Question about Dell Vostro 1710 Laptop
Can not boot ,,,i get error utility partion not found
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 77 Answers
Install new window in system partition
Posted on Jan 13, 2013
3 Suggested Answers
  • 4 Answers
SOURCE: no internal hard disk found during booting when i am going to format
It is possible that the HD has failed completely. However, this is a relatively new laptop, so I would suspect that is not the case. Sometimes the HD will lose contact for one reason or another. This can usually be cured by removing the HD and reinstalling it, which will remove any crud from the contacts.
http://www.fixya.com/support/t1639067-reseat_hard_drive
If the machine is still under warranty, call Dell support. They will walk you through diagnostics to determine the actual problem.
If you're not sure of the warranty status, go here:
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?c=us&l=en&s=gen
HTH
Posted on May 24, 2009
leecom72
  • 4806 Answers
Hi there.
Use the Vista CD to create the new partition, but first you have to delete the old partition first, (the 220GB partition not the 10GB one because that will be the recovery partition).
Get a calculator and work out your new partition, for example 50GB is 50x1024MB so that will be 51200MB.
When you have deleted the 220GB partition select NEW and input your newly worked out partition and carry on from there, to activate the other partition just format it.
Please post back with the results and for anymore help if needed.
Good luck and thanks for using FixYa!!
Windows 8.1 x64 dvd won't boot on UEFI pre-installed Ubuntu laptop
not sure on this one Ubuntu likes to be installed last after windows is set up. I would think that you would have to blow away the ubuntu partitions by resizing the partitions to one partion. But you would want to be extremely careful not to touch the hidden recovery partition. You could use a program called gparted to see what the partions are and resize the partion. Extreme caution is needed as if you get it wrong you will not be able to undo it. The problem you are experiencing is because the boot loader is ubuntu grub. You will need another computer to download a gparted iso file and then use infrarecorder to make a boot cd. it can be found at http://gparted.org/ see http://www.ehow.com/how_6540931_remove-ubuntu.html
see also https://help.ubuntu.com/community/OS-Uninstaller
not sure if it will work on version 14
Aug 04, 2014 | NEO Computers & Internet
I have an old laptop that partition and hd have been reformatted. I've tried using boot disk but keep getting the message that says, ''save to disk partition not found. So, can't get win98se to load as...
Haven't used win98 for a while so bear with me and this uses DOS COMMANDS too.
If useing restore cd/floppy you have to use a utility from compaq that creates two partitions on hard-drive.
They may have a restore floppy if you need it too.
One for "recovery files" and one for "OS Boot"
AHH, the memories, I still have my 95/98/ME Laptops up and running for older stuff. HP n CQ too.
Restore CD should do it all though.
If no restore CD - have Win98 CD?
if Harddrive partitioned and formated - Just do 1
1. boot from Win98 CD.
Partition n Format
2. Choose boot to DOS (puts u in virtual drive A)
AT PROMPT
3. Type drive letter of CD ( C: D: or E: )
4. Type CD Win98
5. Type Fdisk ( to partion drive)
reboot n do 1 + 2
6. Type format C: ( I do this to ckeck drive for errors)
OR
JUST Boot from CD and follow install instructions.
1 to 6 for if you have problem with Win98 CD setting up Harddrive.
Apr 04, 2010 | Compaq Presario 2140US Notebook
Fujitsu lifebook will not bootup. Message says "operating system not found."
Couple of things here, 1. Your os/nos is missing or 2. your boot files have been moved to another partion and the server has not been directed where to look.
Solutions: reinstall the os/nos or find the correct partition which has the boot sector and direct the server to boot from that partion. (This partition should be partition 0.
Good Luck
C2Solutions
Jan 23, 2010 | Fujitsu Siemens Siemens PRIMERGY B210...
I HAVE AN EEE PC AND KEEP GETTING AN ERROR MESSAGE SAYING 'EEE PC TRAY UTILITY HAS ENCOUNTERED A PROBLEM. ERROR TYPE:BEX P1:AsTRAY.EXE P2:5.1.13018 P3:4886b209 P4:AsTRAY.EXE P5:5.1.1.3018
first make a image of the partition using norton ghost. (you cand find it on a hirens boot cd), next uninstall the tray utility. if it is still the same problem, try reinstalling the operating system. if not reinstall the utility and see if it works. if it doesn't works and you don't want to reinstall the operating system, remake your partion from the image created initially using norton ghost
Dec 08, 2009 | ASUS Eee PC 900HD Netbook
Would like to format my toshiba laptop a45-s250 and install xp
First you need a windows os cd with original key, then turn on computer and boot from cd, then when booted from cd choose enter, then f8, and look on the bottom of the screen, if the hdd have a partion choose delete partition, if not choose install and the disk will start to format, after that it will install windows clean.
Jul 08, 2009 | Computers & Internet
No internal hard disk found during booting when i am going to format
HTH
May 24, 2009 | Dell Inspiron 1525 Notebook
Factory image recovery on hp error 0x4001100200001005 when useing the recovery disk to go back to factory only loads up to 33%
I had the same problem with the recovery cd getting to 83% and giving me the 0x4001100200001005 error. I did 2 things. I cleaned the disk it was erroring on and also removed the ethernet cable from the adapter. I have been working for 4 days on this and parsing the internet for answers. Finally it worked. I don't know if it was the cleaning of the disk...which did not look dirty, or the unplugging the network cable.
Nov 07, 2008 | Computers & Internet
Partition Magic Software Error #983
Re: Error 983 while using Partition Magic Error 983: "Too many errors found, process halted"
http://service1.symantec.com/SUPPOR...gic&svy=&csm=no
Utilize the following maintenance programs before using Partition Magic:
Description of the Disk Cleanup Tool in Windows XP
http://support.microsoft.com/defaul...2&Product=winxp
How to Perform Disk Error Checking in Windows XP
http://support.microsoft.com/defaul...5&Product=winxp
HOW TO: Analyze and Defragment a Disk in Windows XP
http://support.microsoft.com/defaul...1&Product=winxp
Mar 31, 2008 | Computers & Internet
U3 launch pad error
Download Gparted disk partion tool, use the bootable ISO burn disk. Now boot PC with gparted and on the desktop is a icon for mounting usb drives, use this to mount the usb stick.Follow the instructions, when asked to install gparted on disk exit window by using "q+enter" key.
Now start the partion tool and mount usb drive and partion and format.
An alternative method is to use the partion tool found in most linux distributions such as in puppy or mepis.
Mar 19, 2008 | Electronics - Others
When I turn on starts shows microsoft windows then goess to startup repairs
formattt that hard drive sound like bad secters in hd run xp dish cheak chdisk u know to fix those bad secters on hd froma bug or sumthign best best u have orginal xp cd not recovery dish operting system disk boot into that del partions make new one then formatt it then install xp fresh update it so on ok
Jan 24, 2008 | Computers & Internet
Dell Vostro 1710 Laptop Logo
24 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
