Question about Amana DRT1802B Top Freezer Refrigerator
Freezer light out??
I have an Amana refridgerator with a top freezer that's a little more than 10 years old. It's old enough for Amana to not have any information in their data base when I called! Anyway, the freezer light suddenly went out. Bulb is fine, socket is fine, the switch on the door is fine, and the freezer is still cooling fine - I checked all of the power points with a meter. When I checked to see if power was coming to the door switch, I got bubkis on my meter. Does anyone have any suggestions for "non-invasive" things to check? Chances are that if it's a wiring issue that I can't deal with, it makes no sense to pay to have it fixed because it would cost more than what the unit is worth!! If that's the case, I can live without the light :-)
    Novelist:
  • 87 Answers
Door switches normally use the neutral so having nothing there may not be unusual. You should be able to check the resistance on the door switch (with the power off***). As long as you have zero resistance through the switch (when fully extended, ie. door open), it will be OK. I would definitely buy another bulb first as wiring issues are unusual, these things are normally well built. Good attitude over living without a light because it sounds like you have checked most things, however I know I couldnt. Hope this helps.
Posted on Aug 17, 2007
SOURCE:
I have an Amana upright freezer (model esu13dl)
I have some experience in refrigeration (since I was 16 to now ,I'm 41 years old) and we only replace the grommets when replacing the compressor ,I don't recomended to do that in that little room ,you can bend or break a copper pipe and then will be a big problem.
Sep 20, 2009 | Freezers
Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Sep 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Fan doesnt stop in Amana side by side refrig.
The fan is supposed to spop while defrosting kindly check the timer contacts or wiring short
Jul 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Control board reset?
Amana version of adaptive defrost : Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 04, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Believe my compressor is bad
bite the bullet. or get a repiar person who know how to fix it.
Oct 12, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Kenmore refridgerator 78285892 Freezer light won't work
probably a bad socket. 10-12 years old metal would not likely to last inside a freezer box.corrosion could have eaten the metals...
Feb 11, 2008 | Refrigerators
Refridgerator not cool enough.
sounds like the probable cause is defrost heater. get someone to test the element.
May 27, 2007 | Amana ABB1927DE Bottom Freezer...
Amana DRT1802B Top Freezer Refrigerator Logo
99 people viewed this question
Top Amana Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
