POLAROID PMP287C-8 NOT CHARGING
NEED TO KNOW IF THE BATTERY IS ON THE SCREEN DURING CHARGING FOR THE FIRST TIME AFTER OPENING THE PACKAGE
    Genius:
  • 1,669 Answers
Use the website to answer the question...I believe you need to charge the battery before operating:
http://search.aol.com/aol/search?&s_qt=sb&q=polaroid+pmp287c-8+owner%27s+manual&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
Posted on Jan 13, 2013
  • Donald Murray
    Donald Murray Jan 13, 2013
    YOU HAVE ANYMORE INFO ONIT AS FAR AS CHARGING DETAILS BECAUSE THE OWNERS MANUAL DONT TELL YOU NOTHING BUT CHARGE 3 TO 5 HOURS
  • Leigh Perlmutter
    Leigh Perlmutter Jan 13, 2013
    Sorry to say, there is very little free information out there.
I have been charging my new Brydge for longer than 3 hours and red light has never gone out . I did get the keyboard paired.
13 - To check battery life, press the battery key. The Delete key will flash three times:
Green = 75-100%
Yellow = 25-74%
Red = 10-24%
You need to charge it for about 8 hours on first use and not use it during that time of charging.
Product Instruction Manuals
Oct 05, 2017 | Radio Communications
Charging battery on Tablet which is totally dead
Depends on how long it sat for with no charge. LION batteries dont recharge from totally being dead if they are left discharged for long periods of time.
Jul 29, 2013 | Polaroid 7-in. Internet Tablet - Other
I have a Polaroid OneStep and am not sure if my film battery is dead or my camera is broken. I haven't used the camera in about 6 months, and at that time it was mostly working fine. Sometimes nothing...
Polaroid has not manufactured film for 600 cameras in about 5 years now. The only current source is The Impossible Project, which gives 8 shots per pack, black and white images only, and they tend to fade rather quickly. You can find and order online by searching the name. The Polaroid versions available are no longer really usable because the batteries are drained, film has expired and chempaks have oxidized.
The battery packs in these are integrated into the film pack and not replaceable separately.
Mar 11, 2011 | Polaroid 600 Film Camera
Have a Polaroid PMP280-4 MP3 player. I can't get it to charge!! Had it plugged into the computer all night and still won't turn on. It has worked in past. Just got it for Christmas and charged once!!
I have the same mp3 and had the same problem. The problem is over charging. The max time to charge is 8 hours. I left my player alone for about 1.5 months. Sometime during that time it reset itself, (not sure when, sorry). Anyway I picked it up the other day and now it works perfectly fine. Hope this helps.
Feb 06, 2011 | Audio Players & Recorders
Stopped taking pictures
How old is the film in camera & when did you put in the film?
Polaroid's battery is built in with the film package.
If the package is old or been in the camera for a long time battery may be low or dead.
Try changing film out.
Good Luck! Hope this helped. Please rate.
MSG back if you need more help.
Mar 11, 2009 | Polaroid OneStep Express Instant Camera
No B/W print while black cartridge is full.
Your printer and its software will let you know when an ink cartridge is low or expended.
If an ink cartridge is low or expended, you see a message on the Epson Stylus CX8400 LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until a cartridge needs replacement.
NOTE:
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the steps below to replace one or more ink cartridges that are low on ink, expended, or too old:
1. Turn on the printer.
If you're replacing a cartridge before you see a message on the LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
2. Open the scanner.
3. Open the cartridge cover.
4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
5. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.)
6. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge.
7. Remove the yellow tape from the bottom of the cartridge.
CAUTION:
Do not remove any other labels or seals, or ink will leak.
8. Insert the new cartridge into the holder and push it down until it clicks into place.
9. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place.
10. Close the scanner.
11. Press OK to begin charging the ink. This takes about 2 minutes.
When you see a completion message on the LCD display screen, ink charging is finished.
CAUTION:
Never turn off the printer while ink is charging or you'll waste ink. If you see an ink replacement message on the LCD display screen, press OK and press down all the cartridges securely.
Feb 02, 2009 | Epson CX8400 All-In-One InkJet Printer
102 people viewed this question
 Grubhead
Grubhead
