Question about Boomerang III E-156 Phrase Sampler/Looper
Boomerang III E-156 Phrase Sampler/Looper manual
I have a Korg KP3 with a faulty touch screen. How can I get this fixed?
Take it appart rub it with pure alcohol an put the touchpad together again
Nov 23, 2014 | Dynamic Korg Kp3 Kaoss Pad Dynamic Dj...
I looking for owner's manual for Alfa Romeo 156 JTS
Hi Lilian,
I have this site for you to get manual for your Alfa Romeo 156 JTS.
http://www.myalfa.eu/katalog/english/1/156.pdf
May 08, 2014 | Music
I've connect my sampler to the mixer. In the RCA "send" and it won't play through my speakers. I can only hear it through the headphones. What could be the problem? I'm using Numark...
You would NOT connect an audio signal to the "send" jacks... those are OUTPUTS... In doing so you are driving signal backward enough to get to the headphones. Sends and returns are NORMALLY used on a mixer for external effects. You should either be using a LINE input jack or one for "tape input".
Sep 10, 2011 | Roland Sp404sx Portable Sampler Wdsp...
I have Korg M3 with some weighted keys issues and I need top repair it. Please advise. Thanks, Ted
Hereis your service manual for the M3... 29Mb
http://elektrotanya.com/korg_m3_sm.rar/download.html
Scroll down the site page to "Get Manual" and click on it to download.
Be careful of the ribbon cables within the unit. God to have extra hands available when opening the unit.
May 10, 2011 | Korg M3 88 88 key Workstation/Sampler with...
My digitech looper phrase sampler will not turn on
A common problem is that somebody has paired the WRONG power adapter to this unit.
The REQUIRED adapter should be 9VAC (not DC) at 1300ma or 1.3 amps.
Note that UNIVERSAL replacement adapters will NOT work with the Vocalist.
Feb 06, 2011 | Digi-Tech Digitech Vocalist Live 4...
Don't need a repair. I need a manual. know where I
Line 6 has the manuals on their site.
The Spider III 15 is in two parts: part 1 and part 2
The first is the manual, the second is the sample settings.
Both are PDF files.
Jan 20, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
Sampling into yamaha dtxpress iv
If you have a sampler, you could midi out of the DTX brain into the midi in of the sampler to trigger the sounds. If not ,try downloading KORE2 from Native Instruments onto your computer and triggering it using the above mentioned method . Midi out from your brain to Midi in on your computer. Hope this helps.
Jan 13, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Split two hands for two different sounds
The SP200 does not have any built in ability to split the keyboard between high and low. My guess is that you were seeing someone using this keyboard as a midi controller for a sampler (or sample player) and they had assigned various samples to keys or key ranges. This can be done using Reason fairly easily. The setup would be in the sampler you use however and not the keyboard.
Hope this helps.
bd.
Jan 03, 2009 | Korg Pa800 Synthesizer
Recording my voice through computer with keyboard
You need a Sampler. Either software or Hardware will work. A sampler is the device that will make it possible to play your voice on your keyboard. There are many software samplers available, take a look at websites like sweetwater.com or musiciansfriend.com and have a look at the pc software section. You will also need a MIDI connection for your computer to enable the keyboard to talk to your computer (runs around 50 bucks). I would look at a program like Sampletank or others.
Dec 05, 2008 | Music
Boomerang III E-156 Phrase Sampler/Looper Logo
Top Boomerang Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Boomerang Music Expert? Answer questions, earn points and help others
