Question about Panasonic DMRES15 DVD Recorder
Will not read disc
Unit will not play a disc
  • johnandsuz Jan 26, 2009
    We have the exact same problem. It makes a noise like an abrupt humm two or three times and says "no read." I took off the cover, cleaned the spindle, the laser and the thing that clamps the disc down. No luck. The noise is made when the laser contraption is moved up against the spindle. It makes this movement a couple of times, then says no read. I know this because I watched it's movement with the cover off. Is there anywhere you can buy commonly faulty parts for these things?
  • Panasonic Master
  • 19,396 Answers
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
To get parts try here.
Posted on Apr 21, 2009
Samsung V6800 when I install a disc the system comes back with "This disc an not be played - please check disc. How can I correct this
If the unit will not play any disc the unit is probably faulty and is just displaying a generic message triggered by the unit not being able to read the disc.
If only some discs will play and others don't, even though the format is the same, it could be the discs are of differing origins. I have experienced this before and assume the laser of some models aren't as powerful as others. Some players seem as though they don't play "cheaper" discs and others seem to play everything.
Jul 11, 2016 | Samsung DVD-V6800 DVD/VCR Combo
Not play toc reading message
If the Table of Contents is read by a disc that is good but the data that follows may not be compatible such as if it was a Mp3 encoded disc.
This was meant for the newer units that have decoders in them.
If you are playing a commercial made pressed disc- this is the kind you use for testing, then your pickup lens may be dirty or the disc is having too much wobble on the spindle. There are a lot of things to check and that is usually done by a technician who knows how to work on disc units.
Mar 24, 2013 | Tascam MD-350 Mini Disc Player
Samsung home cinema ht-330 dvds wont play no disc displayed
The most common reason is either a dirty or bad Optical Pickup unit in the player which is what reads the disc, and you will get no disc, cannot read disc etc.
Dec 20, 2012 | Samsung Audio Players & Recorders
Panasonic dvd recorder dmr-es15 cannot read disk
see this cause and remedies:
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
finally the OPU, optical pick up unit contain lasser beam, is not reading the TOC, can be defective.see the diagram
God bless you
Jul 16, 2012 | Panasonic Televison & Video
Cannot read disk
Does not play disc
Finally the OPU optical pickup unit contain lasser beam, NOT are reading the TOC from Disk, YOU Must go to the repair shop Tv FOR fix it.see the diagram
God bless you
Jul 16, 2012 | Panasonic DMR-ES10 DVD Recorder
Sony GDP s301 won't play any discs
see the cause and remedies:
Does not play disc
Finally the OPU, optical pickup unit contain too the lasser beam, NOT are reading the TOC of disk,+Syscon can be defective. You must go to the repair shop TV for fix it. this a complex equipment.
see tje block diagram.
God bless you
Jul 15, 2012 | Sony BDP-S300 Blu-Ray Disc Player
Tv won't read disc that have been played in it before
If you get a cannot read disc etc either you have a dirty or a bad optical pickup unit in the player--it reads the disc etc.
If bad cheaper to buy a new unit.
Jun 14, 2012 | Disney DTD1363-CAR 13" TV/DVD
Dvd disc not reading
Is it just that disk or are all the discs not reading?? If it is just that disc try cleaning the disc with a lint free soft towel. Also is the disc a factory dvd or a burnt copy of media. Some dvd players will not play certain re-write discs some play DVD-R and some play DVD+R and some will play both ... good luck
Oct 19, 2009 | Audio Players & Recorders
Playstation 2 won't play DVDs
if it's a fat PS2 and
model SCPH 30001, SCPH 35001
(not including the models with an 'R' after the model #.
these models need the following to play DVDs:
- PS2 DVD remote with IR unit
- PS2 DVD disc player (sold with DVD remote w/ IR unit)
- PS2 memory card
you copied the DVD disc to the memory card. you used the memory card to play DVDs.
later models didn't need the memory card to play DVDs.
hope this helps :D
Jul 16, 2009 | Sony PlayStation 2 (PS2) Console
SRD4900 Sylvania DVD/VCR Combo
Well first of all, why the hell would you press play when there was nothing in it???
Feb 01, 2008 | Durabrand DUR7 Portable DVD Player
Panasonic DMRES15 DVD Recorder Logo
239 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
