Question about 2wire Computers & Internet
Can a 2wire 1000HG be used as a bridge?
Want to use in shop located away from house about 100 ft. Shop is a metal building. Current router connects outside of shop, but not inside.
  • 2wire Master
  • 2,072 Answers
You would need to look in the settings to see if it has bridge mode. A possible option for you. Get two wireless routers. Have one in the house where it is now. Run an ethernet cable from it into the shop (Max lenth should not exceed 300ft) Put the other router in the shop. Hook the ethernet from an Ethernet port on the router in the house to the WAN/Uplink port on the second router. Make sure both routers have DHCP enabled and they are on different subnets. So house network could be (Ex: 192.168.0.0) network and Shop (192.168.1.0) network. These will route correctly and use the same internet connection. If you need further directions just ask.
Posted on Jan 14, 2013
kakee
  • 1269 Answers
SOURCE: Setting Up the Netgear WGT624 as a bridge
Just disable the DHCP function of the Netgear router. Connect them from LAN port of 2wire to LAN port of Netgear.
Posted on Nov 25, 2008
  • 44 Answers
SOURCE: 2wire VPN over cisco router 800 series
yes.
when u bride modem you have to go inside ur cisco if u have ur 2wire bridge u should pick up a diffrent ip than 192.168.1.254 on the default gatewat | go to ur command prompt or DOS screen |
vista type CMD on ur search on the start menu at the bottom
xp go to RUN then type CMD | should brin up black screen
type in (ipconfig) look for default gateway |
go to ur browser and type that IP address on the address bar
should take u to ur cisco interfase | then should ask ur for a username and password try variation of admin admin or (blank) admin or admin (blank) that should get u in
if u see DHCP make it PPPoE then it should ask u for username and password from ur ISP or ur primary email address from ur ISP and password | that should do the trick
*****if u cant find username and PWD go to WAN setting manual settings then PPPoE and then USRname and PWD
rate me pls
Posted on Apr 11, 2009
  • 126 Answers
SOURCE: I have a 2wire 1000hg dsl modem and it is in
There should be a reset button on the back or side of the unit.
Using a paperclip, hold that button down for at least 30 seconds, which will reset it to the factory defaults.
Should do the trick!
Posted on Jul 14, 2009
  • 37 Answers
SOURCE: I have a wireless router type n and don't have
What is the standard of the router that you're using? The signal might be interferring or the location of your shop is too far from the router. Especially if the distance between is an open area. You might need a range extender for this.
Posted on Mar 01, 2010
  • 825 Answers
SOURCE: I want to extend the
Instead of removing the antenna from the router you can buy a cheap working second hand router in market (better buy a second hand belkin router, because belkin provides free lifetime phone support also free lifetime hardware support for certain routers whose model numbers starts with F5D or F6D....Dont buy any belkin routers with model number that starts with F7D)
Now configure the second router as an ACCESS POINT (you can call 18002235546 to get help to change to an access point)
run a long ethernet cable from dlink router to the second router (belkin)... you can place the belkin router anywhere where the cable can reach...
The belkin router will broadcast the signal and you will get better signal strength...
Posted on Feb 03, 2011
We have 2 desktop pc's. One in one room and the other in another room on the far side of the house. Both are connected to the same telephone line. The 2wire homeportal 100 hg died and I went to Radio Shack...
well in a hard spot if your using dialup as means of connecting to the internet then only one PC at a time can use dialup connections now if say it was a DSL modem then from the DSL modem or DSL Router Modem you would need RJ-45 cables from the DSL router modem to the two PCs
Apr 22, 2017 | 2wire HomePortal 1000HG DSL Modem and...
I have an AT&&T 2701HG-B Gateway 2Wire wireless router w/DSL modem. My Mac G5 computer is attached with an ethernet cable (my computer does not have wireless capability). All this is in my home...
there is an adaptor that you can buy
it is plugged into the power socket for the house , connected to the ether net connection
you have a second plug in connection that plugs into any other power point and that runs a ethernet cable to the pc or modem
I have such a system running from the shed computer to the house computer and modem distance of 100 yards
it is called a TP-Link and is available fro Jaycar or like electronic shops
it works by using the house wiring to transmit the data signal along with the house power
Mar 23, 2017 | 2wire (1000-400108-001) Router
I have a wireless router type n and don't have a signal in my shop building about 200 ft. away.my box says the range is up to 1200 ft.
Feb 28, 2010 | Computers & Internet
I am trying to figure out how to set up the engenius 1650 so I can wirelessly extend my internet connection to my shop 400ft. away from my d-link router at my house. Do I set it up as an access point or a...
Use the internal antenna, not the stick antenna, and point it directly at where your home router is. Set your PC to the hardcoded IP address 192.168.1.5, and browse to 192.168.1.1. Configure the 1650 into Bridge mode. (At this point, you may need to rebrowse to 192.168.1.2.) In the Wireless section, set it to look for the name (SSID) of your home router, and provide it with any WEP or WPA password needed to connect to your home router. In the TCP section, set it to accept an IP address from your home router via DHCP. Reboot the unit and set your PC to accept IP addresses from DHCP. You should receive an address from your home router and be able to use your home network.
The cable from the 1650 can attach to only one device, obviously. To get your other devices online, you will have to buy an (inexpensive) 10/100 ethernet switch and attach all the cables (including the one to the 1650) through it. That will serve all your devices.
Nov 22, 2009 | Computers & Internet
I have a 2wire 1000hg dsl modem and it is in bridge mode. Apparently I need to reset the modem (get it out of bridge mode) so I can access the settings page. How do I reset this modem?
Jul 13, 2009 | 2wire HomePortal 1000HG DSL Modem and...
I need 2Wire 1800HW without router
The best solution is to use it anyway. If your DSL supplier gave you the info to set up the modem, then the router should work. If you can get to the unit with your computer to set the modem up, the router will allow you to attach more computers.
May 28, 2009 | 2wire HomePortal 1000HG DSL Modem and...
Wireless router
I think 2wire routers are good in providing signal strength. Contact the 2wire vendor regarding your requirements.
take care
May 01, 2008 | AT&T High Speed DSL Modem
Tring to bridge my 2wire
Why do you need to bridge?
Can't you use both devices off the one router?
usually to bridge you would need, effectively , 2 extra access points to set as the bridges, they then connect to the other routers, allowing communication between the 2.
I do know 2wire is slightly different but you would still need something to act as a bridge on the netgear end.
I still don't understand why you need both routers running. Connect both your computers to the same router which has the internet connection.
Hope this helps
Tony
Feb 28, 2008 | 2wire 2700HG-B Router (2700HGB)
Can a 1800HG gateway in my garage/workshop link *wirelessly* to my 2wire 2700 HG-B wifi AP internet in the house?
try going onto http://192.168.1.254/xslt?PAGE=J30&THISPAGE=J29&NEXTPAGE=J30 on the computer connected to the 1800hg and set the router onto bridge mode (deselect enable routing). You might be able to set the two routers to connect then from here: http://192.168.1.254/xslt?PAGE=J09&THISPAGE=J30&NEXTPAGE=J09 or somewhere else in the MDC, not sure if it will work as I haven't tried it, but I hope it helps.
Feb 19, 2008 | 2wire 1800HG Router (RG1800HG00)
Computers & Internet Logo
66 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
