, inspect the main o-ring right behind where it sits against the valve, (if this is damaged, it might be why the handle area is leaking) then turn the whole assembly clockwise 180 degrees then insert straight back in and insert screws. Tighten screws until snug. Turn water back on before installing cover and handle to check for leaks. If no leaks are found, install cover and handle and check for proper position of hot and cold. If there are leaks, tighten screws in clockwise rotation tightening each screw a quarter turn, then moving to the next one until dripping stops. If dripping is from center of stem, where the handle attaches, you will need to contact Price Pfister to request a replacement. They are very good to work with. Good luck.
Aug 15, 2010 | Price Pfister Universal 0X8-310A Pressure...
Kitchen Faucet Leak
The stem and washers inside the faucet need to be replaced.
If you Do it yourself the parts typically will cost you less than 20 bucks.
Most plumbers will charge 75 to 100 for this relatively simple Job.
You can order parts directly from the manufacturer, or from a local plumbing supply house.
The faucet may still be under warranty and the parts would be free. Here is ther number for Price pfister.
1-800-PFAUCET (1-800-732-8238)
Aug 23, 2009 | Plumbing
My price pfister tub valve leaks
there is an o-ring inside the valve that seals. It has failed. They should sell a rebuild kit where you bought it, or dis-assemble, and take the failed oring in to have it matched to a new one.
Dec 26, 2008 | Price Pfister Ashfield Single Control...
Price pfister sb o34-4nss leaks
Well, this is generic for fixing a Price Pfister ceramic disc valve labatory faucet. On the top of the handle, there is usually a screw cover. Pry it off. Then insert a phillips screwdriver or allen wrench, depending on model and remove. Then remove the handle. At this time, make sure the water is shut off to the faucet. You'll need a socket or wrench to remove the cartridge. On many, the size is 3/4. Loosen all the way, then pull out the cartridge and replace. They are usually between 10-30$/cartridge. Insert new cartridge, tighten (but dont overtighten or you will kill the gasket), then replace the handle and turn on water. Check for leaks.
Nov 23, 2008 | Plumbing
Home Logo
43 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
