Question about HP OfficeJet 6110 All-In-One InkJet Printer
Paper jam message but no paper is jammed. how do i fix it (hp officejet 55210 all-in-one)
  • khaaliis181 Jan 23, 2009
    no paper is actually jammed in any of the paper opening on the printer but the paper jam alert light keep blinking constantly. The copy, fax, & scan lights all are flashing constantly. I have checked ALL the ports, turned the printer off & on and pressed the "OK" buttom with no results.
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Jan 23, 2009
HP Officejet 5610 All-in-One continuous paper jam,
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 04, 2010 | HP Officejet 5610 All-In-One InkJet...
HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
Jun 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Hp Officejet L7480 false paper jam message. Resetting the printer has no effect.
Hp paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
May 20, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
HP Officejet Pro L7800. Had paper jam, but opened
mine was 2 there was paper stuck in the little white gears
Nov 02, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
HP Officejet Pro 8500 has a paper jam. Can't get
Hi! I will be glad to assist you in this issue, here is the link that will fix the issue:
Paper Jam' Message Displays on the All-in-One
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01617494&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3752459&lang=en
Carriage Jam' Message Displays on the Control Panel Display
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01618201&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3752459&lang=en
Oct 11, 2009 | HP Office Equipment & Supplies
How can I fix a paper jam on HP OfficeJet 4580
hi,
Paper jam messages can be true or false. The product might report a paper jam when there is not any paper jam. The following steps resolve both true and false paper jam messages.
this link will help you out:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01368841&cc=us&lc=en&dlc=en&product=3645100
thank you for using fixya,rate my answer
vijay
Oct 05, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
88 people viewed this question
Ben Johnson
