Question about Home Security
Willpart#37334r work on a genie blue max garage door
Replacingsafetbeam sensors
SOURCE: Genie 2020L - Garage door does not close using remote/pad
You have loose wire(s). After speaking with Genie Customer Service, they had me disconect a few of the wires and try operating the unit, to no avail. I noticed when reconnecting the wires that several other wires on the same row of connections were loose. I tightened all wire connections and VOILA, it works.
1.Open plastic cover in front of the Unit.
2. Look on upper right corner for a row of screws. Model 2020L has a verticle row of (6) connection screws numbered from top to bottom, 1-6. These screws connet to a green circuit board. Looks kind of like a video card from a computer.
3. Tighten all these screws top to bottom assuring good connection of all wires.
My contention is this. As the motor runs, it causes a vibration that tends to loosen those screws causing a faulty connection to the circuit board. Hope this works for you.
Delta Dan
Posted on Nov 24, 2008
dburns60
  • 410 Answers
SOURCE: Genie Directlift garage door opener, wall control problem.
Sounds like a skinned wire on your front or rear limit switches is touching metal. Go over your low voltage wiring and test again.
Posted on Jul 05, 2009
  • 31 Answers
SOURCE: Genie garage door openner won't stop when it goes down or up
there should be a "travel distance" adjustment screw on the opener.
Posted on Aug 26, 2009
blanchettohd
  • 143 Answers
SOURCE: Genie Garage door will not
If you hit the button on the remote and nothing happens then you may need to code in the remote. On the motor head press the learn button and then press the button on the remote 3 times.
If it looks like the remote will work the opener or it opens the unit but not close it you are experiencing safety sensor problems. Make sure they are aligned. There will be a light on each and each should be on. Check the wiring to them too. They are not polarized. Thanks BB
Posted on Nov 06, 2010
blanchettohd
  • 143 Answers
SOURCE: genie excelerator light won't turn off...
First unwire the wall button. If the light will go off now replace the wall button. If not then you will need to replace the logic board on this unit(genie.com for replacement). Protect this with a surge protector as well 900 joules or higher. Thanks BB
On the garage door sensor, there is a flashing red light. What does that indicate
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwi4hab1u9fSAhUB04MKHRToAGkQFggiMAE&url=http%3A%2F%2Fwww.lestersgaragedoors.com%2Fapp%2Fdownload%2F380621404%2FGenie%2BTroubleshooting%2BGuide.docx&usg=AFQjCNHVMARYMdlwTGmakU6Y55gN7el_ug&sig2=B7X4z0bZatia1370-fnQjA&bvm=bv.149397726,d.amc
Mar 15, 2017 | Building Materials
My Genie door opener does not seem to want to connect to the Chamberlain remote control. Please advise!
If you have a universal remote or a max remote you can go to chamberlain.com to check compatibility. if it is not a universal or max remote it won't work with any genie product.
May 04, 2015 | Building Materials
Garage door opener not working
Sensor must show steady light to close circuit and let opener work. If aligned, then there is a loose or broken wire. Try reaiming first to get steady light. Then check all wires . Another way to test and prove that is the issue is if u hold down the wired button at ur back door and the opener closes, then it is sensor issue. Good luck.
Apr 11, 2015 | Genie Company Genie Garage Door Opener...
Hi, I have an older garage door opener, Genie
If the opener doesn't work with the button on the wall the opener is defective, either the receiver board or the motor drive circuit or the motor itself.
May 03, 2017 | Transmitter Solutions Building Materials
Genie H4000A manual
The garage door will only go down by holding the button on the wall switch
Aug 30, 2012 | Sears Genie Garage Door Gpwk12 Wireless...
I have a genie pro max PMX 300 IC/A garage door opener and bought a Genie 3-button remote (model G3T-R) and I can't get it programmed. I push the button on the back of the opener, push the button
Take the opener apart and see if there are about 4 numbers that can be set. If you have an older remote take it apart and match the numbers, then program it.
Feb 07, 2012 | Home Security
Door wont close with remot
Your door sensors may have been bumped and are no longer pointing at one another. Tweak them until the small light on each sensor is on and glowing steadily.
Aug 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
