Question about Sole Fitness F63 Treadmill
My Sole F63 treadmill belt either fails to start or starts only with some coaxing
My problem is two-fold; I have run through the steps to calibrate the treadmill and get a 'low speed' error message. The speed sensor is as close to the magnet as it can be without actually touching it. After a few seconds of me pushing the belt with my feet, I can hear a 'click' and the belt begins moving itself, and works appropriately, but then when I hit stop the belt doesn't stop (only pulling the safety cord makes it stop).
  • 138 Answers
You may have a few different issues. it sounds like you may have motor or motor brush issues. If the motor brushes are burnt then they don't make proper contact with the motor so they won't be able to power it unless you help it along with your foot. If you are the original owner of the machine and have a proof of purchase that motor should be covered under warranty. The stop issue is a weird one. It's probably just that the stop button isn't working and that's a pretty inexpensive fix.
I would definitely not use the machine until you've had a technician look at it. I am going to guess that the treadmill is over 6 years old. If it is then on top of everything else you'll need a new walking belt. To put one cent into that machine and not replace the belt is a complete waste of money. The problems will all come back and they'll be much worse.
Posted on Jun 16, 2017
2 Suggested Answers
  • 12223 Answers
SOURCE: F63 sole treadmill, low speed error when inclined
If the calibration does not pass you may need to check the speed sensoralignment. You must understand the instruction for calibration is under the hood for motor.
1) Remove the motor cover hood by loosening the 4 screws that hold it inplace (you do not need toremove them completely).2) The speed sensor is located on the left side of the frame, right nextto the front roller pulley (thepulley will have a belt around it that also goes to the motor). Thespeed sensor is small and blackwith a wire connected to it.3) Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
2) if the problem persist you must Test the main motor for open, ground 3) the main control board faulty. See the block diagram that I did as person like you that understand that 90% of functions the main motor controller board has effect.
good luck. sincerely. God bless you.
Posted on Dec 01, 2011
I have a Sole f63 treadmill and I am getting an E7 error
This is an incline motor issue. Your manual should have the steps to get the treadmill into calibration mode. Follow the steps and the treadmill will calibrate itself. If it fails the calibration then it’s most likely that the incline motor needs to be replaced.
Nov 29, 2017 | Exercise & Fitness
I have it all set up..programmed a work starts to work..but the tread itself that you walk on wont run..what do I do?
From the User
'1.If the belt moves, but stops after a short time and
thedisplay shows "LS", run calibration. (on next page)
2.If you press start and the belt never moves, then
the display shows LS, contact service.
Sep 14, 2014 | Sole Fitness F63 Treadmill
Sole f63 error codes
Make sure the safety key is clean and not corroded . Check connections on lower board.
Aug 07, 2014 | Sole Fitness F63 Treadmill
Slow starting
Run the software calibration for easy diagnostic, and fix it. Go under the HOOD motor follow the steps and proceed.
God bless you
Dec 05, 2013 | Sole Fitness Sole F63 Treadmill
The belt on my Sole F63 will not turn
It sounds like you have a blown motor controller. If your machine is older than 5 years then that's pretty normal for sole. Their belts don't last very long and they cause stress on the controller. You'll have to replace the motor controller and the walking belt.
Aug 05, 2017 | Sole Fitness F63 Treadmill
My Sole F63 will slow down a few seconds after I start it then I get a low speed displayed on my control panel
please LUBE the deck belt+ rollers bearings too. You must do it evey 150 miles apros. This happen because the lack of maintenance schedule.
God bless you
Jan 21, 2013 | Sole Fitness Sole F63 Treadmill
Error message and no incline on my sole f63
1) Run the software calibration for diagnose, and troubleshooting and fix it.
2) lube the gear and shift from elevation motor
3) adjust pot from elevation motor
4) tight the wires connector
5) Test the elevation motor for defective, measure the input voltage see my personal TIPS.
God bless you
Jul 08, 2012 | Sole Fitness F63 Treadmill
Sole Fitness F63 Treadmill Logo
800 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
