Question about Canon PIXMA MP130 All-In-One InkJet Printer
Cartridge jammed I have a problem with my printer (Pixma MP 130) . I tried to print or make a copy, by I always see sing Cartridge jammed. I check cartridges many times looks OK! Please help me! Thank you.
  • mikeymac7 Jan 29, 2009
    When attempting to print, display 'cartridge jammed press o.k.' is shown. upon checking. the black ink cartridge appears loose fitting in the top of the cartridge slot I have tried several new cartridges to no avail.
  • DarkSparkels May 19, 2009
    Soo often, my printer says 'Cartridge Jammed'
    The cartdrige is fine!!!
EUREKA! At least the following worked for me w/ this piece of sshhhh.....
went to menu - user data - cleaning..after the "cleaning' whatever that is...it worked. I also took out the cartridges and cleaned the ink contacts. hope it works out
Posted on Nov 19, 2009
    Genius:
  • 2,035 Answers
PLease follow these steps its same for cartridge jam and paper jam..
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Jan 23, 2009
My printer (mp 160 pixma) shows error code 5,3,2 what is the problem
E2 = Reload the paper correctly and press [Black] or [Color]
E3 = If paper has jammed in the machine, clear the jam, reload the paper in the
machine correctly and then press [Black] or [Color].
E5 = The FINE Cartridge may not be installed properly, or the Cartridge may notbe the compatible with this machine. Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the FINE Cartridge Alignment.
Nov 02, 2013 | Canon Pixma Mp160 Mp 160 Photo All-in-one...
My PIXMA MP 130 is not printing colour. The cartridge is new and genuine Canon. Please help.
Check to see that the "Greyscale" tab hasn't been set, and it is set for color printing this is in printer properties. Steps : **click on print **then a box will come up and select advanced options
and fine where it says print grayscale
** then select the color
May 30, 2011 | Canon Office Equipment & Supplies
I have a Canon Pixma MP 240 printer. It's been out of black ink. I installed a new ink cartridge. Now, there's an "E3" flashing on the screen. And it won't print anything.
Error E3 indicates that there is a paper jam.
Firstly remove the ink cartridge you have just installed and check to see if there are any bits of paper underneath that.
Secondly check the rest of the printer for any jams paying careful attention to any rollers as small bits of paper can get stuck to them.
Dec 17, 2010 | Canon PIXMA MP240 All-In-One InkJet...
I have a Pixma MP 470 that says there is a paper jam. I have turned if off and unpluged it for a long period and have also put card stock through it but there does not seem to be a paper jam. Is there...
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Nov 23, 2010 | Canon PIXMA MP470 All-in-One Printer
Won't print black ink text; looks like faint watermark print; ran all maintenance check several times (nozzle checks, etc)
Remove the black cartridge and soak it with an alcohol free window cleaner soaked paper towel let it sit on the towel for a good thirty minutes then wipe clean and put back in printer run nozzle check if necessary.
Oct 09, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Printer says put in cartridge
oh the joys of an hp. get some rubbing alcohol and a q-tip, clean the brass connection points on the catridge with alcohol, also, clean the brass connectors that are in the slot where the cartridge goes. Make sure to let them dry good and try again. We have an hp at work and we are always having to do this.
Jun 23, 2009 | HP PSC 1210 All-In-One InkJet Printer
I have PIXMA MP 600 PRINTER that has a paper jam as I fed used paper back into it /ink was still wet and apparently paper has stuck together and jammed. How do I clear
clear the jam paper
1) pull slowlly the jam paper back as possible as you can, usually the jam paper could be broken as pulling
2) open the cartridge area find the paper pull slowlly forword paper direction as possible as you can and try to take out any pieces paper behide the cartridge (between paper input roller and ink cartridge
Jan 24, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Cartridge jammed
So here it goes: Open the cover as if you would change the cartridge. Then press the little black button I highlighted in the picture. Keep it pressed, push “copy” on the left and then the (print) black button on the right of the lcd. The printer will somehow work and work. Wait until it rests again. Then close the cover and press the black button again. Now it should copy… and print, and so on.
Jan 04, 2009 | Canon PIXMA® MP530 All-In-One Printer
Cartridge jammed
my canon pixma mp 130 says it has a cartridge jammed...Ive tried new cartridges but still get the same situation
Aug 17, 2008 | Office Equipment & Supplies
Canon PIXMA MP130 All-In-One InkJet Printer Logo
723 people viewed this question
old marine
old marine
