SHENG SPF240 THERMAL FUSE one shot
  • rob_rol58
    rob_rol58 Jan 15, 2013
    Sheng(ping) SPF240 is a one shot thermal fuse which cannot be bought in the Netherlands you can buy them under a different name G4 00 228 =SOLVED
  • rob_rol58
    Its for a toaster or things that heat up
Kodak 760H will power up
I'm assuming you mean the projector will NOT power up. This is usually caused by the lamp thermal fuse opening. The Lamp Thermal Fuse is a safety device that will "open" when it detects an over-temperature condition. The fuse is a "one-shot" device, so once it opens, the cause must be determined before the fuse is replaced. Because the projector is so old, parts may or may not be available. Try contacting: www.micro-tools.com for availability. They purchased all the repair parts from Kodak in the mid-1990's when Kodak stopped supporting the projector business. Good Luck !!
Jim
Jan 28, 2014 | Kodak Office Equipment & Supplies
Schumacher battery charger sf-1252-ma thermal fuse does anyone know what the number is off of this fuse
The thermal fuse (1 shot fuse) is a #U25 from
Uchihashi Corp. The link below will take you to their page showing the fuse type and ordering information. Probably not found at a local electronics store.
http://www.uchihashi.co.jp/english/image/pdf03ae.pdf
Nov 20, 2010 | Schumacher & Fast Charge Starter Charger
Nutone, Model QTXN 100HL-A 1500 Watt Does not heat. Electrician said it was the heater part that has "6260 Eichen 04" on it. He said it was the diode. I would like to order the small part.This is a...
The "diode" that your electrician mentioned is actually a one shot thermal fuse.
You can either go to the Nutone website for parts, or remove the thermal fuse, extract the info written on it and buy a replacement. Mine was a 100C 10A thermal fuse. I got mine from DigiKey.
Mar 29, 2010 | Broan-NuTone Heating & Cooling
I have the red Cuisinart BFP-703 SmartPower Duet Blender/Food processor. I turn it on and press and of the buttons and it does come on. What should I do?
if you over loaded these machines there is a thermal fuse one time shot will blow . it is not resettable , you can buy them @ Radio Shack 8 amp should do fine . it might be stamped with the rating value too. need a test meter to check component very small .187 diameter & .750 length apx
Mar 14, 2010 | Cuisinart Blenders
What battery is used for the Sheng Bang HD-1688 clock. It is an unusual size.
I do have a Clock with a Sheng Bang HD-1688 Clockwork. There is a normal AA 1.5V battery in it.
Kind regards Marcel van ****
Jan 31, 2010 | Hammacher Schlemmer Brian The Brain
My dryer will not start. i tried a new start switch, no change. the door switch is working. if the thermal fuse is shot will that stop the dryer from working or only stop the heater from working. the moter...
there is 2 thermal fuses on some models 1 for the heater and the other will keep the unit from coming on at all which is most likely your problem. Example on a series 90 kenmore there is a thermal fuse and high limit mounted right on the side of the heater element housing and another fuse and thermostat mounted on the blower housing. The fuse on the blower housing will kill dryer completely.
Jan 08, 2010 | Whirlpool Dryers
Waring Pro Waffle Maker
I posted the same problem (no heat) but may have found the answer. There is a component that cuts off the power if the unit gets too hot. My best guess name for it would be a "thermal fuse". If it goes...no heat. (located behind one the waffle grids inside unit..silver and black)(behind the other grid is what I believe to be a variable resistor that varies with heat..used to set heat levels in conjunction with the dial on the front of waffle maker)
When thermal fuse goes it needs to be replaced. BUT I WONDER
what caused the overheating? I will go down to Radio Shack and buy the "thermal fuse" according to the data on the old "fuse" and put it in...then ????waffles or sparks???
the old fuse has printed on it: sheng ping SPF240 TF240 Deg. Celsius 10 amps 250volts 073 and some symbols
Wish me luck
Feb 24, 2009 | Waring WMK300 Professional Belgian Waffle...
Hotpoint CTD 40
Thermostats do not have a reset
IF the dryer has failed by overheating, the device is called a thermal fuse, it is a one-shot protector, and needs to be replaced.
If the thermal fuse has blown the dryer is likely {expletive deleted} with lint and needs to be cleaned.
STILL require make and model details for replacement instructions
Oct 08, 2008 | Dryers
WWM200PC Waffle Maker will turn on but does not heat up
I fixed one of these for a friend - the problem was an open thermal fuse. This fuse is located in the fixed grill; it is clamped to the grill and is covered by a white plastic sleeve.
The replacement part should be a 240°C/464°F 10 - 15 Amp thermal fuse. NTE sells a part NTE8242 which works available from Mouser.com for $1.41 plus shipping.
May 25, 2007 | Waring WWM200PC Waffle Maker
Power button
Sorry, I have to say it. If the bulb (LED) is shot it would have to be zero flashes :-) It's my weird sense of humour. After that I hope you'll forgive me and someone can give you some real help.
May 27, 2006 | Sony KDF-E55A20 55 in. LCD Television
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
Electro Med Services...
