Question about Coffee Makers & Espresso Machines
Unable to set clock on out-of-the box Mr. Coffee PSTX
SOURCE: setting the clock on my coffee maker
After turning the coffee maker on press and hold down the timer button until flashing; then press the hour and minute buttons to set the clock.
Posted on Dec 20, 2008
  • 112 Answers
SOURCE: maker clicks on, but doesn't perk or heat the plate.
Unlike older coffee makers, the new Mr. Coffee designs seem to have reliability issues in regard to their circuit boards/controllers. You are right in your thoughts. If the unit is under warranty, I would suggest returning it for a replacement. E-mail your concerns directly to the company.
BTW--there are no user serviceable items within your coffee maker.
Posted on Mar 26, 2009
SOURCE: Brand new Mr coffee PSTX
If you look where the reservior fits into the base, specifically where the water goes in, there is a rubber seal. It's held in by a circulary plastic piece and 3 screws. I took it apart there to see if something was amiss and decided after looking at it some that they had put the seal in upside down. So I put it back together with the lip of the seal facing up instead of down and I have not had a single drop of water leak from the reservior again. Now if I can get the thermos pot that came with it to stop leaking every time I pour a cup I will be a happy camper.
Posted on Jan 30, 2011
  • 5165 Answers
SOURCE: All I need is the
First set the clock on the brewer with the unit plugged in. Press and hold the Hour and Minute buttons until the current time is set. Next press the Delay Brew button while using the Hour and Minute buttons to reach the time you want the coffee to begin brewing.
Set up the coffee maker with ground coffee or beans and sufficient water in the reservoir then follow the directions below.
For brewing with fresh ground beans, press and hold the Delay Brew button until it flashes then press Select once. The Grind and Brew light should come on and the Delay Brew light should become steady.
For ground coffee, press and hold the Delay Brew button and then press Select twice. The Brew Only light and the Delay Brew light should both be on and steady.
Most Mr. Coffee product manuals are here: http://www.mrcoffee.com/InstructionManuals.aspx . The direct link to the GBX23 manual is http://www.mrcoffee.com/Manuals/MANUALS/GBX23_43_50118420.PDF .
I hope this helps.
Posted on Aug 20, 2011
mc1bean
  • 3053 Answers
SOURCE: HOW TO SET THE DELAY AND THE CLOCK ON A MR COFFEE
Hello, james
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about CoffeeMakers and possibly yours, from
repair to trouble shooting it. b>http://home.howstuffworks.com/coffee-maker4.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 29, 2011
How can you reset the time on a Mr. Coffee PSTX brewer?
I believe you use the hour and minute buttons to advance the time to the desired setting. If you hold the program button down and then use the hour minute buttons you set the brew start time. Hope this helps. Good luck.
Jan 10, 2015 | Mr. Coffee Coffee Makers & Espresso...
The coffee is not hot. I have PSTX series.
Does the bottom surface that the carafe sits on get hot. Too hot to touch? If not there may be a wiring problem. If it is a new machine, I would return it for another. Hope this helps.
Dec 25, 2014 | Mr. Coffee 12-Cup Programmable Coffeemaker
Just purchased a PSTX series coffee maker. It is really fast and has the SS carafe. My question is, does it have a warmer or does it just rely on the SS to keep the coffee warm?
No in the BVMC-PSTX90 or 95 series.
If this is your model, Is a good coffee maker.
If you are NOT drinking your fresh brewed coffee withing 25 min. YOU DON'T WANT a warmer/burner.
And the reason why, IT BURNS the coffee. You don't have this problem with the "thermal Carafe".
Jan 11, 2011 | Mr. Coffee 072179228578 12 Cup Coffee...
I have a PSTX Series of Mr. Coffee and the clean light is on. I have cleaned the coffee machine and light still won't go out. I even unplugged it for awhile and it still comes on after I make a pot of...
Had the same issue. You have to let it run a cleaning cycle before before the light goes off. Turn machine off, empty pot, add 4 cup cleaning solution and hit the clean button (not the brew button). Let it go through this slow cycle like it says in the manual and it should reset itself.
Oct 08, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Miele CVA- 4075
You need a new Elektronik. The one in the back of the Coffee maschine has to be changed. There is a technical Problem in the Clock Module.
Greeteings ....
Mr. Cool
Dec 02, 2008 | Miele CVA2660 Stainless Steel Coffee Maker
Coffee Makers & Espresso Machines Logo
318 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
