Hi have a fujitsu asta18 that is dripping water from indoor head unit , drain all good water runs away perfectly , but water coming from the air chute and through the louvres seems to be condensating on the plastic !!! Any ideas please as pulled all hair out Thanks
    Scholar:
  • 67 Answers
I would say that either your unit is short of gas, which is weird because you would of also said the unit has been loosing effiency or I would say that your unit is not level or has came of the back plate. If you pour water on the coil and it drains, I would say that your unit has a gas issue.
If you would like to know anymore please let me know
Posted on Jan 23, 2009
How do I stop water from dripping from Fujitsu Halcyon ASU18T indoor unit?
Unblock the drain tube and make sure the unit is not level. Condensate needs to run to the rear of the unit by gravity to drain properly.
Oct 01, 2014 | Heating & Cooling
Our fujitsu reverse cycle AC is leaking water at bottom left hand side of the internally mounted blower unit
Your drain for the inside unit is stopped up and the water condensate that drips off of the coils when the AC is running has no where to go, so it drips off of the collection channel and over flows to the bottom of the air handler, gravity dictates the place where it leaks. You are going to have to unstop the drain.
Feb 01, 2011 | Fujitsu 24C1 Air Conditioner
Water dripping from air conditioner
It's because of non-maintained air conditioner. Clean air filter, indoor coil, blower wheel and also drain pan. Insulate freon pipelines properly and tightly. After that run the a/c. If still water dripping. Check indoor f.motor speed. If less replace capacitor. If f.m. is o.k, check gas pressure. If less, there will be ice formation over the coil and water dripping will be there when it melting. If short of gas, check for leak and rectify. Thanks. Helpful?
Jan 16, 2011 | Fujitsu Heating & Cooling
If the units temp drops lower than 27 degrees water pours out through the vent indoors
Clean air filter,indoor coil and also drain pan. And also check drain hose is not merged. Also check your blower fan speed. If it's running at less rpm change capacitor.
Dec 11, 2010 | Fujitsu Heating & Cooling
Water in the drip pan- what is causing it?
I assume you are talking about the indoor unit. One function of the a/c system is to dehumidify the air. Condensation forms on the cooling coil and runs to the drip pan. There should be a drain line on the drip pan that drains the pan outside. These sometimes become clogged causing the water level in the pan to rise. Try some mild drain cleaner to open the line. Hope this helps. Let me know what you find.
May 21, 2010 | Carrier 38CKC036 Air Conditioner
Water is dripping out of the indoor unit on to the floor unit had only been turned on for about 1/2 hr this happened about a week ago but after cleaning the filters problem seemed to go away has now...
Hi
Check if the water drain pipe is not blocked. Or if the water drain pipe is not sloping downward away from the the unit. Or if the inside unit is level or slightly tilted to the side of the water drain pipe.
Jan 25, 2010 | Heating & Cooling
Water dripping from air con use
If the unit is mounted on an outside wall check the condensate drain that comes out with the line-set to the outdoor unit. If the pipping goes up into the attic than you have a small condensate pump that may have failed. The float in the pump may have stuck in the down position not allowing the pump to come on.
Nov 08, 2009 | Fujitsu 24C1 Air Conditioner
Too much water condensation
Check your condensate drain. It could be plugged. Or perhaps you have a crack in the drain pan.
Jun 21, 2009 | Ruud UAKA037 Air Conditioner
Leaking water
water leakage from indoor unit
1.clean cooling coil
2. wash air filter
3. check drain tray.if it block then clean it
4. check drain pipe U band.
5.check indoor unit water tray.if damage change by new one or repair it
Sep 04, 2007 | Friedrich QuietMaster RS10J10 Air...
Heating & Cooling Logo
224 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
