Question about Garden
Why isn't my 16 hp Wisconsin lawn mower engine
    Sergeant:
  • 322 Answers
There could be a couple different things causing a no spark situation. First, replace the spark plug and try it, if that isn't it disconnect the ground circuit from the ignition module, if that's not it then replace the module, if after you remove the ground circuit it works then you have a bad wire that needs to be replaced
Posted on Jan 16, 2013
5 Suggested Answers
  • 59 Answers
SOURCE: My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
Posted on Jun 26, 2009
nobby63
  • 10 Answers
SOURCE: lawn mower stalls when engine is hot
first thing is to check that plug is not fowling up when hot due to motor burning to much oil.
Posted on Jul 26, 2009
  • 88 Answers
SOURCE: no spark from spark plug in honda lawn mower
the pionts could be bad try changing them
Posted on Aug 30, 2009
  • 61 Answers
SOURCE: lawn mower pull cord
This works best with two people. Remove cover and pull cord will be inside cover. If your handle on pull cord is attatched to a metal ring up on the handle, you will need 8 foot of new pull cord.
With all the old cord removed, wind cord pulley 6 revolunations, now, have someone hold the pulley, while you string the new cord thru pulley and out the cord hole on cover. Be sure to put a knot on the end going thru pulley. Draw cord all the way thru and out of the cover. Attatch the handle and let it rewind. You will have extra cord, this will be used up going from engine up the handle. I hope this helps
Posted on May 09, 2010
Pull string won't recoil
its your Recoil spring that is causing it to do what it is doing it may have came off or broke
Jun 07, 2013 | Garden
Kolher 16 hp motor no spark
check the safety switches going to the engine disconnect the harness to the engine and see if you get spark i assume it's on a mower check the safety switch on the clutch/brake pedal
Jun 08, 2012 | Garden
Honda mower won't pull start
you will need to find out if you are getting a spark. generally cheap to fix it you just need to find out which part isnt working first
Jun 03, 2012 | Honda Gxv160 55hp 55 Hp 1" To 78" Lawn...
Fitted new coil to briggs and straton 16 twin but have no spark
unplug the wire that comes from the tractor then check for spark if you do then stat by checking he safety switches
Mar 30, 2012 | Briggs & Stratton Garden
My mower has sat for about a year and has not been used. I am unable to get it started now. Prime it and when I turn the key it just will not turn over. Doesn't sound much like it is trying. Could...
It probably isn't the spark plug, they don't typically fail from sitting.
I would say that it is probably old fuel that has gelled in the carb. The carb needs probably needs cleaned and the diaphragm possibly replaced.
Aug 29, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
