Question about Coffee Makers & Espresso Machines
Machine lost electrical power. Used it twice this date then it shut down. Won't power up. Checked outlet and breaker. They were fine
  • Michael Jan 13, 2013
    Simply is no power to the unit.
    Genius:
  • Coffee Maker... Master
  • 1,669 Answers
Try some of these websites:
http://www.espressoitalia.com.au/viewStory/Troubleshooting%20your%20coffee%20machine.
www.youtube.com/watch?v=uGBg69MhOso
http://www.ehow.com/how_7678469_troubleshoot-saeco-coffee-machine.html
Posted on Jan 13, 2013
Second hand Nordictrack.exp.1000, was running.only.13min...shut.down...checked electrical outlets...treadmill completely.shut down?
did you check the breaker switch. it is either by the main power switch or is part of the power switch. follow the cord to the treadmill and check
Jul 29, 2014 | Exercise & Fitness
No power to Whirlpool awo/d5727. I have checked the fuse and the socket but still have no power.
You say you checked "socket" and the "fuse," did you mean the AC wall outlet (115V) and a fuse or breaker in the main power panel?
Nearly all circuits involving water are protected by a Ground Fault Interrupter that can be servicing several wall outlets (perhaps one not near the washing machine) or can be located as part of a circuit breaker in your main power panel.
The GFI outlets will have one or two push buttons located between the outlets and a combination GFI/overcurrent breaker will also have at least one button where others will have none.
If you find one that is tripped, try resetting it. If it will not reset, unplug the washing machine and try again.
If it now stays on, your machine may have an electrical path causing it to trip and using an unprotected outlet may be unsafe and an indication that the appliance itself may have electrical leakage which could be otherwise dangerous.
The circuit breakers in the main power panel can also fail (they didn't 20 years ago) and we have replaced 3 in a home only 5 years old already so they are not made well anymore.
Jun 22, 2013 | Whirlpool Washing Machines
It won't turn on
check the electrical outlet and, or, the circuit breaker to your washer
Feb 04, 2013 | Miele Novotronic Premier 500 Front Load...
Janome 9000 lost all power in the middle of embroidery and won't turn back on.
have you checked to make sure the power cord is plugged into the machine correctly?
is the outlet getting electricity?
if the answer to the above is yes
then it's possible the power cord, motor could have with out
have you checked to see if the sewing machine has a battery compartment
or a fuse compartment?
Mar 29, 2012 | Janome Memory Craft 9000 Computerized...
I have a HE3 dryer which will not run and does not light up. I checked power at the outlet and equipment connection and it has power. I then activated the diagnostic test mode and all lights are activated...
Try shutting off the breaker in the main electrical panel for a few minutes. Then turn it back on again. Sometimes resetting the main power will re-set the programmable Logic Controller.
Jan 09, 2012 | Kenmore Dryers
Machine not turning on
1. Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2. Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3. Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4. Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Hope i could help you.
Have a nice day : )
Sep 04, 2011 | Microwave Ovens
The electrical consumer unit trips when the dishwasher is on, swicthing all the sockets off in the house. An electrician has told me it could be a number of things, namely a problem with the neutral, some...
You might need to contact a different electrician. Also a different retailer of machines as this one is obviously trying to make a sale. The apparent problem is that the house is wired with all of the outlets in the house on one circuit breaker--a recipe for trouble. Any house with multiple outlets should be divided into zones so that the whole house doesn't shut down if one appliance trips the breaker. A heavy user of power like a dishwasher should have it's own breaker and wiring for that machine alone. The electrician should have load-checked the dishwasher to make sure it is not drawing more than rated power, then suggested that it be wired to it's own breaker and circuit. Any other high power appliances should also have separate circuits (washing machine, microwave, toaster, etc.). Hope this helps!
Mar 25, 2010 | Tecnik TKL9260 Front Load Washer
The microwave does not react what so ever. Checked the fuse and its fine, what could be the problem? please help
Is there power at the outlet? You say you checked the fuse ... is that the one inside the machine? Is the outlet protected by a GFI (reset for a GFI is on the GFI)? A GFI looks like a ordinary outlet but is very sensitive to electrical irregularities. Your circuit breaker may be on or your power panel fuse may be fine and the fuse inside your oven may be fine. If the GFI is popped, you have no power.
Try some other electrical device in the outlet. Does it work? Try an extension cord from a known hot outlet?
Beyond these tips, you may need professional help with this.
Thanks for your interest in FixYa.com
Jan 22, 2010 | LG LMV1630ST Microwave Oven
Saeco Incanto will not power on.
The curcuit breaker on the boiler probably tripped. There are 2 of them on the boiler. You can remove the back cover to access these parts. If you are not comfortable with taking the machine apart, take it to a service center.
Check out www.CeriniCoffee.com
Authorized saeco service center for new york
Oct 25, 2007 | Saeco Incanto Classic Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
