How does the sound tuning work on Sennheiser IE80 ear buds? Is the minimum (factory setting) the lowest bass setting? What setting is considered neutral?
SOURCE: Sennheisser cx300 ear buds ..one channel has lost volume.
I have been having the same problem for the past week, I have just fixed it, reading your post gave me the idea to clean them and it actually worked
What i did was to "heat them up" with a hair dryer so that any wax from my ear that had gotten inside would "melt", then I cleaned them with alcohol and a q-tip and I made sure I let a bit of alcohol to get inside the ear bud, then I dryed it with the hair dryer again very carefully and tested to see the results and WHALA works just fine
Posted on Jul 15, 2009
electrodynam
  • 35 Answers
SOURCE: Losing sound in my Shure ear buds, they are one year old.
the wire breaks after a while in ear buds ,and head phones due to the constant flexing,and moving.they probably need to be remade.by cutting out the bad part of the wire(usually close to the fitting)You can usually wiggle the wire and find where the breaks are that way.it can be a real pain re soldering ear buds.also check the plug end by wiggling the wire there.
Posted on Mar 16, 2009
usshadowop
SOURCE: Only One Ear Bud Works
It is likely that your right stereo channel has either been severed somehow or there is a severe short in one of the cables. What you can try to do to test this theory is first turn on your music. Then wiggle the cable at the very base of the right earbud. If nothing happens wiggle the cord right where it connects to the stereo jack. If still nothing happens run your fingers along the right earbud audio cable bending and twisting it. If at any point you hear music again then you likely have a short. If it is near the earbud then it is going to be difficult to fix since these earbudfs have a large gauard. If the short is at the stereo jack then the fix is simple. A standard 1/8" stereo jack can be purchased from any electronics or audio store. You can then fairly easily seperate teh old stereo jack and solder this new one in place. Search the internet for tutorials on how to do this if need be. Even if you do not get any kind of sound when wiggling it at the base of the jack this is the most likely culprit since this is where most of the stress on the headphones occur. Be wary though, if you do attempt a stereo jack repair you will void whatever kind of warranty your earbuds may have so check before you try. But, in teh end you may end up saving a 60-100 dollar set of earbuds for 5-8 dollars. Hope this helped.
Posted on Sep 19, 2009
SOURCE: Right ear bud isn't working
i have this problem too, except it's the left side that doesn't work. i think that's because the copper wire inside broke or is severed partly. there is no way to fix it... just go buy a new one and this time try to kot coil the cords around hour mp3or ipod.
Posted on Oct 28, 2009
  • 272 Answers
SOURCE: my skullcandy earphones are busted
could be caused by the way you wrap them up the cords should never be wound tightly it causes a short and it just so happens that earphones are made of light weight wiring to make them seem to disapear when wearing them so what to do is instead of winding them when your done simply fold them loosely so to speak
Posted on Feb 25, 2010
How do I insert the Apple Earpods into my ears so they will stay???
switch the ear buds that's what I do when they wont stay in and it works really well
Sep 21, 2014 | Audio Players & Recorders
Hi, I have a Ludwig Classic Maple drum comprising: Bd 16x24, Sr 5x14 , Tt 7x10, Tt 8x12 , Ft 14x14 , Ft 16x16 . I am very happy with the sound of this drum, very powerful, resonant, and easy tuning, I have...
Here I've listed valuable reference information on bass drum tuning and achieving the lowest pitch possible. Some things are trial and error but once you fully familiarize yourself with drum tuning you should be able to achieve the sound you want. Hope this helps.
Kick Drum Tuninghttp://home.earthlink.net/~prof.sound/id6.html
Bass Drum Tuning Lesson http://www.drummerconnection.com/drumlessons/youtube/46667-bob-gatzen-bass-drum-tuning-lesson
Apr 05, 2011 | Ludwig Classic Maple Power Drum Set Shell...
When I used these headphones this morning, I noticed that the sound from one of them was far less powerful than the other one. I've tried different songs, to see if it wasn't just the song, but the problem...
had the same problem with the right ear bud and I don't know if it is suggested in the manual, but cleaning the mesh on the ear bud with a cotton stick dipped lightly in alcohol (almost dry) helped with me, the sound is back 100%.
I hope it helpes with your too.
Mykab
Sep 05, 2010 | Sennheiser CX 300 Consumer Headphones
I have a 2008 Hyundai Tucson with the premium sound package. The first radio was replaced by the dealer as the radio has no bass at all. The treble even turned to the lowest setting pierces my ears. The...
Try replacing the factory speakers with a better quality speaker. make sure you listen in a sound room before you have them installed. make sure you like the sound of the new speakers before installation. also have the radio tech listen to your car to make sure radio is ok
Feb 12, 2010 | Car Audio & Video
Apr 10, 2009 | Sennheiser CX 300 Consumer Headphones
Help! no bass sound, low volume
You might want to try using a different size of the earpieces that come with it, and make sure they're inserted fully into your ear. They come with three different size earpieces because people's ears are shaped differently, and having the right size can make a HUGE difference in the sound. If it's done right, it should basically feel like you've just inserted an earplug into your ear.
If that doesn't help, and you've tried another pair of headphones to verify that it's not a problem with your sound source, I would guess you were unlucky enough to get a defective pair.
Mar 17, 2009 | Sennheiser CX 300 Consumer Headphones
Want to replace PX100 wires
Just be careful, maybe try to find a guide to dissasembling the PX-100's - I had a pair go bad that I tried to open up and I mangled them somewhat - of course I wasn't being super careful, nor were they in great condition at that point. There's a lot of you tube vides about replacing the ear buds with other ear buds - it should be straight forward, minus the extra care for taking the PX-100's apart. Any concerns about impedance matching for the wires? Could this represent a degradation of the PX-100's sound if the wires are diff. impedance?
Jan 07, 2009 | Sennheiser PX 100 Consumer Headphones
I plugged int he rca's but he the lowest sounding bass possibe
kicker subs arnt ment to hit the lowest bass, unless you go spend a **** load of money, im talking 3000 wat amp, ant some 15' or bigger subs. the most commen kickers are 12' subs, so im asuming you have 12' subs, if not, this (said lightly) should work. try turning the bass boost screw on the amp to the middle of its turning range. this will offer the greatest balance between high and low bass. if you want more low bass, turn it past half. if you want more high bass, turn it down. i have mine set to mid range, but i also recently purchased 2 18' kickers. with every new set of subs, you should spend at least 15 min tuning the amp to get the best performance. every sub is different. hope this helps, good luck.
Jun 27, 2008 | Kicker KX800.2 Car Audio Amplifier
I have a pair of Peavey Impulse 1012 4ohm amp a Peavey XR 696f was not geting enough bass ( use a Yamaha TYROS keyboard & Vocals) so i purchassed a pair of Peavey messanger Pro 15 Sub Cabs 4Ohm cant...
Hi fingers 1
There will be some overlap in bass response that you may need to tune out to tone down the boomy bits. You could tune this out with a 31 band EQ Another approach is to use a crossover or low pass filter to the subs to get some control over your bass frequencies. Another thought, if you're using the rig for stage work, how does it sound out the front. It may be standing waves created by the bass bins, moving them to different monitoring positions may also help.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jun 18, 2008 | Audio Players & Recorders
485 people viewed this question
 Grubhead
Grubhead
