Question about Samsung SyncMaster 19 in. LCD HDTV
Samsung syncmaster 933hd back removal - Samsung SyncMaster 19 in. LCD HDTV
  • Rob Taylor Jan 14, 2013
    Thought i would post my own solution as I managed it myself in the end.The back is simply clipped in to place all round the sides, remove the stand fixing, struggle but a good firm hand and it comes away. The clips are located in the gap beween the front and back case. Look carefully for the gap and with a small thin screwdriver prise the two pieces apart being careful not to split the plastic. It will sound as though its snapping...I started at the lower right side looking at the back, work your way round and the top edge, about 4 clips per side, the back then simply pops off, putting it back I located the top edge first then pushed firmly down each side until it clipped back. FYI the circuit board is loose inside the case just located on the case edges and screen back behind a protective metal cover, its worth being careful not to turn it over without holding it in place and dislodging the cables and connectors. There is nothing to see unless you disconnect the cables and carefully turn the board over, you can then view the component side, to see the soldered side required a braver effort with screwdrivers....and more hands to hold things in place. Rob
  • Rob Taylor Jan 15, 2013
    all sorted now, see above, needed to be a little braver. Rob
3 Suggested Answers
Sahill
  • 23 Answers
SOURCE: Removing the back cover of a Samsung SyncMaster 753s
there is 2 lock on front side first remove back side lock or scrow then insert small pin pull up back cover your monitor will get open
ashok
Posted on Jan 21, 2008
  • 524 Answers
SOURCE: what is the sky remote control for Samsung
Hi
Samsung
4 digits: 0060
3 digits: 065, 584, 037, 245, 476, 398, 516, 292, 318,037
Samsung (6000 series)
4 digits: 1340
As you used 0060 and it didnt respond please try to programma with the other 3 didgit codes.
If still you cannot programme it follow the below instruction:
1. To control your TV firstly switch on the TV set, point the Sky remote at the TV,
2. Press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice.
3. Continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will start using the inbuilt codes to programme the remote.
Thanx
Posted on Jul 27, 2010
Where can i get the living solutions jumbo universal remote code for the samsung syncmaster 1701 mp tv
You should use the search remote code feature:
  1. Hold the device button you want to program for 3 seconds & release.
  2. Push & release the power button & the red light will remain lit.
  3. Push the CHANNEL UP button over & over slowly until the device turns off.
  4. When device turns off press OK button.
Hopefully that works for you.
Jan 07, 2015 | Samsung Televison & Video
I am trying to retune my mother-in-law's tv, and don't have a manual. If I go into the menu, and try and open the "Satellite dish" icon - it won't let me. The curser just goes past it.
Sometimes, the manufacturer removes the user manual from their website in the case of older device models. If this is the case with the Samsung 933HD, you can find a backup here:
Samsung Syncmaster 933HD manual
Jan 28, 2014 | Samsung 933HD 19 in. LCD TV
Samsung 933hd tv. . .once i plugged it it turns on and it gives the sound but the whole screen turns white. . .any suggestions?
The screen turns white because defective T-Con. Mostly 19 inch model doesn't have PCB T-Con. My suggestions is , call samsung cervice center.
Mar 14, 2011 | Samsung 933HD 19 in. LCD TV
We have a samsung 933hd. when we switch on, we get a picture and sound but lose picture after 1 second. Can't get anything on screen even using remote. Switch off then back on and same again , sound ok but...
This is a power supply problem. If the set is under warranty, exchange it.
If you warranty is expired, you can take it to a repair shop and get an estimate to see if it is worth fixing.
Feb 10, 2011 | Samsung 933HD+1 19 in. TV
NEED A OWNERS MANUAL
http://www.nodevice.com/user_manual/samsung/monitors1/933hd.html
Jan 28, 2011 | Samsung 933HD 19 in. LCD TV
How do you remove the stand on a samsung 19inch lcd tv..
There are 4-6 screws that must be removed. look on the rear of the TV for screws at the base of fairly deep holes. They require a #2 phillips head screw driver. Remove all of the screws and then get a friend to hold the base whild you pull the tv straight up about 6-7 inches. Joe
Mar 29, 2010 | Samsung 933HD 19 in. LCD TV
Samsung 933HD TV and the blue light comes on when the TV is off
Look at the power supply first; look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find
Dec 15, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
How to do a manual channel tune on a Samsung 933HD TV
in every remote there is a button that leads u to the digital setup. you have 2 options in it. manual or automatic. go for automatic. rest is done automatically. good luck!
Nov 01, 2009 | Televison & Video
ashok
Jan 20, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung SyncMaster 19 in. LCD HDTV Logo
400 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
