Question about Logitech Z130
My Logitech Z130 speakers suddenly stopped working, Missing driver
Yesterday, they suddenly stopped working, the green light was on but it said they weren't connected to the computer, I looked into control panel to find that they are unrecognized for some reason and to make them work again i would need to reinstall the driver, I have no box or discs that came with the speakers and a driver could not be automatically found, when I searched manually I had no idea what the driver would be called so I couldn't find anything of use, I need some way of obtaining the driver for the speakers, and that should make them work again, If nobody can tell me how to get the driver, could somebody please atleast let me know what it's called?
sandrew
  • 2961 Answers
SOURCE: My computer wont detect my speakers!!!!!
Applogies for whoever the idiot is on other sarcastic solution, as it rears it's ugly head every now and then. The problem won't be your speakers, but the sound or audio driver. if you post your pc or notebook details and operating system back here, I will try to point you in the right direction.
Posted on Feb 22, 2007
SOURCE: logitech z560 set up help
The 4 satilite speakers are all the same. You can get new speaker wire at the local Radio Shck or electronics store. They just recomend an 18 gauge wire. When you wire them the red terminal on the speaker is hooked to the red terminal of the sub woofer speaker. On the back of you volume controller there is a place to plug in the wires from your sound card or motherboard. One cable will do the front speakers and another one will do the rear speakers.
Hope this helps.
Posted on Aug 31, 2008
SOURCE: no sound
FOR MACS... Last February(08) I bought the V20 Logitech speakers for my Apple iBook laptop. I got them to work. Hadn't used them for about a year and had forgotten how to get the sound to emerge. I went to System Preferences. Clicked on Sound. I had plugged in the USB. Didn't show up. Unplugged it and plugged in again and there it was! I clicked on it and the sound came through immediately. So wait to plug in the speakers until you have opened Sound. (And Pandora (superb Internet radio station) is playing flawlessly.) I am not familiar with PCs. Sorry.
Posted on Jan 27, 2009
SOURCE: Right speaker doesn't work
I had this very same problem and I had my system for about 2 weeks. I have seen a lot of similar posts on this site so it seems that this problems happens a lot. For some reason my right speaker just stopped working so i came to this site for help. I looked at alot of posts and nothing fixed the problem. when i switched the right speaker to the left input it started to work so I knew the speakers were fine. So i finally decided to unplug everything and restart my laptop. Once my laptop rebooted I plugged the sub back into the wall after about a minute of it being not plugged in. Then I plugged all the the wires and volume control back into the sub and turned the switch back on. Make sure the volume control is down when you plug everything back in. Then plug the wire into the device, which in my case was a laptop, and start to play some tunes. Right away everything was working perfectly fine again and no problems ever since...for me atleast.
HOPE THIS HELPS
Posted on Feb 18, 2009
SOURCE: Logitech Z-5450 5.1 surround sound speakers - no sound from rear right only
Unfortunately I have the same problem. As an electronic engineer I suspect that the power supply part of the unit is damaged. I opened up the module (don' t try it, its a little bit tricky since there is a type of glue around the silver bezel, after you remove the 4 screws from the front holes) and did some quick static measurements with a multimeter, so far no luck. Since I am still in warranty I will try to replace the item. Hint: protect your electronic equipment with ups or surge protection devices.
Posted on Jun 28, 2009
Are the z130 Logitech speakers for laptop
No. Any computer with a sound card will work them.
Oct 01, 2014 | Logitech New-980000417 - Z130 Compact...
How to connect z130 speakers to dell Inspiron 660
Connect the cable coming off of the z130 speakers to the GREEN port in the back of the computer. There should be 3 ports all there together(see below). The GREEN one is the one for your audio speakers. c1bb1df7-b62a-40ab-a588-fe9f02f1fe07.jpg
Oct 14, 2013 | Dell Inspiron Computers & Internet
Z130 speakers keep blinking
Sounds like you have it in tuning mode & or pairing mode, provide me with some more info and i can help out
Oct 30, 2017 | Logitech Z130
My logitech z130 speakers suddenly stopped working. I use them frequently with my laptop. they worked perfectly, but 10 min. later i tried to use them and the green light would not come on. i wiggled the...
sounds like the inner cable is broken,either at the speaker end or the jack plug. but if there new take them back to the shop they should be under guarentee
Sep 16, 2011 | Logitech Z130
Where on my computer do i plug in the speakers i have a hp windows 7
Hello
Look for the "line out" socket. It is the audio out terminal of you computer. OK
Jul 08, 2011 | Logitech Z130
I have the Logitech Z130 speakers, and the left speaker does not emit any sound. Is this perhaps due to bad connections inside the speaker? If so, how do I open the case?
could also be a damaged wire, check that first by "feeling up" the wires, does it feel cut or interrupted somewhere? if not, you can open the speakers by lifting or prying out the rubber cushions on the bottom side and removing the screws. Remember this voids your warranty, if it's still applicable.
May 06, 2011 | Logitech Z130
Do not know why it is not putting out sound wich jack do i install into on a hp p6754y desktop it has 6 diffferent options
Usually if there is only one cord coming from the speakers it is green and that fits into the green port on the motherboard, the reast are there for Mic and 5:1 sound
Feb 12, 2011 | Logitech Z130
Where to connect 3.5 mm connector to Dell PC?
green coloured port on the rear of the motherboard
Feb 07, 2011 | Logitech Z130
I have logitech Z130 and they dont work
I DON'T HAVE A SOLUTION THEY JUSTWON'T WORK..........
Oct 16, 2010 | Logitech Audio Players & Recorders
Logitech Z130 Logo
80 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
