Question about Frigidaire FWS833A Top Load Washer
Frigidaire top load cover not unlocking upon completion of cycle.
  • Official Brand Answer
  • 4,342 Answers
Hello Roger Pierre - From what you have described it sounds like you have a problem with the lid assembly. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. If it proves to be ineffective, contact a professional to move forward accurately.
Posted on Jan 15, 2013
3 Suggested Answers
  • 39 Answers
SOURCE: Door will not unlock, cycle did not finish.
Unplug the power cord let it reset..It should unlock
Posted on May 22, 2009
  • 38 Answers
SOURCE: burning smell during spin cycle on frigidaire washing machine
Open lid as you would load clothes and hold the inner drum with all the holes in it. Give it a manual turn left, then right. If it spins in both ways the main bearing is gone. This is not a DIY because the new bearing has to be pressed on at a machine shop, or an appliance repair shop.
Posted on Dec 29, 2009
Unlock top load washer
Hi, switch power off completely, remove plug from socket, wait few minutes then reinstall plug and start anew. (It would be great if the machine had a reset button). Hope the power unplugging does the trick. All the best.
Apr 17, 2014 | Frigidaire FAHE1011MW HE Top Load Washer...
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
Frigidaire affinity door will not lock when door is closed or register door is not closed when open
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Apr 21, 2010 | Frigidaire ATF6700F Front Load Washer
Frigidaire top load washer approx 6yrs old water keeps running into it won't stop and won't go into cycle water won't stop even by cuting the power had to shut off the valve
The problem is your water inlet valve has failed. It is stuck in an open position. Part # AP3267279 at www.appliancehelponline.com
cost is $37.87 easy to replace. Remove top cover to acess.
Mar 18, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
May 21, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
LOC ERR
The control panel may in *LOCKED* mode. Press the *OPTIONS* and *SELECT* buttons at the same time and hold for about three seconds to unlock the control panel. Make sure the detergent tray is fully closed too.
Feb 23, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire FWS833A Top Load Washer Logo
26 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
