Question about Sony KLV-S32A10 32 in. HD-Ready LCD Television
TV doesn't recognize HDMI with Roku
Have Roku box plugged in to HDMI port on back of TV. On WEGA GATE menu, External Inputs, no HDMI option to select. How do I make the TV recognize this so I can easily switch to HDMI input in addition to others (currently shows VHS and DVD).
    Genius:
  • 1,669 Answers
The Roku is the problem, not the TV. You need to go to the Roku site and request download information to synch the Roku to an HDMI input.
Posted on Jan 13, 2013
4 Suggested Answers
mistersony
  • 320 Answers
SOURCE: KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
Posted on Oct 19, 2008
Coldcut
  • 1554 Answers
SOURCE: Accessing External Inputs Settings
you have to use the remote control for the tv not the dvr.
the dvr control likely cannot control the tv inputs programming unless you can program the correct code. and most new lcd panels don't have the correct codes for existing remotes
access using ext on the tv remote.
you may have to go into the menu and tell the tv what the ext is set to ie.. a channel or a input.
Posted on Feb 18, 2008
welcomejee
  • 10594 Answers
SOURCE: cant get video 6 input. Seems to be stuck on
Please confirm tv model number as question shows it is Sony KDE-37XS955
Model number would be written on label pasted at rear of tv, this info will help me to provide you info about Video-6
Thanks.
Posted on Mar 21, 2011
No hdmi audio output except Roku 2.
You didn't mention whether you switched inputs on your TV for the different devices. Fix could be that simple.
Apr 30, 2016 | RCA Televison & Video
How to hook up a Roku2 to Sony KLV-S32A10 TV with A/V cable (yellow/red/white Ports)
If you plug into the box and TV with the composite plugs then you need to change inputs. Your TV is currently set to use HDMI. You need to change the source with your remote.
Dec 25, 2014 | Roku 2 HD
Www roku com link
This sounds like a basic setup, so correct me if I made any wrong assumptions.
You have 2 "output" devices: a Roku and a cable box. Both have HDMI outputs.
You have 1 "input" device (your TV) that has 2 HDMI inputs available.
So, you need one HDMI cable to connect your cable box to your TV. Remember what HDMI port it's connected to - the back of your TV probably says "HDMI 1" and "HDMI 2" or similar. That's the "input name" of your TV.
Connect your Roku to your TV with another HDMI cable.
Now turn on your TV and use the remote to change between the inputs. Most remotes have a button that says INPUT or SOURCE (or sometimes a dumb little icon with no writing). If you press that it should change inputs. Usually, each time you push the button will cycle to the next input, so sometimes you have to hit it a bunch of times until the on screen menu shows the input you want. Most TVs will automatically switch to the selected input after a few seconds, so you don't have to push any buttons on the remote to tell the TV to change inputs.
If "at the same time", you meant actually watching both Roku movies and your cable at the same time, you are talking about a TV feature usually called "picture in picture". That should be possible, but will depend very much on your TV. I'd suggest checking your TV manual, or calling the company's 1-800 number and asking them to talk you through it.
Jan 07, 2014 | Computers & Internet
Inputs not working
Sounds like the main board has gone bad. But! what is the model number and brand?
Dec 19, 2013 | Sony KDL55EX620 55 LED HDTV
JBL SB400 Soundbar System
With some TV's you have to go into the menu, and enable an external sound device. If that doesn't work you can try to hook the tivo to the other HDMI inputs to make sure they work. If yes then, it's not your TV it's the soundbar. Hope this helps! Good luck!
Dec 17, 2013 | Sharp LC46SB54U 46 in. LCD TV
Using Roku 3 with HDMI cable to stream to TV, is there a way to get an audio out signal (either from the TV or Roku box) to connect to an analog stereo receiver
Your tv should have a couple different audio out options, but you can not just plug in a wire and make it work. You will have to use your remote to go into your settings on the tv and select an external speaker before it will actually send the signals out.
Oct 11, 2013 | Televison & Video
Run DVD through tuner
ok a bit confused, Tuner ? like amplifier or Tv Tuner ? regardless seems like a easy fix .
First your cable box as 3 cables:1st . Power cable to outlet
2nd. From the wall ( usually a Coaxial cable coming from outside box ) into cable box.3rd. HDMI or Second coaxial cable ( One of these usually goes to the back or side of your Tv depending where inputs are located.)
Now Dvd has 2 cables 1st to Power2nd. To TV ( Hdmi or Coaxial )
On the back of your Tv will have 2-3 HDMI inputs . Assign 1HDMI jack to each media your trying to use.In this case TV HDMI 1, HDMI 2 DVD.
Assigning HDMI's will now reflect on your TV menu selection. Choosing HDMi 1 or HDMI2 from Tv menu will allow you use or view desired Media option in this case DVD or TV.
Now if there is Amplifier / Tuner involved like to connect surround sound to, connection may be a bit trickier however same principal.Plug all media into HDMI 1, HDMI 2, respectively,this time to the back of the tuner NOT to back of TV.Once you have done that You will need a third HDMI cable now from the back of the Tuner ( output Jack, usually has lighter color markings indicating Output HDMI) to your HDMI 1 jack in the back of your TV. Now you have bridge TV/ Cable , DVD into Receiver / Tuner and Selecting media will now be done not through TV Menu as before but through Tuner / Receiver menu or selection.
Good luck .
Good Luck
Sep 20, 2012 | Panasonic DVD-A120 DVD Player
I am connecting Roku to an open HDMI port but I cannot get the port to recognize Roku
In your TV, go to Menu, Settings and then turn on the HDMI port. Hope this helps Fix Ya up.
Aug 04, 2011 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sony KLV-S32A10 32 in. HD-Ready LCD Television Logo
3,479 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
