Question about Whirlpool Gold 30" 1.8 cu. ft. Microhood Combination Microwave Oven
The start button on my whirlpool gold hood microwave does not work
The start button is the only button on the keypad that does not work.
MicrowaveSvc
  • 9085 Answers
SOURCE: Whirlpool GT4185SK Keypad does not work - oven starts as soon as door is closed
Is it possible that some spray cleaner accidentally got into the controls?
I always recommend that users spray the cleaner on a soft cloth (not on the keypad itself) then wipe the control panel off.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
Another thing that can cause this is steam or grease / smoke getting in the controls. The best way to prevent this is to be sure your hood exhaust fan is on whenever you cook on the stove top.
If it does not dry out over time, it may need to be manually dried or blown out.
I've followed up to your by e-mail address to be sure I help you fully.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 16, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: When you push the start
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Sep 09, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: my whirlpool microwave model# MH1150XMB-0, light in microwave sta
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on May 26, 2009
SOURCE: Whirlpool Microwave Hood Combination MH3184XPS-0
Ours just started doing this exact same thing this past Friday - 12/11/09. What's going on? The cook power just starts beeping all by itself and going from 10 down to 1 over and over again. It may stop momentarily, but then starts again within a minute or so - it's constant until we unplug it. We plug it back in and within a few minutes it starts doing it again. What gives?
Posted on Dec 13, 2009
hardrocko
  • 1476 Answers
SOURCE: My whirlpool microwave Gold's door is stuck shut.
If this is an undercounter unit remove it from the mounts. Remove the case and look at the rear of the display/control area. You should be able to see the door latch. If not remove the electronics in that section of the unit. When you can see the latch you should be able to get the door open. If the unit is not working (latch wise) you will need to get a new one. Try www.repairclinic.com they have parts for everything at a good price. Getting the door lock out will require a little thinking on your part but you should be able to accomplish it. Let me know if you need more help.
hardrocko
Thanks for using FixYa
Posted on Mar 03, 2010
Where on the Whirlpool microwave keypad is the start control? The model is WMH31017HS
Jack, The start button on this Whirlpool® Microwave is located underneath the number 7 on the key pad.
Sep 10, 2017 | Whirlpool Microwave Ovens
How do I fix the key pad of a Kenmore microwave model 401.80084700?
I don't know of anyway to repair the keypad. Usually replacement (of the keypad/control console) is the only option. But you might want to remove the ribbon cable that connects the keypad to the control board behind it, clean it with a degreaser (like Fantastic or 409), dry it, and re-insert it, and then try again. (Remember to unplug the microwave oven first before you try that!)
Jul 07, 2014 | Kenmore Microwave Ovens
I hit the start button on my Whirlpool microwave oven model no. MH7110XBB-5 but got nothing but a click. Any thoughts?
The control board that is located behind the keypad is the problem, I have seen the board develop bad solder connections around the relays. If you are handy with a soldering iron you can attempt a repair, remove top "2 to 6 screws" and remove keypad with control board attached "clipped or screwed in" remember to unplug microwave before you work on it.
Jun 28, 2011 | Whirlpool Microwave Ovens
Whirlpool gold accuwave microwave oven lost power afer running em
Hello Davisaroundt, we are sorry to hear about your Microwave not powering on. If you would like for us to schedule service for you, then can you please email your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 13, 2017 | Whirlpool Accuwave Microwave Oven
Whirlpool Microwave Hood Combination MH3184XPS-0 (October 2004), for no reason at all, this morning keeps beeping and running the power setting down from 10 to 1, and just keeps doing it in rapid sequence....
Dec 08, 2009 | Whirlpool MH3184XP Microwave Oven
Whirlpool gold series model gh7155xhs-1 buttons not functioning
Remove power to unit, wait 3 min. Plug unit back again try using touch control, If it still not working replace controller assembly, touch pad and board.
Sep 17, 2009 | Whirlpool GH7155XHS Microwave Oven
Microwave wont start
go to repair clinic .com or similar site.Will need make model # serial#
Jan 07, 2009 | Microwave Ovens
Buttons #3 & 8 on control panel not working
Sounds like your keypad has failed and you need the fan circuit repaired on the control panel.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Add to that about $75 for the keypad.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 01, 2008 | Whirlpool GH7155XHS Microwave Oven
Mar 12, 2008 | Whirlpool GT4185SK Microwave Oven
Whirlpool Gold 30" 1.8 cu. ft. Microhood Combination Microwave Oven Logo
20 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
