Question about Prolink PixelView PlayTVpro Video Capture
Adding deinterlacer failed
Not found for video
What causes the trunk not to open on Ford Focus 2003?
Here's a video I made on what all I found wrong with mine. First you want to make sure the fuse is not blown. I had to clean my trunk latch button and I show how to do that in the video. I also found the wires going to the trunk latch had split insulation and I show where I found that problem in the video.
May 31, 2014 | 2003 Ford Focus
I found a optimus digital video cam I need download the driver
http://download.driverguide.com/driver/dv3040-dv3045/Other+Companies/d1454852.html
I found the above link by searching google.com under 'dv-3040 driver' on the Internet.
Other links were found as well, for a free download of software driver for the optimus digital video cam.
Feb 04, 2011 | Optimus DV-3040 Flash Media Camcorder
Why doesnt my tv recieve signal from my ps3
Your tv might not receive a signal for a variety of reason.
a. You have the RCA (yellow,white,red) cables plugged in the wrong way
b. Your ps3 hasn't recognized your video due to using an hdmi cable and switching around with the settings on your ps3.
c. you have changed the video settings on your ps3 and is now set to the wrong video output.
d. the cables have become defective and you need to purchase a new one.
e. the ps3 has malfunctioned and wont take video anymore.
f. the tv input is set wrong. make sure all RCA cables are found in "video output", all hdmi cables are found in "HDMI", and all VGA cables are found under "PC".
Your guess on the problem is as good as mine.
I hope everything goes better for you : )
Dec 30, 2010 | Video Game Consoles & Games
How do I connect a camera to my pavilion n5430?
Follow these steps :
Identify the ports you have on your computer and video camera. Typically there will be a small door or flap at the rear or near the bottom that covers the ports. You computer may have ports in the front as well as the rear. You video camera may have more than one of these ports and may not have all of them.
Find the i.LINK port. i.LINK is
version of IEEE-1394 standard (aka) Firewire. It is commonly found on DV (Digital Video) varieties of camcorders. You may find the smaller 4 pin connector on your camera if it is a compact video camera. Typically the larger 6 pin variety is found on computers and larger camcorders. i.LINK transfers both video and audio. For more information click on "How i.LINK Works" in the Resources section.
Find the USB port. USB (Universal Serial Bus) is another connector like i.LINK for transferring digital video and audio. Typically a mini USB connector such as the "Mini-A" will be found on your camcorder than large flat "Type A" connector typically found on computers.
Locate the S-Video jack. The S-Video jack is a round 4 pin analog connector. S-Video is for only video transmission. You will need to connect the red and white audio RCA jacks or use a phono port to transfer the audio to your computer.
5
Find RCA Audio/Video Jacks. These round single pin ports usually are found in a set of three of different colors. Yellow is video, red is for right audio, and white is for left audio. On some Handycam's, there may be a mini-plug that is an all in one Audio/Video jack that you plug in a special cable (as seen in the photo) that connects your camera to standard yellow, red, and white RCA jacks on your computer.
6
Choose a matching pair of ports you have on both your computer and your camcorder.
7
Turn both your computer and camcorder off.
8
Connect your computer and camcorder with the appropriate cable. Turn on both your camcorder and your computer.
Nov 20, 2010 | Computers & Internet
Not found you tube vedio
search for a proper video........and if you not found it means that youtube has no video on that
Apr 16, 2010 | YouTube Videos
Video playback
The playback for the videos is the same as the photos. Once you are in playback mode, use the directional button to go left or right to find the video, once you found it press "up" on the directional button to start the video.
Aug 13, 2009 | Polaroid i733LP Digital Camera
I found the s video cable, checked it, it's fine. Still b & w
If you haven't reset the media center yet, do so. (unplug the DC power cable for 30+ seconds from the back of the media center OR the vs2 enhancer, and not the wall/outlet) If you still have black and white video, check the format and make sure it's set to NTSC. -the Video format can be found in the system menu (by pressing 'system') under Video.
The s-video cable can cause black and white video if it's loose at the s-video out on the media center, so I'm surprised that this didn't fix the issue. The 'quadra cable' that it belongs may need to be replaced. -Bose also has very good tech support, and I'd be surprised if they can't figure it out over the phone either.. But still, check the format and reset until then.
Jun 13, 2009 | Bose Lifestyle 48 System
No Audio device found and cannot found any video controller drivr
Well if you reinstalled the operating system you need to install the drivers for all the hardware that is on the motherboard, You need drivers for, chipset, Graphic's, sound, lan, If you go to the website
of the maker of your motherboard they will have all the drivers you need.
Mar 29, 2009 | Asrock 775i65G Motherboard
Televison & Video Logo
130 people viewed this question
Top Prolink Televison & Video Experts
vbalag
Level 1 Expert
Tony
Computer Links
Are you a Prolink Televison and Video Expert? Answer questions, earn points and help others
