Question about Toto Dartmouth 2pc. E/F Toilet CST754SF-01
Toto Dartmouth toilet flapper/chain design flaw
I have a toto toilet. The flapper/chain and handle rod layout is such that the flapper is pulled sideways when the toilet is flushed, not pulled straight up, but sideways. That is the design. The problem; the flapper must return itself and square up on the hole to properly seal. Sometimes it works, sometimes it doesn't and the toilet runs. The flapper is perfect, not worn. The toilet has done this since new. If I didn't bend the rod to somewhat lessen the sideways pull, it would be worse. Design problem, bad layout. A new replacement rod with an offset would fix it. Any available? Why would someone layout a flush systems where the flapper is pulled sideways and must fight to return to proper seating position? Anyone?
  • Anonymous Mar 24, 2009
    We do have the same problem, TOTO do not consistence on their product. They use other system. Rubber Flapper could not find anymore on the market.
  • Anonymous Mar 23, 2014
    toilet doesn't flush complety
  • 979 Answers
Your right this is a poor design. Space was the main reason for this and functionality was sacrificed. However, you can get a replacement rod at a major plumbing store. You could rig it by attaching a stem to the valve assembly. Allow the chain or rubber piece to slide over it. It is kind of like putting a permanent finger in the path of the chain to give it a "direct" lift up. This would then force the chain to go up instead of at an angle.
Posted on Jan 28, 2009
How do i reconnect the chain to the flapper? i can't see a place to connect on the flapper and the chain isn't open on the end link.
You need a new flapper. They are about 5 dollars at home depot it will come with chain already attached.
Nov 30, 2010 | Toto Dartmouth 2pc. E/F Toilet ...
HAve to hold the flush handle down for several
change and or adjust the flapper valve if the chain is to long flapper wont stay open long enough for the water to drain into the bowl
May 30, 2010 | Toto CST414M-11 Aquia Dual Flush Elongated...
Flush problem with toto toilet
If your hooked to city water it can be cause of the high water pressure comes across and keeps flapper from seating rite. Take a empty plastic bottle,cut it in half long ways. flush toilet then place plastic bottle between fill valve and flapper,trying to devert water away from where flapper seats. good luck.
Jul 23, 2009 | Toto Dartmouth 2pc. E/F Toilet ...
Toto flush handle problem
did you try a new flapper? sometimes those are the reason they wont flush properly. check out the american standard cadet 3 it's half as much as a toto and works just as well
Jul 13, 2009 | Toto Dartmouth 2pc. E/F Toilet ...
Toto toilet, flapper doesn't stay up long enough to flush
One of two things is the problem. First, make sure that you have a tight chain with little slack. If there's too much slack, the flapper won't catch in the passing air to stay up. Second, the flapper is not correct for that style of toilet. You might want to look into purchasing a new Kolby filter that has a removeable cone in the center. Move that cone to 12 o'clock to allow the maximum amount of water to run through the flush valve. If the flapper you have now is flat, it needs to have a cone in the center on the underside.
Jul 09, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
Toto toilet ultra max flush
Open the tank and examine the linkages between the handle and the flapper. If the handle is sticking, it sounds like there may be either mineral buildup or a stuck chain.
May 27, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
Toto Dartmouth 2pc. E/F Toilet  CST754SF-01 Logo
1,043 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
